Unable to start after flashing jetson 36.4 with custom UEFI
I performed boot time optimization and nvidia logo removal on jetson orin NX and nano dev kits with jetson r36.3 before. With the release of r36.4, I was needed to perform the same. So, after performing kernel customization on r36.4, I full-flashed the dev kit using
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 jetson-orin-nano-devkit internal
and it was successful, device was booting without any error. Afterwards, I built the UEFI for r36.4 without any changes and replaced the uefi_jetson.bin and BOOTAA64 files and reflashed. The flash log ends with flash is successful and rebooting the device.However, the device gives a blank screen and doesn’t start. I’ve tried it with different UEFI combos for jetson 36.4 from here but nothing seems to work and I get the same error.
Your help is requested and appreciated.
Here are flash and uart bootup logs
flash_2-1_0_20241114-093947.log (47.8 KB)
UART LOG:
��[     0.326035] Camera-FW on t234-rce-safe started
TCU early console enabled.
DCE Started
DCE_R5_Init
MPU enabled
DCE_SW_Init
��[     0.578062] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.415 ms, total boot 265.513 ms)
��I/TC:
��Admin Task Init
Admin Task Init complete
Print Task Init
RM Task Init
SHA Task Init
Admin Task Started
DCE SC7 SHA Enabled
RM Task Started
RM Task Running
Print Task Started
Print Task Running
SHA Task Started
DCE: FW Boot Complete
Admin Task Running
SHA Task Running
��I/TC: Non-secure external DT found
I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Fri Sep 13 04:10:17 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: fTPM ID is not enabled.
I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is not supported.
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 202410.0-f4d4ea48 built on 2024-11-14T09:14:14+05:00)
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
I/TC: WARNING: Test UEFI variable auth key is being used !
I/TC: WARNING: UEFI variable protection is not fully enabled !
��[     2.487274] Camera-FW on t234-rce-safe started
Jetson System firmware version 202410.0-f4d4ea48 date 2024-11-14T09:14:14+05:00
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
s     to enter Shell.
Enter to continue boot.
L4TLauncher: Attempting Direct Boot
ASSERT [L4TLauncher] /home/ubuntu/UEFIdev/uefi-202410/nvidia-uefi/edk2/MdePkg/Li
brary/UefiFileHandleLib/UefiFileHandleLib.c(1016): !(((INTN)(RETURN_STATUS)(Stat
us)) < 0)
us)) < 0)
brary/UefiFileHandleLib/UefiFileHandleLib.c(936): !(((INTN)(RETURN_STATUS)(Statu
s)) < 0)
L4TLauncher: Unable to process extlinux config: Not Found
L4TLauncher: Attempting Kernel Boot
��[     0.323350] Camera-FW on t234-rce-safe started
DCE Started
DCE_R5_Init
MPU enabled
DCE_SW_Init
��[     0.575335] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.417 ms, total boot 265.475 ms)
��I/TC:
��Admin Task Init
Print Task Init
RM Task Init
SHA Task Init
Admin Task Started
DCE SC7 SHA Enabled
RM Task Started
RM Task Running
Print Task Started
Print Task Running
SHA Task Started
Admin Task Running
SHA Task Running
��[     2.484535] Camera-FW on t234-rce-safe started
ESC   to enter Setup.
s     to enter Shell.
us)) < 0)
us)) < 0)
s)) < 0)
��[     0.325151] Camera-FW on t234-rce-safe started
Hi tornado1100,
Please share the detailed steps how did you clone the UEFI source and build UEFI binary.
Can you also try just updating <Linux_for_Tegra>/bootloader/uefi_jetson.bin and check if you would hit the boot issue?
Hello Kevin,
As provided in the build without docker guide, I cloned some of the sources for r36.4 including main, uefi-202410.0 and r36.4.0. Since there’s an error in .gitmodules file of edk2 - wrong link for subhook module, I used the following commands as given in this thread to clone the UEFI source:
edk2_docker edkrepo clone nvidia-uefi NVIDIA-Platforms main -s
cd nvidia-uefi/edk2
# edit .gitmodules and change subhook URL to https://github.com/tianocore/edk2-subhook.git
git commit -a -m "Fix subhook url"
git submodule init
git submodule update
Afterwards, I build the UEFI without any changes simply using edk2-nvidia/Platform/NVIDIA/Jetson/build.sh, and it was built successfully.
Do you mean to just replace the uefi_jetson.bin and not replace BOOTAA64.efi file?
If you meant that, I just did it and it’s still behaving the same.
If I recopy the original uefi_jetson.bin and BOOTAA4.efi files and flash, it works without a hitch.
Please do not use main branch to build UEFI binary for R36.4.0
main branch includes the latest changes but it might be unstable for each release.
You can use the following command instead.
$ edk2_docker edkrepo clone nvidia-uefi-r36.4.0 NVIDIA-Platforms r36.4.0
Hello Kevin,
I tried it with r36.4.0 branch as well, still the issue remains the same.
It is not the expected result to me since you’ve used the clean UEFI binary w/o any customization.
Could you check if the following UEFI binary can work on your devkit?
uefi_Jetson_RELEASE.bin (3.2 MB)
$ cp uefi_Jetson_RELEASE.bin <Linux_for_Tegra>/bootloader/uefi_jetson.bin
$ sudo ./flash.sh -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internal
I used your provided .bin file, here’s the flash log and the video to let you see what I’m facing.
Moreover, I used this command to flash this time
instead of this.
[sudo] password for ubuntu:
# L4T BSP Information:
# R36 , REVISION: 4.0
# User release: 0.0
ECID is 0x80012344705DD5047C00000013008240
# Target Board Information:
# Name: jetson-orin-nano-devkit, Board Family: generic, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying device_config(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
copying emc_fuse_dev_params(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-diag-boot.dts)... done.
Existing emcfuse(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/fuse_t234.xml) reused.
./tegraflash.py --chip "0x23" --applet "/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "readfuses fuse_t234.bin fuse_t234.xml; dump eeprom cvm cvm.bin; dump try_custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0333 ] Reading fuses
[   0.0339 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0343 ] File rcm_state open failed
[   0.0347 ] ERROR: failed to read rcm_state
[   0.0347 ]
[   0.0365 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0367 ] Assuming zero filled SBK key
[   0.0352 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.1646 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.1797 ] Parsing partition layout
[   0.1807 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.1939 ] Kernel DTB used: None
[   0.1940 ] WARNING: dce base dtb is not provided
[   0.1940 ] Parsing partition layout
[   0.1949 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.1958 ] Creating list of images to be signed
[   0.1965 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.1971 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.2122 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.2128 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.2197 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.2205 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.2335 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.2342 ] adding BCH for mb2_t234_aligned.bin
[   0.2466 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.2662 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.2669 ] adding BCH for mb2_t234_aligned.bin
[   0.2859 ] Filling MB1 storage info
[   0.2860 ] Parsing dev params for multi chains
[   0.2975 ] Generating br-bct
[   0.2982 ] Updating dev and MSS params in BR BCT
[   0.2983 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.3204 ] Updating bl info
[   0.3214 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.3222 ] WARNING: boot chain is not completed. set to 0
[   0.3237 ] Generating signatures
[   0.3254 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.3258 ] Assuming zero filled SBK key
[   0.3739 ] Warning: pub_key.key is not found
[   0.3725 ] Parsing dev params for multi chains
[   0.3726 ] Generating br-bct
[   0.3732 ] Updating dev and MSS params in BR BCT
[   0.3733 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.3743 ] Updating bl info
[   0.3749 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.3754 ] WARNING: boot chain is not completed. set to 0
[   0.3784 ] Generating SHA2 Hash
[   0.3843 ] Sha saved in br_bct_BR.sha
[   0.3830 ] Get Signed section of bct
[   0.3843 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.3856 ] Signing BCT
[   0.3873 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.3876 ] Assuming zero filled SBK key
[   0.3911 ] Sha saved in br_bct_BR.sha
[   0.3915 ] Warning: pub_key.key is not found
[   0.3898 ] Updating BCT with signature
[   0.3904 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.3909 ] Offset :4608 Len :3584
[   0.3916 ] Generating SHA2 Hash
[   0.3933 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.3935 ] Assuming zero filled SBK key
[   0.3936 ] Assuming zero filled SBK key
[   0.3963 ] Sha saved in br_bct_BR.sha
[   0.3950 ] Updating BCT with SHA2 Hash
[   0.3956 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.3960 ] Offset :4608 Len :3584
[   0.3966 ] Offset :68 Len :8124
[   0.3969 ] Generating coldboot mb1-bct
[   0.3979 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.3984 ] MB1-BCT version: 0.13
[   0.4007 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.4011 ] Added Platform Config 9 data with size :- 100
[   0.4012 ]
[   0.4012 ] Updating mb1-bct with firmware information
[   0.4017 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.4033 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.4040 ] Generating SHA2 Hash for mb1bct
[   0.4069 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.4082 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.4072 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.4077 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.4105 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.4107 ] Assuming zero filled SBK key
[   0.4123 ] Warning: pub_key.key is not found
[   0.4113 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.4127 ] Generating recovery mb1-bct
[   0.4134 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.4139 ] MB1-BCT version: 0.13
[   0.4163 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.4168 ] Added Platform Config 9 data with size :- 100
[   0.4168 ]
[   0.4168 ] Updating mb1-bct with firmware information
[   0.4175 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.4202 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.4209 ] Generating SHA2 Hash for mb1bct
[   0.4238 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.4251 ] Sha saved in mb1_bct_MB1.sha
[   0.4240 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.4245 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.4273 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.4274 ] Assuming zero filled SBK key
[   0.4293 ] Warning: pub_key.key is not found
[   0.4284 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.4298 ] Info: Skip generating mem_bct because sdram_config is not defined
[   0.4299 ] Info: Skip generating mem_bct because sdram_config is not defined
[   0.4299 ] Copying signatures
[   0.4310 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.4376 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.4378 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.4379 ] Boot Rom communication
[   0.4384 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.4389 ] BR_CID: 0x80012344705DD5047C00000013008240
[   0.4400 ] Sending bct_br
[   0.4402 ] Sending mb1
[   0.4407 ] Sending psc_bl1
[   0.4512 ] Sending bct_mb1
[   0.4568 ] Boot Rom communication completed
[   0.4643 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.4657 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.4664 ] adding BCH for applet_t234_aligned.bin
[   0.4811 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.4816 ] Assuming zero filled SBK key
[   0.4848 ] Warning: pub_key.key is not found
[   0.4841 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.4862 ] Sending mb2_applet...
