Hi community,
My BGP configuration is very simple, but I cannot set up eBGP peers, they remain in Active state. The BGP configuration is like that:
nv set vrf default router bgp autonomous-system 64514
nv set vrf default router bgp router-id 10.10.20.1
nv set vrf default router bgp neighbor 10.10.20.2 remote-as 64515
nv set vrf default router bgp neighbor 10.10.30.1 remote-as 64512
nv set vrf default router bgp neighbor 10.10.30.1 multihop-ttl 100
nv set vrf default router bgp neighbor 10.10.30.2 remote-as 64513
nv set vrf default router bgp neighbor 10.10.30.2 multihop-ttl 100
The configuration in the peers is the opposite.
cumulus@SW-MLNX-01-AVZ1:mgmt:~$net show bgp summary
show bgp ipv4 unicast summary
BGP router identifier 10.10.20.1, local AS number 64514 vrf-id 0
BGP table version 0
RIB entries 0, using 0 bytes of memory
Peers 3, using 68 KiB of memory
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd PfxSnt
10.10.20.2 4 64515 0 0 0 0 0 never Active 0
10.10.30.1 4 64512 0 0 0 0 0 never Active 0
10.10.30.2 4 64513 0 0 0 0 0 never Active 0
Total number of neighbors 3
But I can ping the peers successfully:
cumulus@SW-MLNX-01-AVZ1:mgmt:~$ ping 10.10.20e[Ke[K30.1
vrf-wrapper.sh: switching to vrf “default”; use ‘–no-vrf-switch’ to disable
PING 10.10.30.1 (10.10.30.1) 56(84) bytes of data.
64 bytes from 10.10.30.1: icmp_seq=1 ttl=61 time=7.78 ms
64 bytes from 10.10.30.1: icmp_seq=2 ttl=61 time=5.03 ms
64 bytes from 10.10.30.1: icmp_seq=3 ttl=61 time=5.64 ms
64 bytes from 10.10.30.1: icmp_seq=4 ttl=61 time=4.38 ms
64 bytes from 10.10.30.1: icmp_seq=5 ttl=61 time=7.10 ms
^C
— 10.10.30.1 ping statistics —
5 packets transmitted, 5 received, 0% packet loss, time 11ms
rtt min/avg/max/mdev = 4.380/5.985/7.783/1.276 ms
I cannot see any interesting in frr.log, only this:
2023-02-06T11:48:01.162971+00:00 SW-MLNX-01-AVZ1 watchfrr[1913]: zebra state → up : connect succeeded
2023-02-06T11:48:01.165817+00:00 SW-MLNX-01-AVZ1 watchfrr[1913]: bgpd state → up : connect succeeded
2023-02-06T11:48:01.167261+00:00 SW-MLNX-01-AVZ1 watchfrr[1913]: all daemons up, doing startup-complete notify
2023-02-06T11:48:01.931755+00:00 SW-MLNX-01-AVZ1 zebra[1955]: Configuration Read in Took: 00:00:00
2023-02-06T11:48:02.789740+00:00 SW-MLNX-01-AVZ1 bgpd[1998]: Configuration Read in Took: 00:00:01
2023-02-06T11:48:02.839266+00:00 SW-MLNX-01-AVZ1 watchfrr[1913]: Daemon: zebra: is in Up state but expected it to be in DAEMON_DOWN state
2023-02-06T11:48:02.842824+00:00 SW-MLNX-01-AVZ1 watchfrr[1913]: Daemon: bgpd: is in Up state but expected it to be in DAEMON_DOWN state
2023-02-06T11:48:02.843310+00:00 SW-MLNX-01-AVZ1 watchfrr[1913]: Daemon: staticd: is in Up state but expected it to be in DAEMON_DOWN state
I don’t know if those logs are fine or have to do with the BGP session establishment.
Any idea?
Regards,
Julián
