Hardware Platform: Jetson AGX Orin
Jetpak Version: Jetpak 6.2 (R36.4.3)
Issue Description:
We are developing a camera driver on Jetpak 6.2 for the Jetson AGX Orin platform. The camera can be successfully bring up using argus_camera
. However, when attempting to modify the “Exposure Time Range” and “Gain Range” parameters in the argus_camera
interface, the corresponding driver functions, sensor_set_gain
and sensor_set_exposure
, are not being invoked.
Driver Code:
static const u32 ctrl_cid_list[] = {
TEGRA_CAMERA_CID_GAIN,
TEGRA_CAMERA_CID_EXPOSURE,
TEGRA_CAMERA_CID_EXPOSURE_SHORT,
TEGRA_CAMERA_CID_FRAME_RATE,
TEGRA_CAMERA_CID_HDR_EN,
TEGRA_CAMERA_CID_SENSOR_MODE_ID,
static struct tegracam_ctrl_ops sensor_ctrl_ops = {
.numctrls = ARRAY_SIZE(ctrl_cid_list),
.ctrl_cid_list = ctrl_cid_list,
.set_gain = sensor_set_gain,
.set_exposure = sensor_set_exposure,
.set_exposure_short = sensor_set_exposure,
.set_frame_rate = sensor_set_frame_rate,
.set_group_hold = sensor_set_group_hold,
static int sensor_probe(struct i2c_client *client,
const struct i2c_device_id *id)
struct device *dev = &client->dev;
struct device_node *node = dev->of_node;
struct tegracam_device *tc_dev;
struct cam_str *priv;
int err;
if (!IS_ENABLED(CONFIG_OF) || !node)
return -EINVAL;
priv = devm_kzalloc(dev, sizeof(struct cam_str), GFP_KERNEL);
if (!priv) {
dev_err(dev, "unable to allocate memory!\n");
return -ENOMEM;
tc_dev = devm_kzalloc(dev,
sizeof(struct tegracam_device), GFP_KERNEL);
if (!tc_dev)
devm_kfree(dev, priv);
return -ENOMEM;
priv->i2c_client = tc_dev->client = client;
priv->id = id;
tc_dev->dev = dev;
strncpy(tc_dev->name, id->name, sizeof(tc_dev->name));
tc_dev->dev_regmap_config = &sensor_regmap_config;
tc_dev->sensor_ops = &sensor_common_ops;
tc_dev->v4l2sd_internal_ops = &sensor_subdev_internal_ops;
tc_dev->tcctrl_ops = &sensor_ctrl_ops;
err = tegracam_device_register(tc_dev);
if (err) {
dev_err(dev, "tegra camera driver registration failed\n");
return err;
priv->tc_dev = tc_dev;
priv->s_data = tc_dev->s_data;
priv->subdev = &tc_dev->s_data->subdev;
tegracam_set_privdata(tc_dev, (void *)priv);
err = sensor_board_setup(priv);
if (err) {
tegracam_device_unregister(tc_dev);
dev_err(dev, "board setup failed\n");
return err;
We are wondering why the sensor_set_gain
functions are not being called when we adjust the Exposure Time and Gain parameters in argus_camera
