Unable to set device in gst_nvstreammux_change_state
Deepstream Version : 6.O
I am facing this below issue while trying to run deepstream-app.
Erroe: → Unable to set device in gst_nvstreammux_change_state
0:00:00.645630705 53 0x562db0c518f0 WARN bin gstbin.c:2832:reset_state:<multi_src_bin> Failed to switch back down to NULL
** ERROR: main:1461: Failed to set pipeline to PAUSED
Quitting
App run failed
I am a beginner in deepstream What exactly i need to do in order to resolve this issue?
I am waiting for your response.
fixed the issue as i have only one gpu and was put gpu id as 1 that’s why this error was coming. I just changed the gpu id as 0 and its working fine then.
Glad to know you have found the answer.