[   0.4869 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.4874 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[   0.4883 ] Sending applet
[   0.5014 ] completed
[   0.5024 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.5031 ] MB2 Applet version 01.00.0000
[   0.5998 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.6003 ] MB2 Applet version 01.00.0000
[   0.6030 ] Parsing fuse info as per xml file
[   0.6035 ] tegraparser_v2 --chip 0x23 0 --get_fuse_names fuse_t234.xml read_fuse_names.txt
[   0.6041 ] MagicId=0x45535546 version=0x2
[   0.6046 ] trying to read fuse with MB2 Applet
[   0.6053 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PublicKeyHash read_fuse.bin
[   0.6067 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.6073 ] MB2 Applet version 01.00.0000
[   0.6102 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.6163 ] Fuse read successful
[   0.6177 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash1 read_fuse.bin
[   0.6192 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.6197 ] MB2 Applet version 01.00.0000
[   0.6226 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.6287 ] Fuse read successful
[   0.6301 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash2 read_fuse.bin
[   0.6323 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.6330 ] MB2 Applet version 01.00.0000
[   0.6358 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.6420 ] Fuse read successful
[   0.6431 ] tegraparser_v2 --chip 0x23 0 --read_fusetype BootSecurityInfo read_fuse.bin
[   0.6445 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.6451 ] MB2 Applet version 01.00.0000
[   0.6482 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.6540 ] Fuse read successful
[   0.6553 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ArmJtagDisable read_fuse.bin
[   0.6567 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.6574 ] MB2 Applet version 01.00.0000
[   0.6604 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.6663 ] Fuse read successful
[   0.6678 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SecurityMode read_fuse.bin
[   0.6692 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.6697 ] MB2 Applet version 01.00.0000
[   0.6726 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.6786 ] Fuse read successful
[   0.6803 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SwReserved read_fuse.bin
[   0.6815 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.6820 ] MB2 Applet version 01.00.0000
[   0.6847 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.6908 ] Fuse read successful
[   0.6921 ] tegraparser_v2 --chip 0x23 0 --read_fusetype DebugAuthentication read_fuse.bin
[   0.6938 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.6947 ] MB2 Applet version 01.00.0000
[   0.6975 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.7035 ] Fuse read successful
[   0.7047 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmInfo read_fuse.bin
[   0.7060 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.7065 ] MB2 Applet version 01.00.0000
[   0.7092 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.7151 ] Fuse read successful
[   0.7164 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmId read_fuse.bin
[   0.7177 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.7181 ] MB2 Applet version 01.00.0000
[   0.7208 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.7268 ] Fuse read successful
[   0.7281 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmLock read_fuse.bin
[   0.7293 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.7298 ] MB2 Applet version 01.00.0000
[   0.7325 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.7386 ] Fuse read successful
[   0.7397 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm0 read_fuse.bin
[   0.7411 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.7415 ] MB2 Applet version 01.00.0000
[   0.7443 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.7502 ] Fuse read successful
[   0.7514 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm1 read_fuse.bin
[   0.7527 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.7537 ] MB2 Applet version 01.00.0000
[   0.7566 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.7627 ] Fuse read successful
[   0.7640 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm2 read_fuse.bin
[   0.7657 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.7662 ] MB2 Applet version 01.00.0000
[   0.7689 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.7749 ] Fuse read successful
[   0.7761 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm3 read_fuse.bin
[   0.7773 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.7778 ] MB2 Applet version 01.00.0000
[   0.7806 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.7869 ] Fuse read successful
[   0.7881 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm4 read_fuse.bin
[   0.7895 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.7901 ] MB2 Applet version 01.00.0000
[   0.7930 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.7993 ] Fuse read successful
[   0.8005 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm5 read_fuse.bin
[   0.8021 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.8026 ] MB2 Applet version 01.00.0000
[   0.8054 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.8114 ] Fuse read successful
[   0.8125 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm6 read_fuse.bin
[   0.8137 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.8142 ] MB2 Applet version 01.00.0000
[   0.8170 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.8230 ] Fuse read successful
[   0.8242 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm7 read_fuse.bin
[   0.8255 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.8259 ] MB2 Applet version 01.00.0000
[   0.8286 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.8349 ] Fuse read successful
[   0.8359 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Sku read_fuse.bin
[   0.8372 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.8377 ] MB2 Applet version 01.00.0000
[   0.8404 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.8463 ] Fuse read successful
[   0.8476 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Uid read_fuse.bin
[   0.8500 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.8507 ] MB2 Applet version 01.00.0000
[   0.8537 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.8596 ] Fuse read successful
[   0.8609 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OptEmcDisable read_fuse.bin
[   0.8623 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.8627 ] MB2 Applet version 01.00.0000
[   0.8657 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.8716 ] Fuse read successful
[   0.8729 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.8733 ] MB2 Applet version 01.00.0000
[   0.8764 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.8769 ] MB2 Applet version 01.00.0000
[   0.8816 ] Retrieving board information
[   0.8823 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   0.8830 ] MB2 Applet version 01.00.0000
[   0.8857 ] Saved platform info in chip_info.bin
[   0.8915 ] Chip minor revision: 1
[   0.8917 ] Bootrom revision: 0x7
[   0.8919 ] Ram code: 0x2
[   0.8920 ] Chip sku: 0xd5
[   0.8922 ] Chip Sample: prod
[   0.8922 ]
[   0.8925 ] Retrieving EEPROM data
[   0.8925 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   0.8930 ] MB2 Applet version 01.00.0000
[   0.8956 ] Saved platform info in /home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/cvm.bin
[   0.9292 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.9297 ] MB2 Applet version 01.00.0000
[   0.9333 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.9341 ] MB2 Applet version 01.00.0000
[   0.9367 ] Dumping customer Info
[   0.9374 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[   0.9380 ] MB2 Applet version 01.00.0000
[   0.9405 ] Saved bct in tmp.bct
[   0.9610 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/custinfo_out.bin
[   0.9615 ] Cu[   0.9620 ] stomer data saved in /home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[   0.9621 ] Rebooting to recovery mode
[   0.9626 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[   0.9661 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.9666 ] MB2 Applet version 01.00.0000
[   0.9691 ] Booting to recovery mode
[   0.9696 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[   0.9701 ] MB2 Applet version 01.00.0000
Board ID(3767) version(300) sku(0005) revision(K.2)
Preset RAMCODE is 2
Chip SKU(00:00:00:D5) ramcode(2) fuselevel(fuselevel_production) board_FAB(300)
emc_opt_disable_fuse:(0)
Copy /home/ubuntu/jetlin_364_2/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb to /home/ubuntu/jetlin_364_2/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb.rec
Generated UUID ace37333-3541-4440-82e3-3c6b7bce5ccc for mounting root APP partition.
copying bctfile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0001-sdram-l4t.dts)... done.
copying minratchet_config(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)... done.
copying pinmux_config(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi)... done.
copying gpioint_config(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)... done.
copying pmic_config(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)... done.
copying pmc_config(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi)... done.
copying deviceprod_config(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)... done.
copying prod_config(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)... done.
copying scr_config(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)... done.
copying wb0sdram(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0001-wb0sdram-l4t.dts)... done.
copying bootrom_config(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)... done.
