throws error
2023-03-17 16:31:14 [Error] [carb.events.python] ValueError: ‘rap_NV_Project1_JDB.wav’ is not in list
any solution?
Using v2022.2.0
I’d recommend a cleanup for your installation, check this out Cleanup-Tool — Omniverse Launcher documentation
Tried it but getting the same type of error
2023-03-17 22:29:45 [Error] [omni.audio2face.utility.scripts.utils] Unable to set value resevoirdogs.wav for setting track_name
2023-03-17 22:29:45 [Error] [omni.audio2face.utility.scripts.utils] Unable to set value C:/Users/Mit/Documents/ for setting track_root_path
2023-03-17 22:29:45 [Error] [omni.ui.python] ValueError: File format b’\x00\x00\x00\x18’ not understood. Only ‘RIFF’ and ‘RIFX’ supported.
2023-03-17 22:29:45 [Error] [omni.ui.python] At:
2023-03-17 22:29:45 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.player_deps\deps\py\scipy\io\wavfile.py(521): _read_riff_chunk
2023-03-17 22:29:45 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.player_deps\deps\py\scipy\io\wavfile.py(705): read
2023-03-17 22:29:45 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.player_deps\deps\audio2face-sdk\python/audio2face/audio\audio_track.py(55): read_track
2023-03-17 22:29:45 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.player_deps\deps\audio2face-sdk\python/audio2face/audio\audio_track.py(75): read_track_from_bytes
2023-03-17 22:29:45 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.player\omni\audio2face\player\scripts\instances.py(392): _load_track
2023-03-17 22:29:45 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.player\omni\audio2face\player\scripts\instances.py(287): _set_track_name
2023-03-17 22:29:45 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.common\omni\audio2face\common\scripts\settings.py(73): set_val
2023-03-17 22:29:45 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.common\omni\audio2face\common\scripts\settings.py(83): reset
2023-03-17 22:29:45 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.common\omni\audio2face\common\scripts\settings.py(225): set_options_and_reset
2023-03-17 22:29:45 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.player\omni\audio2face\player\scripts\instances.py(265): _set_track_root_path
2023-03-17 22:29:45 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.ui.common\omni\audio2face\ui\common\scripts\ui.py(1231): _on_browse_selected
2023-03-17 22:29:45 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\kit\exts\omni.kit.window.filepicker\omni\kit\window\filepicker\file_bar.py(284): _on_apply
2023-03-17 22:29:45 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\kit\exts\omni.kit.window.filepicker\omni\kit\window\filepicker\file_bar.py(248):
2023-03-17 22:29:45 [Error] [carb.events.python] ValueError: ‘rap_NV_Project1_JDB.wav’ is not in list
2023-03-17 22:29:45 [Error] [carb.events.python] At:
2023-03-17 22:29:45 [Error] [carb.events.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.common\omni\audio2face\common\scripts\settings.py(234): get_index
2023-03-17 22:29:45 [Error] [carb.events.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.ui.common\omni\audio2face\ui\common\scripts\ui.py(717): _on_update
It looks like you’re using Audio2Face 2022.1.2
. Can you try 2022.2.0
to see if it works?
Tried, throws the same error message
Could you please send your latest Audio2Face log file which can be found here: C:\Users\<USERNAME>\.nvidia-omniverse\logs\Kit\Audio2Face
Your graphics driver version seems to be 531.29
. Could you try installing 527.37
to see if it works?
Sure, downgraded to 527.37 and getting a similar error
2023-03-20 16:40:57 [Error] [omni.audio2face.utility.scripts.utils] Unable to set value resevoirdogs.wav for setting track_name
2023-03-20 16:40:57 [Error] [omni.audio2face.utility.scripts.utils] Unable to set value C:/Users/Mit/Documents/ for setting track_root_path
2023-03-20 16:40:57 [Error] [omni.ui.python] ValueError: File format b’\x00\x00\x00\x18’ not understood. Only ‘RIFF’ and ‘RIFX’ supported.
2023-03-20 16:40:57 [Error] [omni.ui.python] At:
2023-03-20 16:40:57 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.player_deps\deps\py\scipy\io\wavfile.py(521): _read_riff_chunk
2023-03-20 16:40:57 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.player_deps\deps\py\scipy\io\wavfile.py(705): read
2023-03-20 16:40:57 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.player_deps\deps\audio2face-sdk\python/audio2face/audio\audio_track.py(55): read_track
2023-03-20 16:40:57 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.player_deps\deps\audio2face-sdk\python/audio2face/audio\audio_track.py(75): read_track_from_bytes
2023-03-20 16:40:57 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.player\omni\audio2face\player\scripts\instances.py(392): _load_track
2023-03-20 16:40:57 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.player\omni\audio2face\player\scripts\instances.py(287): _set_track_name
2023-03-20 16:40:57 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.common\omni\audio2face\common\scripts\settings.py(73): set_val
2023-03-20 16:40:57 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.common\omni\audio2face\common\scripts\settings.py(83): reset
2023-03-20 16:40:57 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.common\omni\audio2face\common\scripts\settings.py(225): set_options_and_reset
2023-03-20 16:40:57 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.player\omni\audio2face\player\scripts\instances.py(265): _set_track_root_path
2023-03-20 16:40:57 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\exts\omni.audio2face.ui.common\omni\audio2face\ui\common\scripts\ui.py(1231): _on_browse_selected
2023-03-20 16:40:57 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\kit\exts\omni.kit.window.filepicker\omni\kit\window\filepicker\file_bar.py(284): _on_apply
2023-03-20 16:40:57 [Error] [omni.ui.python] c:\users\mit\appdata\local\ov\pkg\audio2face-2022.2.0\kit\exts\omni.kit.window.filepicker\omni\kit\window\filepicker\file_bar.py(248):
Are you using a custom audio file? If so, are you able to share your audio file?
Yes, I am!! I checked it with other audio files, and it worked fine. Maybe the issue was with the wav that was exported. Thank you
