I am manually specifying the options to save a video stream to an mp4 file. When I rundetectnet
and specify an output.mp4
the file will save and I can click on it and view it. When I specify the exact same options manually the video saves but gives me a no playable streams
error. Below I’ll include the terminal output from detectnet
, the terminal output from my code, and then my actual code where I specify the options and use the render function to save the video. This is the error I’m seeing
[image] failed to save 1920x1080 image to 'output_4.mp4/0.jpg'
[image] imageWriter -- failed to save 'output_4.mp4/0.jpg'
Terminal output from detectnet
[gstreamer] nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=30/1, format=(string)NV12 ! nvvidconv flip-method=2 ! video/x-raw(memory:NVMM) ! appsink name=mysink
[gstreamer] gstCamera successfully created device csi://0
[video] created gstCamera from csi://0
gstCamera video options:
-- URI: csi://0
- protocol: csi
-- deviceType: csi
-- ioType: input
-- width: 1280
-- height: 720
-- frameRate: 30
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: rotate-180
[gstreamer] gstEncoder -- codec not specified, defaulting to H.264
[gstreamer] gstEncoder -- pipeline launch string:
[gstreamer] appsrc name=mysource is-live=true do-timestamp=true format=3 ! omxh264enc name=encoder bitrate=4000000 ! video/x-h264 ! h264parse ! qtmux ! filesink location=output.mp4
[video] created gstEncoder from file:///home/crose72/Documents/GitHub/OperationSquirrel/scratch/object-detection-examples/detectnet/build/output.mp4
gstEncoder video options:
-- URI: file:///home/crose72/Documents/GitHub/OperationSquirrel/scratch/object-detection-examples/detectnet/build/output.mp4
- protocol: file
- extension: mp4
-- deviceType: file
-- ioType: output
-- codec: H264
-- codecType: omx
-- frameRate: 30
-- bitRate: 4000000
-- numBuffers: 4
-- zeroCopy: true
[OpenGL] glDisplay -- X screen 0 resolution: 1920x1080
[OpenGL] glDisplay -- X window resolution: 1920x1080
[OpenGL] glDisplay -- display device initialized (1920x1080)
[video] created glDisplay from display://0
glDisplay video options:
-- URI: display://0
- protocol: display
-- deviceType: display
-- ioType: output
-- width: 1920
-- height: 1080
-- frameRate: 0
-- numBuffers: 4
-- zeroCopy: true
Terminal output from my code
-- URI: csi://0
- protocol: csi
-- deviceType: csi
-- ioType: input
-- width: 1280
-- height: 720
-- frameRate: 30
-- numBuffers: 4
-- zeroCopy: true
[gstreamer] appsrc name=mysource is-live=true do-timestamp=true format=3 ! omxh264enc name=encoder bitrate=4000000 ! video/x-h264 ! h264parse ! qtmux ! filesink location=video.mp4
[video] created gstEncoder from file:///home/crose72/Documents/GitHub/OperationSquirrel/SquirrelDefender/build/video.mp4
-- URI: file:///home/crose72/Documents/GitHub/OperationSquirrel/SquirrelDefender/build/video.mp4
- protocol: file
- extension: mp4
-- deviceType: file
-- ioType: output
-- codec: H264
-- codecType: omx
-- frameRate: 30
-- bitRate: 4000000
-- numBuffers: 4
-- zeroCopy: true
-- URI: display://0
- protocol: display
-- ioType: output
-- width: 1920
-- height: 1080
-- frameRate: 30
-- numBuffers: 4
-- zeroCopy: true
And then here’s my video options
bool Video::create_output_vid_stream(void)
std::string baseName = "output";
std::string extension = ".mp4";
std::string fileName = generate_unique_file_name(baseName, extension);
videoOptions options;
options.resource = fileName;
options.deviceType = videoOptions::DeviceType::DEVICE_FILE;
options.ioType = videoOptions::IoType::OUTPUT;
options.codec = videoOptions::Codec::CODEC_H264;
options.codecType = videoOptions::CodecType::CODEC_OMX;
options.width = 1280;
options.height = 720;
options.frameRate = 30;
options.zeroCopy = true;
output_vid_file = videoOutput::Create(options);
if (!output_vid_file)
LogError("detectnet: failed to create output_vid_file stream\n");
return false;
return true;
And the render function to save the video
bool Video::save_video(void)
// render output_vid_disp to the display
if (output_vid_file != NULL)
output_vid_file->Render(image, input->GetWidth(), input->GetHeight());
// update the status bar
char str[256];
sprintf(str, "TensorRT %i.%i.%i | %s | Network %.0f FPS", NV_TENSORRT_MAJOR, NV_TENSORRT_MINOR, NV_TENSORRT_PATCH, precisionTypeToStr(net->GetPrecision()), net->GetNetworkFPS());
output_vid_file->SetStatus(str);
// check if the user quit
if (!output_vid_file->IsStreaming())
return false;
return true;