Existing uphylane_config(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-p3767-0000-l4t.dts)... done.
copying dev_params_b(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)... done.
copying mb2bct_cfg(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)... done.
Existing pscfwfile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing tscfwfile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/tsec_t234.bin) reused.
Existing mb2applet(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/ramdisk_tmp /home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader /home/ubuntu/jetlin_364_2/Linux_for_Tegra
85163 blocks
gzip: /home/ubuntu/jetlin_364_2/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.15.148-tegra
108695 blocks
Making Recovery image...
copying recdtbfile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000266087 s, 75.2 kB/s
Existing sosfile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing pvafile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/nvpva_020.fw) reused.
Existing dcefile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/bpmp_t234-TE950M-A1_prod.bin) reused.
copying bpfdtbfile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/tegra234-bpmp-3767-0003-3509-a02.dtb)... done.
Existing camerafw(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb)... done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Not signing of kernel-dtb
Existing tbcfile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.415421 s, 162 MB/s
	Sync'ing esp.img ... done.
copying tbcdtbfile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb)... done.
copying cfgfile(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/generic/cfg/flash_t234_qspi.xml) to flash.xml... done.
Existing flashapp(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/kernel/dtb/tegra234-carveouts.dtbo)... done.
copying overlay_dtb(/home/ubuntu/jetlin_364_2/Linux_for_Tegra/kernel/dtb/tegra-optee.dtbo)... done.
/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py  --bl uefi_jetson_with_dtb.bin  --odmdata gbe-uphy-config-8,hsstp-lane-map-3,hsio-uphy-config-0  --overlay_dtb L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,  --bldtb tegra234-p3768-0000+p3767-0005-nv.dtb --applet mb1_t234_prod.bin --cmd "flash; reboot"  --cfg flash.xml --chip "0x23" --concat_cpubl_bldtb --cpubl uefi_jetson.bin --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0001-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts  --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; tsec_fw tsec_t234.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; pva_fw nvpva_020.fw; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE950M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02.dtb; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img"  --sdram_config tegra234-p3767-0001-sdram-l4t.dts  --cust_info custinfo_out.bin  --bct_backup  --boot_chain A  --ramcode 2
saving flash command in /home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/ubuntu/jetlin_364_2/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[   0.0321 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0323 ] Assuming zero filled SBK key
[   0.0315 ] Parsing partition layout
[   0.0321 ] tegraparser_v2 --pt flash.xml.tmp
[   0.0375 ] Change tegra234-bpmp-3767-0003-3509-a02.dtb to tegra234-bpmp-3767-0003-3509-a02_with_odm.dtb
[   0.0376 ] Change tegra234-bpmp-3767-0003-3509-a02.dtb to tegra234-bpmp-3767-0003-3509-a02_with_odm.dtb
[   0.0970 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3767-0003-3509-a02_with_odm.dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_tmp.dtb
[   0.4617 ] Concatenating L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo to tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb.updated
[   0.4620 ] Concatenating bl dtb to cpubl binary
[   0.4651 ] MB2 binary: mb2_t234.bin
[   0.4652 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3767-0000.dts
[   0.4943 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3767-0000.dts
[   1.1809 ] Generating coldboot mb2-bct
[   1.1809 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[   1.1813 ] ERROR: value 0x31 is out of range
[   1.1827 ] ERROR: value 0x31 is out of range
[   1.1829 ] ERROR: value 0x31 is out of range
[   1.1832 ] ERROR: value 0x31 is out of range
[   1.1835 ] WARNING: unknown property 'tfc_version'
[   1.1838 ] WARNING: unknown property 'addr_header_version'
[   1.1993 ] Updating mb2-bct with storage information
[   1.1999 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   1.2011 ] Concatenating mb2-bct to mb2 binary
[   1.2011 ] mb2_bin_file = mb2_t234.bin
[   1.2011 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[   1.2048 ] DCE binary: display-t234-dce.bin
[   1.2049 ] Kernel DTB used: tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb.updated
[   1.2049 ] Concatenating kernel-dtb to dce-fw binary
[   1.2050 ] dce_bin = display-t234-dce.bin
[   1.2050 ] kernel_dtb = tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb.updated
[   1.2050 ] dce_with_dtb = display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb.bin
[   1.2154 ] Update display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb.bin to dce_fw partitions
[   1.2188 ] Parsing partition layout
[   1.2194 ] tegraparser_v2 --pt flash.xml.tmp
[   1.2207 ] Creating list of images to be signed
[   1.2213 ] Generating ratchet blob
[   1.2213 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
[   1.2334 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   1.2482 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
[   1.2616 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3767-0000.dts
[   1.2738 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   1.2934 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi
[   1.3195 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi
[   1.3327 ] Pre-processing config: tegra234-mb1-bct-pmic-p3767-0000-a02.dts
[   1.3473 ] Pre-processing config: tegra234-mb1-bct-prod-p3767-0000.dts
[   1.3573 ] Pre-processing config: tegra234-p3767-0001-sdram-l4t.dts
[   2.9082 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[   2.9191 ] Pre-processing config: tegra234-p3767-0001-wb0sdram-l4t.dts
[   4.4687 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[   4.4791 ] Generating coldboot mb1-bct
[   4.4796 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   4.4802 ] MB1-BCT version: 0.13
[   4.4826 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   4.4831 ] Added Platform Config 0 data with size :- 2416
[   4.4859 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   4.4866 ] WARNING: unknown node 'g2'
[   4.4871 ] WARNING: unknown node 'g2'
[   4.4876 ] WARNING: unknown node 'g9'
[   4.4877 ] WARNING: unknown node 'g9'
[   4.4877 ] Added Platform Config 2 data with size :- 24
[   4.4877 ]
[   4.4877 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   4.4877 ] Added Platform Config 4 data with size :- 288
[   4.4877 ]
[   4.4877 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   4.4877 ] Added Platform Config 3 data with size :- 52
[   4.4877 ]
[   4.4877 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   4.4877 ] WARNING: unknown property 'major'
[   4.4877 ] WARNING: unknown property 'minor'
[   4.4877 ] Added Platform Config 5 data with size :- 512
[   4.4878 ]
[   4.4878 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   4.4878 ] WARNING: unknown property 'major'
[   4.4878 ] WARNING: unknown property 'minor'
[   4.4878 ] Added Platform Config 7 data with size :- 380
[   4.4878 ]
[   4.4878 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   4.4878 ] Added Platform Config 8 data with size :- 24
[   4.4878 ]
[   4.4878 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   4.4878 ] Added Platform Config 9 data with size :- 100
[   4.4878 ]
[   4.4878 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   4.4879 ] ModuleCount 0 NumProdNames 0
[   4.4879 ] Added Platform Config 6 data with size :- 16
[   4.4879 ]
[   4.4879 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   4.4879 ]
[   4.4879 ] Updating mb1-bct with firmware information
[   4.4884 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   4.4908 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   4.4915 ] Generating SHA2 Hash for mb1bct
[   4.4938 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   4.4953 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   4.4952 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   4.4957 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   4.4987 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   4.4991 ] Assuming zero filled SBK key
[   4.5016 ] Warning: pub_key.key is not found
[   4.5016 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   4.5034 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   4.5042 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   4.5058 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   4.5063 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   4.5127 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   4.5132 ] Header already present for tsec_t234_aligned.bin
