Hi there,
I followed the instructions on the user guide, in order to generate the APK and install it on a Quest 2.
but the client App keep crashing every-time i try to start it.
This is is what i see in the logs :
E/AndroidRuntime: FATAL EXCEPTION: main
Process: com.nvidia.cloudxr.ovr, PID: 7342
java.lang.UnsatisfiedLinkError: dlopen failed: library “/system/lib64/libvrapi.so” needed or dlopened by “/apex/com.android.runtime/lib64/libnativeloader.so” is not accessible for the namespace “classloader-namespace”
at java.lang.Runtime.loadLibrary0(Runtime.java:1071)
at java.lang.Runtime.loadLibrary0(Runtime.java:1007)
at java.lang.System.loadLibrary(System.java:1667)
at com.nvidia.cloudxr.ovr.MainActivity.(MainActivity.java:44)
at java.lang.Class.newInstance(Native Method)
at android.app.AppComponentFactory.instantiateActivity(AppComponentFactory.java:95)
at android.support.v4.app.CoreComponentFactory.instantiateActivity(CoreComponentFactory.java:43)
at android.app.Instrumentation.newActivity(Instrumentation.java:1250)
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:3196)
at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:3424)
at android.app.servertransaction.LaunchActivityItem.execute(LaunchActivityItem.java:83)
at android.app.servertransaction.TransactionExecutor.executeCallbacks(TransactionExecutor.java:135)
at android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:95)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2030)
at android.os.Handler.dispatchMessage(Handler.java:109)
at android.os.Looper.loop(Looper.java:214)
at android.app.ActivityThread.main(ActivityThread.java:7400)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:492)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:936)
Could someone help me to fix this error.
