I’m using Ubuntu 18.04. I’ve installed all the dependencies using the script as well. I’ve also installed the nvidia driver 440 mentioned in the documentation.
I am able to run all c++ sample apps like ping and stereo_dummy, but none of the python samples can be run.
This is how I’m trying to run the python app:
kirang@Kiran:~/ISAAC/sdk$ bazel run //apps/tutorials/ping_python
This is the error that I’m getting:
ERROR: /ISAAC/sdk/packages/pyalice/BUILD:13:1: no such package ‘@com_nvidia_isaac_engine//engine’: BUILD file not found in directory ‘engine’ of external repository @com_nvidia_isaac_engine. Add a BUILD file to a directory to mark it as a package. and referenced by ‘//packages/pyalice:bindings_pybind’
ERROR: /ISAAC/sdk/packages/pyalice/BUILD:30:1: no such package ‘@com_nvidia_isaac_engine//engine’: BUILD file not found in directory ‘engine’ of external repository @com_nvidia_isaac_engine. Add a BUILD file to a directory to mark it as a package. and referenced by ‘//packages/pyalice:components’
WARNING: errors encountered while analyzing target ‘//apps/tutorials/ping_python:ping_python’: it will not be built
INFO: Analyzed target //apps/tutorials/ping_python:ping_python (0 packages loaded, 3 targets configured).
INFO: Found 0 targets…
ERROR: command succeeded, but there were loading phase errors
INFO: Elapsed time: 4.278s, Critical Path: 0.11s
INFO: 0 processes.
FAILED: Build did NOT complete successfully