[   4.5159 ] Header already present for nvdec_t234_prod_aligned.fw
[   4.5201 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   4.5278 ] adding BCH for xusb_t234_prod_aligned.bin
[   4.5470 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[   4.5561 ] adding BCH for tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[   4.5794 ] Header already present for pscfw_t234_prod_aligned.bin
[   4.5878 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   4.5947 ] Header already present for sc7_t234_prod.bin
[   4.5992 ] Header already present for psc_rf_t234_prod_aligned.bin
[   4.6038 ] adding BCH for mb2rf_t234_aligned.bin
[   4.6065 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   4.6901 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 91%
[   4.6979 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   4.7863 ] adding BCH for tos-optee_t234_aligned.img
[   4.8718 ] adding BCH for eks_t234_aligned.img
[   4.9582 ] INFO: compressing display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_aligned.bin
[   5.2367 ] INFO: complete compression, display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_aligned.bin, ratio = 6%
[   5.2663 ] adding BCH for display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_aligned_blob_w_bin_aligned.bin
[   5.2927 ] adding BCH for spe_t234_aligned.bin
[   5.3104 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   5.3219 ] adding BCH for adsp-fw_aligned.bin
[   5.3436 ] INFO: compressing nvpva_020_aligned.fw
[   5.4068 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[   5.4108 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[   5.4135 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   5.4159 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   5.4165 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   5.4234 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   5.4240 ] Header already present for tsec_t234_aligned.bin
[   5.4270 ] Header already present for nvdec_t234_prod_aligned.fw
[   5.4313 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   5.4423 ] adding BCH for xusb_t234_prod_aligned.bin
[   5.4623 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[   5.4752 ] adding BCH for tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[   5.4963 ] Header already present for pscfw_t234_prod_aligned.bin
[   5.5056 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   5.5124 ] Header already present for sc7_t234_prod.bin
[   5.5163 ] Header already present for psc_rf_t234_prod_aligned.bin
[   5.5205 ] adding BCH for mb2rf_t234_aligned.bin
[   5.5241 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   5.6105 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 91%
[   5.6183 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   5.7001 ] adding BCH for tos-optee_t234_aligned.img
[   5.7781 ] adding BCH for eks_t234_aligned.img
[   5.8550 ] INFO: compressing display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_aligned.bin
[   6.1176 ] INFO: complete compression, display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_aligned.bin, ratio = 6%
[   6.1452 ] adding BCH for display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_aligned_blob_w_bin_aligned.bin
[   6.1712 ] adding BCH for spe_t234_aligned.bin
[   6.1907 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   6.2025 ] adding BCH for adsp-fw_aligned.bin
[   6.2232 ] INFO: compressing nvpva_020_aligned.fw
[   6.2879 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[   6.2920 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[   6.2963 ] Filling MB1 storage info
[   6.2964 ] Parsing dev params for multi chains
[   6.3077 ] Generating br-bct
[   6.3083 ] Updating dev and MSS params in BR BCT
[   6.3083 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   6.4527 ] Updating bl info
[   6.4534 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   6.4644 ] Generating br-bct
[   6.4652 ] Updating dev and MSS params in BR BCT
[   6.4652 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   6.6085 ] Updating bl info
[   6.6092 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   6.6107 ] Generating BCT backup image
[   6.6108 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   6.6114 ] 32768+0 records in
[   6.6691 ] 32768+0 records out
[   6.6691 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0569105 s, 576 kB/s
[   6.6691 ]
[   6.6691 ] Concatenating BCT for chain A to bct_backup.img
[   6.6692 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   6.6697 ] 8192+0 records in
[   6.6852 ] 8192+0 records out
[   6.6853 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0148421 s, 552 kB/s
[   6.6853 ]
[   6.6853 ] Concatenating BCT for chain B to bct_backup.img
[   6.6853 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   6.6862 ] 8192+0 records in
[   6.7044 ] 8192+0 records out
[   6.7044 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0172935 s, 474 kB/s
[   6.7045 ]
[   6.7045 ] Generating signatures
[   6.7055 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.7057 ] Assuming zero filled SBK key
[   6.8230 ] Warning: pub_key.key is not found
[   6.8252 ] Parsing dev params for multi chains
[   6.8253 ] Generating br-bct
[   6.8258 ] Updating dev and MSS params in BR BCT
[   6.8259 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   6.9678 ] Updating customer data section
[   6.9684 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   6.9694 ] Updating bl info
[   6.9699 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   6.9721 ] Generating SHA2 Hash
[   6.9743 ] Sha saved in br_bct_BR.sha
[   6.9736 ] Get Signed section of bct
[   6.9741 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   6.9750 ] Signing BCT
[   6.9760 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.9763 ] Assuming zero filled SBK key
[   6.9791 ] Sha saved in br_bct_BR.sha
[   6.9796 ] Warning: pub_key.key is not found
[   6.9786 ] Updating BCT with signature
[   6.9793 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   6.9801 ] Offset :4608 Len :3584
[   6.9808 ] Generating SHA2 Hash
[   6.9819 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   6.9820 ] Assuming zero filled SBK key
[   6.9821 ] Assuming zero filled SBK key
[   6.9847 ] Sha saved in br_bct_BR.sha
[   6.9841 ] Updating BCT with SHA2 Hash
[   6.9847 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   6.9852 ] Offset :4608 Len :3584
[   6.9857 ] Offset :68 Len :8124
[   6.9860 ] Generating br-bct
[   6.9865 ] Updating dev and MSS params in BR BCT
[   6.9866 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   7.1280 ] Updating customer data section
[   7.1286 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   7.1295 ] Updating bl info
[   7.1300 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   7.1322 ] Generating SHA2 Hash
[   7.1345 ] Sha saved in br_bct_BR.sha
[   7.1337 ] Get Signed section of bct
[   7.1343 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   7.1352 ] Signing BCT
[   7.1362 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.1364 ] Assuming zero filled SBK key
[   7.1393 ] Sha saved in br_bct_BR.sha
[   7.1399 ] Warning: pub_key.key is not found
[   7.1389 ] Updating BCT with signature
[   7.1396 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   7.1403 ] Offset :4608 Len :3584
[   7.1411 ] Generating SHA2 Hash
[   7.1421 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   7.1422 ] Assuming zero filled SBK key
[   7.1423 ] Assuming zero filled SBK key
[   7.1449 ] Sha saved in br_bct_BR.sha
[   7.1443 ] Updating BCT with SHA2 Hash
[   7.1448 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   7.1453 ] Offset :4608 Len :3584
[   7.1459 ] Offset :68 Len :8124
[   7.1463 ] Generating BCT backup image
[   7.1463 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   7.1468 ] 32768+0 records in
[   7.2050 ] 32768+0 records out
[   7.2050 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0574325 s, 571 kB/s
[   7.2050 ]
[   7.2051 ] Concatenating BCT for chain A to bct_backup.img
[   7.2051 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   7.2056 ] 8192+0 records in
[   7.2206 ] 8192+0 records out
[   7.2206 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0142574 s, 575 kB/s
[   7.2206 ]
[   7.2207 ] Concatenating BCT for chain B to bct_backup.img
[   7.2207 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   7.2215 ] 8192+0 records in
[   7.2393 ] 8192+0 records out
[   7.2393 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0169495 s, 483 kB/s
[   7.2393 ]
[   7.2393 ] Generating coldboot mb1-bct
[   7.2398 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   7.2403 ] MB1-BCT version: 0.13
[   7.2425 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   7.2430 ] Added Platform Config 0 data with size :- 2416
[   7.2456 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   7.2461 ] WARNING: unknown node 'g2'
[   7.2463 ] WARNING: unknown node 'g2'
[   7.2464 ] WARNING: unknown node 'g9'
[   7.2466 ] WARNING: unknown node 'g9'
[   7.2467 ] Added Platform Config 2 data with size :- 24
