Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating H264 Encoder
Creating H264 rtppay
Playing file /dli/task/my_apps/auto-sentry/videos/img_1280.264
Warning: ‘input-dims’ parameter has been deprecated. Use ‘infer-dims’ instead.
Unknown or legacy key specified ‘process_mode’ for group [property]
Warn: ‘threshold’ parameter has been deprecated. Use ‘pre-cluster-threshold’ instead.
Adding elements to Pipeline
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
Starting pipeline
Opening in BLOCKING MODE
0:00:00.411950373 1233 0xccd1260 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1161> [UID = 2]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:07.727722926 1233 0xccd1260 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 2]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/my_apps/model/LP/LPR/lpr_us_onnx_b16.engine
INFO: [FullDims Engine Info]: layers num: 3
0 INPUT kFLOAT image_input 3x48x96 min: 1x3x48x96 opt: 4x3x48x96 Max: 16x3x48x96
1 OUTPUT kINT32 tf_op_layer_ArgMax 24 min: 0 opt: 0 Max: 0
2 OUTPUT kFLOAT tf_op_layer_Max 24 min: 0 opt: 0 Max: 0
ERROR: [TRT]: 3: Cannot find binding of given name: output_bbox/BiasAdd
0:00:07.729057903 1233 0xccd1260 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1868> [UID = 2]: Could not find output layer ‘output_bbox/BiasAdd’ in engine
ERROR: [TRT]: 3: Cannot find binding of given name: output_cov/Sigmoid
0:00:07.729128529 1233 0xccd1260 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1868> [UID = 2]: Could not find output layer ‘output_cov/Sigmoid’ in engine
0:00:07.729159415 1233 0xccd1260 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 2]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/my_apps/model/LP/LPR/lpr_us_onnx_b16.engine
0:00:07.757646286 1233 0xccd1260 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 2]: Load new model:sgie2_config.txt sucessfully
0:00:08.382378544 1233 0xccd1260 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 2]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/my_apps/model/LP/LPD/usa_pruned.etlt_b16_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x480x640
1 OUTPUT kFLOAT output_bbox/BiasAdd 4x30x40
2 OUTPUT kFLOAT output_cov/Sigmoid 1x30x40
0:00:08.383557632 1233 0xccd1260 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 2]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/my_apps/model/LP/LPD/usa_pruned.etlt_b16_gpu0_fp16.engine
0:00:08.499819644 1233 0xccd1260 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 2]: Load new model:sgie1_config.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
~~ CLOG[/dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvmultiobjecttracker/include/modules/NvMultiObjectTracker/NvTrackerParams.hpp, getConfigRoot() @line 54]: [NvTrackerParams::getConfigRoot()] !!![WARNING] Invalid low-level config file caused an exception, but will go ahead with the default config values
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
[NvMultiObjectTracker] Initialized
0:00:08.546134872 1233 0xccd1260 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1161> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:09.080365836 1233 0xccd1260 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:09.081373514 1233 0xccd1260 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
0:00:09.088661434 1233 0xccd1260 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:pgie_config.txt sucessfully
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform.cpp:3885: => VIC Configuration failed image scale factor exceeds 16, use GPU for Transformation
0:00:09.457638433 1233 0xce0ef70 WARN nvinfer gstnvinfer.cpp:1376:convert_batch_and_push_to_input_thread: error: NvBufSurfTransform failed with error -2 while converting buffer
0:00:09.458394231 1233 0xce0ef70 WARN nvinfer gstnvinfer.cpp:2288:gst_nvinfer_output_loop: error: Internal data stream error.
0:00:09.458501629 1233 0xce0ef70 WARN nvinfer gstnvinfer.cpp:2288:gst_nvinfer_output_loop: error: streaming stopped, reason error (-5)
0:00:09.458678768 1233 0xce0ef70 WARN nvinfer gstnvinfer.cpp:1376:convert_batch_and_push_to_input_thread: error: NvBufSurfTransform failed with error -3 while converting buffer
Error: gst-stream-error-quark: NvBufSurfTransform failed with error -2 while converting buffer (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1376): convert_batch_and_push_to_input_thread (): /GstPipeline:pipeline0/GstNvInfer:secondary2-nvinference-engine
0:00:09.488175817 1233 0xce0ef70 WARN nvinfer gstnvinfer.cpp:1376:convert_batch_and_push_to_input_thread: error: NvBufSurfTransform failed with error -3 while converting buffer
