Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
other
Hi I am using nvidia driver os docker container and i am trying to run the sample hello world application. I see the below error
On my host i installed the gpu driver and sdkmanager already.
nvidia-smi
Tue Feb 7 16:36:01 2023
| NVIDIA-SMI 525.78.01 Driver Version: 525.78.01 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA RTX A4500 Off | 00000000:B3:00.0 On | Off |
| 30% 28C P8 13W / 200W | 130MiB / 20470MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1303 G /usr/lib/xorg/Xorg 54MiB |
| 0 N/A N/A 2204 G /usr/bin/gnome-shell 74MiB |
Is it expected that we need to install the same driver and sdkmanager in the docker environment as well to mitigate this issue?
Dear @Sistla3,
Yes. It looks like issue with nvidia driver.
Did you install CUDA 12.x seperately on host? Note that, we recommend to use docker container for cross compiling. If you want to test out x86 samples, You can install DRIVE OS 6.0.5 using sdkmanager on host and check running.
Hi Siva,
The issue that i am noticing above is in the docker itself . I am not planning to run anything on the host side. But wanted to check if the issue is because of the driver missing on the host side
Hi Siva,
I updated my cuda to 12.0
nvidia-smi
Wed Feb 8 08:24:14 2023
| NVIDIA-SMI 525.85.12 Driver Version: 525.85.12 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA RTX A4500 On | 00000000:B3:00.0 On | Off |
| 30% 29C P8 9W / 200W | 87MiB / 20470MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1396 G /usr/lib/xorg/Xorg 85MiB |
Is there any procedure document that needs to be followed for the tools installations on the host side before starting to use the docker?
is there a way for me to check the driver version that is being used in the docker to rule out any mismatches if there are any ?
I tried checking the nvidia-smi inside the docker and i dont see any installed binary for that and it fails to tell me what the driver version in the container is.
Will a lightdm on the host machine cause any of these errors?