[   7.2467 ]
[   7.2467 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   7.2467 ] Added Platform Config 4 data with size :- 288
[   7.2467 ]
[   7.2468 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   7.2468 ] Added Platform Config 3 data with size :- 52
[   7.2468 ]
[   7.2468 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   7.2468 ] WARNING: unknown property 'major'
[   7.2468 ] WARNING: unknown property 'minor'
[   7.2468 ] Added Platform Config 5 data with size :- 512
[   7.2468 ]
[   7.2468 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   7.2468 ] Added Platform Config 7 data with size :- 380
[   7.2469 ]
[   7.2469 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   7.2469 ] Added Platform Config 8 data with size :- 24
[   7.2469 ]
[   7.2469 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   7.2469 ] Added Platform Config 9 data with size :- 100
[   7.2469 ]
[   7.2469 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   7.2469 ] ModuleCount 0 NumProdNames 0
[   7.2469 ] Added Platform Config 6 data with size :- 16
[   7.2469 ]
[   7.2469 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   7.2470 ]
[   7.2470 ] Updating mb1-bct with firmware information
[   7.2475 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   7.2490 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   7.2496 ] Generating SHA2 Hash for mb1bct
[   7.2519 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   7.2534 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   7.2531 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   7.2536 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   7.2566 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.2569 ] Assuming zero filled SBK key
[   7.2594 ] Warning: pub_key.key is not found
[   7.2592 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   7.2606 ] Generating recovery mb1-bct
[   7.2613 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   7.2619 ] MB1-BCT version: 0.13
[   7.2646 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   7.2652 ] Added Platform Config 0 data with size :- 2416
[   7.2693 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   7.2698 ] WARNING: unknown node 'g2'
[   7.2701 ] WARNING: unknown node 'g2'
[   7.2702 ] WARNING: unknown node 'g9'
[   7.2702 ] Added Platform Config 2 data with size :- 24
[   7.2702 ]
[   7.2702 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   7.2702 ] Added Platform Config 4 data with size :- 288
[   7.2702 ]
[   7.2702 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   7.2702 ] Added Platform Config 3 data with size :- 52
[   7.2702 ]
[   7.2702 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   7.2702 ] WARNING: unknown property 'major'
[   7.2702 ] WARNING: unknown property 'minor'
[   7.2702 ] Added Platform Config 5 data with size :- 512
[   7.2703 ]
[   7.2703 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   7.2703 ] WARNING: unknown property 'major'
[   7.2703 ] WARNING: unknown property 'minor'
[   7.2703 ] Added Platform Config 7 data with size :- 380
[   7.2703 ]
[   7.2703 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   7.2703 ] Added Platform Config 8 data with size :- 24
[   7.2703 ]
[   7.2703 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   7.2703 ] Added Platform Config 9 data with size :- 100
[   7.2703 ]
[   7.2703 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   7.2704 ] ModuleCount 0 NumProdNames 0
[   7.2704 ] Added Platform Config 6 data with size :- 16
[   7.2704 ]
[   7.2704 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   7.2704 ]
[   7.2704 ] Updating mb1-bct with firmware information
[   7.2712 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   7.2732 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   7.2739 ] Generating SHA2 Hash for mb1bct
[   7.2761 ] Sha saved in mb1_bct_MB1_aligned.sha
[   7.2774 ] Sha saved in mb1_bct_MB1.sha
[   7.2770 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   7.2775 ] adding BCH for mb1_bct_MB1_aligned.bct
[   7.2798 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.2801 ] Assuming zero filled SBK key
[   7.2817 ] Warning: pub_key.key is not found
[   7.2814 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   7.2827 ] Generating coldboot mem-bct
[   7.2833 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   7.2837 ]  packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[   7.4280 ] Packing sdram param for instance[0]
[   7.4283 ] Packing sdram param for instance[1]
[   7.4285 ] Packing sdram param for instance[2]
[   7.4288 ] Packing sdram param for instance[3]
[   7.4291 ] Packing sdram param for instance[4]
[   7.4293 ] Packing sdram param for instance[5]
[   7.4295 ] Packing sdram param for instance[6]
[   7.4297 ] Packing sdram param for instance[7]
[   7.4300 ] Packing sdram param for instance[8]
[   7.4302 ] Packing sdram param for instance[9]
[   7.4305 ] Packing sdram param for instance[10]
[   7.4308 ] Packing sdram param for instance[11]
[   7.4310 ] Packing sdram param for instance[12]
[   7.4313 ] Packing sdram param for instance[13]
[   7.4316 ] Packing sdram param for instance[14]
[   7.4318 ] Packing sdram param for instance[15]
[   7.5744 ] Getting sector size from pt
[   7.5751 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   7.5759 ] BlockSize read from layout is 0x200
[   7.5765 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   7.5769 ] Binary 0 length is 58752
[   7.5773 ] Binary 0 align length is 58880
[   7.5786 ] Binary 1 length is 58752
[   7.5788 ] Binary 1 align length is 58880
[   7.5800 ] Binary 2 length is 58752
[   7.5802 ] Binary 2 align length is 58880
[   7.5814 ] Binary 3 length is 58752
[   7.5816 ] Binary 3 align length is 58880
[   7.5828 ] Buffer length is 235520
[   7.5830 ] adding BCH for tegra234-p3767-0001-sdram-l4t_cpp_1.bct
[   7.5833 ] new length is 243712
[   7.5845 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[   7.5857 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[   7.5863 ] Header already present for mem_coldboot_aligned.bct
[   7.5886 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.5889 ] Assuming zero filled SBK key
[   7.5910 ] Warning: pub_key.key is not found
[   7.5907 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   7.5927 ] Generating recovery mem-bct
[   7.5933 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   7.5937 ]  packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[   7.7403 ] Packing sdram param for instance[0]
[   7.7406 ] Packing sdram param for instance[1]
[   7.7409 ] Packing sdram param for instance[2]
[   7.7411 ] Packing sdram param for instance[3]
[   7.7412 ] Packing sdram param for instance[4]
[   7.7413 ] Packing sdram param for instance[5]
[   7.7415 ] Packing sdram param for instance[6]
[   7.7416 ] Packing sdram param for instance[7]
[   7.7417 ] Packing sdram param for instance[8]
[   7.7419 ] Packing sdram param for instance[9]
[   7.7421 ] Packing sdram param for instance[10]
[   7.7424 ] Packing sdram param for instance[11]
[   7.7426 ] Packing sdram param for instance[12]
[   7.7429 ] Packing sdram param for instance[13]
[   7.7432 ] Packing sdram param for instance[14]
[   7.7434 ] Packing sdram param for instance[15]
[   7.8881 ] Generating mem_bct based on ramcode group number
[   7.8881 ] Got ramcode 2 from the command line
[   7.8882 ] Using ramcode group number 0
[   7.8882 ] Disabled BPMP dtb trim, using default dtb
[   7.8882 ]
[   7.8890 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[   7.8900 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[   7.8904 ] adding BCH for mem_rcm_aligned.bct
[   7.8945 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.8947 ] Assuming zero filled SBK key
[   7.8964 ] Warning: pub_key.key is not found
[   7.8961 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   7.8976 ] Generating all 4 mem_bct for ramcode group (0..3)
[   7.8976 ] Disabled BPMP dtb trim, using default dtb
[   7.8976 ]
[   7.8985 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_0_aligned.bct
[   7.8996 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_0_aligned.bct zerosbk
[   7.9002 ] adding BCH for mem_rcm_0_aligned.bct
[   7.9045 ] tegrasign_v3.py --key None --list mem_rcm_0_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.9051 ] Assuming zero filled SBK key
[   7.9075 ] Warning: pub_key.key is not found
[   7.9076 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_0_aligned_sigheader.bct.encrypt mem_rcm_0_aligned_sigheader.bct.hash zerosbk
[   7.9090 ] Disabled BPMP dtb trim, using default dtb
[   7.9090 ]
[   7.9101 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_1_aligned.bct
[   7.9113 ] tegrahost_v2 --chip 0x23 0 --magicid MEM1 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_1_aligned.bct zerosbk
[   7.9118 ] adding BCH for mem_rcm_1_aligned.bct
[   7.9162 ] tegrasign_v3.py --key None --list mem_rcm_1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.9165 ] Assuming zero filled SBK key
[   7.9200 ] Warning: pub_key.key is not found
