This is the wat the terminal shows when i run the code
(python3:3543): GStreamer-WARNING **: 10:38:24.675: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so’: /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
(python3:3543): GStreamer-WARNING **: 10:38:24.683: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so’: /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
[ WARN:0] global …/modules/videoio/src/cap_gstreamer.cpp (713) open OpenCV | GStreamer warning: Error opening bin: no element “nvarguscamerasrc”
[ WARN:0] global …/modules/videoio/src/cap_gstreamer.cpp (480) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
[ERROR:0] global …/modules/videoio/src/cap.cpp (116) open VIDEOIO(CV_IMAGES): raised OpenCV exception:
OpenCV(4.2.0) …/modules/videoio/src/cap_images.cpp:253: error: (-5:Bad argument) CAP_IMAGES: can’t find starting number (in the name of file): nvarguscamerasrc ! video/x-raw(memory:NVMM), width=326 4, height=2464, format=NV12, framerate=21/1 ! nvvidconv flip-method=2 ! video/x-raw, width=320, height=240, format=BGRx ! videoconvert ! video/x- raw, format=BGR ! appsink in function ‘icvExtractPattern’
File “pom-ai_1.py”, line 71, in
cv2.imwrite(filename, frame)
cv2.error: OpenCV(4.2.0) …/modules/imgcodecs/src/loadsave.cpp:715: error: (-215:Assertion failed) !_img.empty() in function ‘imwrite’