[   7.9199 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_1_aligned_sigheader.bct.encrypt mem_rcm_1_aligned_sigheader.bct.hash zerosbk
[   7.9221 ] Disabled BPMP dtb trim, using default dtb
[   7.9221 ]
[   7.9232 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_2_aligned.bct
[   7.9243 ] tegrahost_v2 --chip 0x23 0 --magicid MEM2 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_2_aligned.bct zerosbk
[   7.9248 ] adding BCH for mem_rcm_2_aligned.bct
[   7.9291 ] tegrasign_v3.py --key None --list mem_rcm_2_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.9293 ] Assuming zero filled SBK key
[   7.9311 ] Warning: pub_key.key is not found
[   7.9308 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_2_aligned_sigheader.bct.encrypt mem_rcm_2_aligned_sigheader.bct.hash zerosbk
[   7.9324 ] Disabled BPMP dtb trim, using default dtb
[   7.9324 ]
[   7.9333 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_3_aligned.bct
[   7.9344 ] tegrahost_v2 --chip 0x23 0 --magicid MEM3 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_3_aligned.bct zerosbk
[   7.9349 ] adding BCH for mem_rcm_3_aligned.bct
[   7.9394 ] tegrasign_v3.py --key None --list mem_rcm_3_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.9397 ] Assuming zero filled SBK key
[   7.9422 ] Warning: pub_key.key is not found
[   7.9420 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_3_aligned_sigheader.bct.encrypt mem_rcm_3_aligned_sigheader.bct.hash zerosbk
[   7.9437 ] Copying signatures
[   7.9444 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   8.0173 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   8.0181 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   8.0181 ] Boot Rom communication
[   8.0187 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   8.0192 ] BR_CID: 0x80012344705DD5047C00000013008240
[   8.1301 ] Sending bct_br
[   8.1304 ] Sending mb1
[   8.1318 ] Sending psc_bl1
[   8.1422 ] Sending bct_mb1
[   8.1476 ] Boot Rom communication completed
[   8.1477 ] Generating blob for T23x
[   8.1573 ] tegrahost_v2 --chip 0x23 0 --align blob_uefi_jetson_with_dtb_aligned.bin
[   8.1601 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_uefi_jetson_with_dtb_aligned.bin zerosbk
[   8.1611 ] adding BCH for blob_uefi_jetson_with_dtb_aligned.bin
[   8.3101 ] tegrasign_v3.py --key None --list blob_uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.3103 ] Assuming zero filled SBK key
[   8.3204 ] Warning: pub_key.key is not found
[   8.3204 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt blob_uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[   8.3340 ] Get magic id
[   8.3347 ] tegraparser_v2 --get_magic psc_fw
[   8.3357 ] PFWP
[   8.3357 ]
[   8.3357 ] partition type psc_fw, magic id = PFWP
[   8.3370 ] tegrahost_v2 --chip 0x23 0 --align blob_pscfw_t234_prod_aligned.bin
[   8.3399 ] tegrahost_v2 --chip 0x23 0 --magicid PFWP --ratchet_blob ratchet_blob.bin --appendsigheader blob_pscfw_t234_prod_aligned.bin zerosbk
[   8.3405 ] Header already present for blob_pscfw_t234_prod_aligned.bin
[   8.3494 ] tegrasign_v3.py --key None --list blob_pscfw_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.3497 ] Assuming zero filled SBK key
[   8.3520 ] Warning: pub_key.key is not found
[   8.3518 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_pscfw_t234_prod_aligned_sigheader.bin.encrypt blob_pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[   8.3547 ] Get magic id
[   8.3555 ] tegraparser_v2 --get_magic mts_mce
[   8.3562 ] MTSM
[   8.3565 ] partition type mts_mce, magic id = MTSM
[   8.3576 ] tegrahost_v2 --chip 0x23 0 --align blob_mce_flash_o10_cr_prod_aligned.bin
[   8.3587 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --ratchet_blob ratchet_blob.bin --appendsigheader blob_mce_flash_o10_cr_prod_aligned.bin zerosbk
[   8.3592 ] Header already present for blob_mce_flash_o10_cr_prod_aligned.bin
[   8.3649 ] tegrasign_v3.py --key None --list blob_mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.3651 ] Assuming zero filled SBK key
[   8.3671 ] Warning: pub_key.key is not found
[   8.3668 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[   8.3694 ] Get magic id
[   8.3711 ] tegraparser_v2 --get_magic tsec_fw
[   8.3719 ] TSEC
[   8.3721 ] partition type tsec_fw, magic id = TSEC
[   8.3733 ] tegrahost_v2 --chip 0x23 0 --align blob_tsec_t234_aligned.bin
[   8.3750 ] tegrahost_v2 --chip 0x23 0 --magicid TSEC --ratchet_blob ratchet_blob.bin --appendsigheader blob_tsec_t234_aligned.bin zerosbk
[   8.3758 ] Header already present for blob_tsec_t234_aligned.bin
[   8.3815 ] tegrasign_v3.py --key None --list blob_tsec_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.3817 ] Assuming zero filled SBK key
[   8.3837 ] Warning: pub_key.key is not found
[   8.3835 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tsec_t234_aligned_sigheader.bin.encrypt blob_tsec_t234_aligned_sigheader.bin.hash zerosbk
[   8.3853 ] Get magic id
[   8.3859 ] tegraparser_v2 --get_magic mb2_applet
[   8.3863 ] MB2A
[   8.3865 ] partition type mb2_applet, magic id = MB2A
[   8.3874 ] tegrahost_v2 --chip 0x23 0 --align blob_applet_t234_aligned.bin
[   8.3884 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader blob_applet_t234_aligned.bin zerosbk
[   8.3889 ] adding BCH for blob_applet_t234_aligned.bin
[   8.4026 ] tegrasign_v3.py --key None --list blob_applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.4033 ] Assuming zero filled SBK key
[   8.4064 ] Warning: pub_key.key is not found
[   8.4066 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_applet_t234_aligned_sigheader.bin.encrypt blob_applet_t234_aligned_sigheader.bin.hash zerosbk
[   8.4100 ] Generating recovery mb2-bct
[   8.4100 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[   8.4105 ] ERROR: value 0x31 is out of range
[   8.4120 ] ERROR: value 0x31 is out of range
[   8.4123 ] ERROR: value 0x31 is out of range
[   8.4126 ] ERROR: value 0x31 is out of range
[   8.4129 ] WARNING: unknown property 'tfc_version'
[   8.4132 ] WARNING: unknown property 'addr_header_version'
[   8.4263 ] Updating mb2-bct with storage information
[   8.4269 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   8.4280 ] Concatenating mb2-bct to mb2 binary
[   8.4281 ] mb2_bin_file = mb2_t234.bin
[   8.4281 ] mb2_bct_file = mb2_bct_MB2.bct
[   8.4287 ] Get magic id
[   8.4293 ] tegraparser_v2 --get_magic mb2_bootloader
[   8.4297 ] MB2B
[   8.4300 ] partition type mb2_bootloader, magic id = MB2B
[   8.4312 ] tegrahost_v2 --chip 0x23 0 --align blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[   8.4339 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[   8.4350 ] adding BCH for blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[   8.4573 ] tegrasign_v3.py --key None --list blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.4577 ] Assuming zero filled SBK key
[   8.4608 ] Warning: pub_key.key is not found
[   8.4606 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[   8.4632 ] Get magic id
[   8.4648 ] tegraparser_v2 --get_magic xusb_fw
[   8.4666 ] XUSB
[   8.4666 ]
[   8.4667 ] partition type xusb_fw, magic id = XUSB
[   8.4690 ] tegrahost_v2 --chip 0x23 0 --align blob_xusb_t234_prod_aligned.bin
[   8.4718 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_xusb_t234_prod_aligned.bin zerosbk
[   8.4727 ] adding BCH for blob_xusb_t234_prod_aligned.bin
[   8.4810 ] tegrasign_v3.py --key None --list blob_xusb_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.4812 ] Assuming zero filled SBK key
[   8.4832 ] Warning: pub_key.key is not found
[   8.4831 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_xusb_t234_prod_aligned_sigheader.bin.encrypt blob_xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[   8.4853 ] Get magic id
[   8.4864 ] tegraparser_v2 --get_magic pva_fw
[   8.4875 ] PVAF
[   8.4878 ] partition type pva_fw, magic id = PVAF
[   8.4909 ] tegrahost_v2 --chip 0x23 0 --align blob_nvpva_020_aligned.fw
[   8.4920 ] tegrahost_v2 --chip 0x23 0 --magicid PVAF --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvpva_020_aligned.fw zerosbk
[   8.4925 ] adding BCH for blob_nvpva_020_aligned.fw
[   8.5848 ] tegrasign_v3.py --key None --list blob_nvpva_020_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.5850 ] Assuming zero filled SBK key
[   8.5901 ] Warning: pub_key.key is not found
[   8.5898 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_nvpva_020_aligned_sigheader.fw.encrypt blob_nvpva_020_aligned_sigheader.fw.hash zerosbk
[   8.5963 ] Kernel DTB used: tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb.updated
[   8.5964 ] Concatenating kernel-dtb to dce-fw binary
[   8.5964 ] dce_bin = display-t234-dce.bin
[   8.5965 ] kernel_dtb = tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb.updated
[   8.5965 ] dce_with_dtb = display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb.bin
[   8.6310 ] Get magic id
[   8.6320 ] tegraparser_v2 --get_magic dce_fw
[   8.6326 ] DCEF
[   8.6330 ] partition type dce_fw, magic id = DCEF
[   8.6407 ] tegrahost_v2 --chip 0x23 0 --align blob_display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_aligned.bin
[   8.6417 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_aligned.bin zerosbk
[   8.6422 ] adding BCH for blob_display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_aligned.bin
[   9.1247 ] tegrasign_v3.py --key None --list blob_display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   9.1249 ] Assuming zero filled SBK key
[   9.1682 ] Warning: pub_key.key is not found
[   9.1688 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_aligned_sigheader.bin.encrypt blob_display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_aligned_sigheader.bin.hash zerosbk
[   9.2210 ] Get magic id
[   9.2215 ] tegraparser_v2 --get_magic nvdec
[   9.2220 ] NDEC
[   9.2222 ] partition type nvdec, magic id = NDEC
[   9.2231 ] tegrahost_v2 --chip 0x23 0 --align blob_nvdec_t234_prod_aligned.fw
[   9.2241 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvdec_t234_prod_aligned.fw zerosbk
[   9.2245 ] Header already present for blob_nvdec_t234_prod_aligned.fw
[   9.2337 ] tegrasign_v3.py --key None --list blob_nvdec_t234_prod_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[   9.2339 ] Assuming zero filled SBK key
[   9.2372 ] Warning: pub_key.key is not found
[   9.2372 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_nvdec_t234_prod_aligned_sigheader.fw.encrypt blob_nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[   9.2400 ] Get magic id
[   9.2406 ] tegraparser_v2 --get_magic bpmp_fw
[   9.2412 ] BPMF
[   9.2414 ] partition type bpmp_fw, magic id = BPMF
[   9.2430 ] tegrahost_v2 --chip 0x23 0 --align blob_bpmp_t234-TE950M-A1_prod_aligned.bin
[   9.2443 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp_t234-TE950M-A1_prod_aligned.bin zerosbk
[   9.2448 ] Header already present for blob_bpmp_t234-TE950M-A1_prod_aligned.bin
[   9.2699 ] tegrasign_v3.py --key None --list blob_bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   9.2702 ] Assuming zero filled SBK key
[   9.2741 ] Warning: pub_key.key is not found
[   9.2738 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin.encrypt blob_bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin.hash zerosbk
[   9.2775 ] Using bpmp-dtb concatenated with odmdata in blob
[   9.2776 ] Get magic id
[   9.2782 ] tegraparser_v2 --get_magic bpmp_fw_dtb
[   9.2787 ] BPMD
[   9.2790 ] partition type bpmp_fw_dtb, magic id = BPMD
[   9.2800 ] tegrahost_v2 --chip 0x23 0 --align blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[   9.2818 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb zerosbk
[   9.2834 ] adding BCH for blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[   9.2949 ] tegrasign_v3.py --key None --list blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key --sha sha512
[   9.2952 ] Assuming zero filled SBK key
[   9.2973 ] Warning: pub_key.key is not found
[   9.2970 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned_sigheader.dtb.encrypt blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned_sigheader.dtb.hash zerosbk
[   9.2988 ] Get magic id
[   9.2995 ] tegraparser_v2 --get_magic rce_fw
[   9.3000 ] RCEF
[   9.3002 ] partition type rce_fw, magic id = RCEF
[   9.3016 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-t234-rce_aligned.img
[   9.3039 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_camera-rtcpu-t234-rce_aligned.img zerosbk
[   9.3045 ] adding BCH for blob_camera-rtcpu-t234-rce_aligned.img
[   9.3284 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   9.3286 ] Assuming zero filled SBK key
[   9.3309 ] Warning: pub_key.key is not found
[   9.3307 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt blob_camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[   9.3330 ] Get magic id
[   9.3336 ] tegraparser_v2 --get_magic ape_fw
[   9.3341 ] APEF
[   9.3343 ] partition type ape_fw, magic id = APEF
[   9.3362 ] tegrahost_v2 --chip 0x23 0 --align blob_adsp-fw_aligned.bin
[   9.3379 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_adsp-fw_aligned.bin zerosbk
[   9.3385 ] adding BCH for blob_adsp-fw_aligned.bin
[   9.3621 ] tegrasign_v3.py --key None --list blob_adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   9.3623 ] Assuming zero filled SBK key
[   9.3647 ] Warning: pub_key.key is not found
[   9.3645 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_adsp-fw_aligned_sigheader.bin.encrypt blob_adsp-fw_aligned_sigheader.bin.hash zerosbk
[   9.3670 ] Get magic id
[   9.3676 ] tegraparser_v2 --get_magic spe_fw
[   9.3681 ] SPEF
[   9.3683 ] partition type spe_fw, magic id = SPEF
[   9.3692 ] tegrahost_v2 --chip 0x23 0 --align blob_spe_t234_aligned.bin
[   9.3703 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t234_aligned.bin zerosbk
[   9.3707 ] adding BCH for blob_spe_t234_aligned.bin
[   9.3839 ] tegrasign_v3.py --key None --list blob_spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   9.3841 ] Assuming zero filled SBK key
[   9.3876 ] Warning: pub_key.key is not found
[   9.3880 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_spe_t234_aligned_sigheader.bin.encrypt blob_spe_t234_aligned_sigheader.bin.hash zerosbk
[   9.3905 ] Get magic id
[   9.3911 ] tegraparser_v2 --get_magic tos
[   9.3917 ] TOSB
[   9.3920 ] partition type tos, magic id = TOSB
[   9.3940 ] tegrahost_v2 --chip 0x23 0 --align blob_tos-optee_t234_aligned.img
[   9.3951 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-optee_t234_aligned.img zerosbk
[   9.3956 ] adding BCH for blob_tos-optee_t234_aligned.img
[   9.4717 ] tegrasign_v3.py --key None --list blob_tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   9.4720 ] Assuming zero filled SBK key
[   9.4773 ] Warning: pub_key.key is not found
[   9.4771 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tos-optee_t234_aligned_sigheader.img.encrypt blob_tos-optee_t234_aligned_sigheader.img.hash zerosbk
[   9.4850 ] Get magic id
[   9.4862 ] tegraparser_v2 --get_magic eks
[   9.4868 ] EKSB
[   9.4871 ] partition type eks, magic id = EKSB
[   9.4883 ] tegrahost_v2 --chip 0x23 0 --align blob_eks_t234_aligned.img
[   9.4897 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_t234_aligned.img zerosbk
[   9.4903 ] adding BCH for blob_eks_t234_aligned.img
[   9.4925 ] tegrasign_v3.py --key None --list blob_eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   9.4927 ] Assuming zero filled SBK key
[   9.4949 ] Warning: pub_key.key is not found
[   9.4947 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_eks_t234_aligned_sigheader.img.encrypt blob_eks_t234_aligned_sigheader.img.hash zerosbk
[   9.4969 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   9.4974 ] The number of images in blob is 17
[   9.4981 ] blobsize is 23988112
[   9.4984 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3612736
[   9.5174 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[   9.5192 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[   9.5201 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[   9.5207 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279808
[   9.5214 ] Not supported type: mb2_applet
[   9.5217 ] Added binary blob_mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt of size 440944
[   9.5225 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[   9.5234 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[   9.5239 ] Added binary blob_display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_sigheader.bin.encrypt of size 12083264
[   9.5383 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   9.5415 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1027008
[   9.5427 ] Added binary blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt of size 204608
[   9.5437 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[   9.5443 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 415232
[   9.5449 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   9.5458 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1887312
[   9.5464 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   9.5627 ] Sending membct and RCM blob
[   9.5637 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   9.5649 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[   9.5658 ] Sending bct_mem
[   9.5659 ] Sending blob
[  10.3706 ] completed
[  10.3707 ] Retrieving storage infomation
[  10.3719 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails storage storage_info.bin
[  10.3724 ] MB2 version 01.00.0000
[  10.4851 ] Saved platform info in storage_info.bin
[  11.4892 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[  11.4923 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[  11.4929 ] MB2 version 01.00.0000
[  11.4948 ] Flashing the device
[  11.4954 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[  11.4960 ] gpt_secondary_3_0.bin:
[  11.4969 ] partition_id	partition_name			      StartingLba	EndingLba
[  11.4976 ]            1	BCT                                 	       0	    2047
[  11.4983 ]            2	A_mb1                               	    2048	    3071
[  11.4991 ]            3	A_psc_bl1                           	    3072	    3583
[  11.4998 ]            4	A_MB1_BCT                           	    3584	    3839
[  11.5006 ]            5	A_MEM_BCT                           	    3840	    4351
[  11.5013 ]            6	A_tsec-fw                           	    4352	    6399
[  11.5021 ]            7	A_nvdec                             	    6400	    8447
[  11.5024 ]            8	A_mb2                               	    8448	    9471
[  11.5025 ]            9	A_xusb-fw                           	    9472	    9983
[  11.5025 ]           10	A_bpmp-fw                           	    9984	   13055
[  11.5025 ]           11	A_bpmp-fw-dtb                       	   13056	   21247
[  11.5025 ]           12	A_psc-fw                            	   21248	   22783
[  11.5025 ]           13	A_mts-mce                           	   22784	   23807
[  11.5025 ]           14	A_sc7                               	   23808	   24191
[  11.5025 ]           15	A_pscrf                             	   24192	   24575
[  11.5025 ]           16	A_mb2rf                             	   24576	   24831
[  11.5025 ]           17	A_cpu-bootloader                    	   24832	   31999
[  11.5026 ]           18	A_secure-os                         	   32000	   40191
[  11.5026 ]           19	A_smm-fw                            	   40192	   44287
[  11.5026 ]           20	A_eks                               	   44288	   44799
[  11.5026 ]           21	A_dce-fw                            	   44800	   55039
[  11.5026 ]           22	A_spe-fw                            	   55040	   56191
[  11.5026 ]           23	A_rce-fw                            	   56192	   58239
[  11.5026 ]           24	A_adsp-fw                           	   58240	   62335
[  11.5026 ]           25	A_pva-fw                            	   62336	   62847
[  11.5026 ]           26	A_reserved_on_boot                  	   62848	   65023
[  11.5026 ]           27	B_mb1                               	   65024	   66047
[  11.5027 ]           28	B_psc_bl1                           	   66048	   66559
[  11.5027 ]           29	B_MB1_BCT                           	   66560	   66815
[  11.5027 ]           30	B_MEM_BCT                           	   66816	   67327
[  11.5027 ]           31	B_tsec-fw                           	   67328	   69375
[  11.5027 ]           32	B_nvdec                             	   69376	   71423
[  11.5027 ]           33	B_mb2                               	   71424	   72447
[  11.5027 ]           34	B_xusb-fw                           	   72448	   72959
[  11.5027 ]           35	B_bpmp-fw                           	   72960	   76031
[  11.5028 ]           36	B_bpmp-fw-dtb                       	   76032	   84223
[  11.5028 ]           37	B_psc-fw                            	   84224	   85759
[  11.5028 ]           38	B_mts-mce                           	   85760	   86783
[  11.5028 ]           39	B_sc7                               	   86784	   87167
[  11.5028 ]           40	B_pscrf                             	   87168	   87551
[  11.5028 ]           41	B_mb2rf                             	   87552	   87807
[  11.5028 ]           42	B_cpu-bootloader                    	   87808	   94975
[  11.5029 ]           43	B_secure-os                         	   94976	  103167
[  11.5029 ]           44	B_smm-fw                            	  103168	  107263
[  11.5029 ]           45	B_eks                               	  107264	  107775
[  11.5029 ]           46	B_dce-fw                            	  107776	  118015
[  11.5029 ]           47	B_spe-fw                            	  118016	  119167
[  11.5029 ]           48	B_rce-fw                            	  119168	  121215
[  11.5029 ]           49	B_adsp-fw                           	  121216	  125311
[  11.5030 ]           50	B_pva-fw                            	  125312	  125823
[  11.5030 ]           51	B_reserved_on_boot                  	  125824	  127999
[  11.5030 ]           52	uefi_variables                      	  128000	  128511
[  11.5030 ]           53	uefi_ftw                            	  128512	  129535
[  11.5030 ]           54	reserved                            	  129536	  129919
[  11.5030 ]           55	worm                                	  129920	  130303
[  11.5030 ]           56	BCT-boot-chain_backup               	  130304	  130431
[  11.5030 ]           57	reserved_partition                  	  130432	  130559
[  11.5030 ]           58	secondary_gpt_backup                	  130560	  130687
[  11.5031 ]           59	B_VER                               	  130688	  130815
[  11.5031 ]           60	A_VER                               	  130816	  130943
[  11.5031 ]
[  11.5031 ] Start flashing
[  11.5041 ] tegradevflash_v2 --pt flash.xml.bin --create
[  11.5046 ] Bootloader version 01.00.0000
[  11.5187 ] Erasing spi: 0 ......... [Done]
[ 211.5055 ] Writing partition secondary_gpt with gpt_secondary_3_0.bin [ 16896 bytes ]
[ 211.5069 ] [................................................] 100%
[ 211.7210 ] Writing partition A_mb1 with mb1_t234_prod_aligned_sigheader.bin.encrypt [ 282768 bytes ]
[ 211.7235 ] [................................................] 100%
[ 211.7341 ] Writing partition A_psc_bl1 with psc_bl1_t234_prod_aligned_sigheader.bin.encrypt [ 123008 bytes ]
[ 215.2565 ] [................................................] 100%
[ 215.2605 ] Writing partition A_tsec-fw with tsec_t234_sigheader.bin.encrypt [ 176128 bytes ]
[ 216.7988 ] [................................................] 100%
[ 216.8043 ] Writing partition A_nvdec with nvdec_t234_prod_sigheader.fw.encrypt [ 294912 bytes ]
[ 218.9957 ] [................................................] 100%
[ 219.0045 ] Writing partition A_mb2 with mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt [ 440944 bytes ]
[ 222.6711 ] [................................................] 100%
[ 222.6867 ] Writing partition A_xusb-fw with xusb_t234_prod_sigheader.bin.encrypt [ 164864 bytes ]
[ 228.1731 ] [................................................] 100%
[ 228.1780 ] Writing partition A_bpmp-fw with bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt [ 1027008 bytes ]
[ 230.2303 ] [................................................] 100%
[ 230.2651 ] Writing partition A_bpmp-fw-dtb with tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt [ 204608 bytes ]
[ 243.0240 ] [................................................] 100%
[ 243.0296 ] Writing partition A_psc-fw with pscfw_t234_prod_sigheader.bin.encrypt [ 310768 bytes ]
[ 245.5804 ] [................................................] 100%
[ 245.5917 ] Writing partition A_mts-mce with mce_flash_o10_cr_prod_sigheader.bin.encrypt [ 187120 bytes ]
[ 249.4570 ] [................................................] 100%
[ 249.4631 ] Writing partition A_sc7 with sc7_t234_prod_sigheader.bin.encrypt [ 186880 bytes ]
[ 251.7953 ] [................................................] 100%
[ 251.8035 ] Writing partition A_pscrf with psc_rf_t234_prod_sigheader.bin.encrypt [ 122464 bytes ]
[ 254.1283 ] [................................................] 100%
[ 254.1320 ] Writing partition A_mb2rf with mb2rf_t234_sigheader.bin.encrypt [ 122720 bytes ]
[ 255.6638 ] [................................................] 100%
[ 255.6682 ] Writing partition A_cpu-bootloader with uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt [ 3327744 bytes ]
[ 257.2014 ] [................................................] 100%
[ 296.3866 ] Writing partition A_secure-os with tos-optee_t234_sigheader.img.encrypt [ 1887312 bytes ]
[ 298.6540 ] [................................................] 100%
[ 311.7497 ] Writing partition A_eks with eks_t234_sigheader.img.encrypt [ 9232 bytes ]
[ 322.1930 ] [................................................] 100%
[ 322.1946 ] Writing partition A_dce-fw with display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_aligned_blob_w_bin_sigheader.bin.encrypt [ 783040 bytes ]
[ 322.3239 ] [................................................] 100%
[ 322.3478 ] Writing partition A_spe-fw with spe_t234_sigheader.bin.encrypt [ 270336 bytes ]
[ 332.0927 ] [................................................] 100%
[ 332.1024 ] Writing partition A_rce-fw with camera-rtcpu-t234-rce_sigheader.img.encrypt [ 458096 bytes ]
[ 335.4671 ] [................................................] 100%
[ 335.4823 ] Writing partition A_adsp-fw with adsp-fw_sigheader.bin.encrypt [ 415232 bytes ]
[ 341.1841 ] [................................................] 100%
[ 341.1973 ] Writing partition A_pva-fw with nvpva_020_aligned_blob_w_bin_sigheader.fw.encrypt [ 67024 bytes ]
[ 346.3631 ] [................................................] 100%
[ 346.3657 ] Writing partition B_mb1 with mb1_t234_prod_aligned_sigheader.bin.encrypt [ 282768 bytes ]
[ 347.2054 ] [................................................] 100%
[ 347.2161 ] Writing partition B_psc_bl1 with psc_bl1_t234_prod_aligned_sigheader.bin.encrypt [ 123008 bytes ]
[ 350.7406 ] [................................................] 100%
[ 350.7446 ] Writing partition B_tsec-fw with tsec_t234_sigheader.bin.encrypt [ 176128 bytes ]
[ 352.2833 ] [................................................] 100%
[ 352.2898 ] Writing partition B_nvdec with nvdec_t234_prod_sigheader.fw.encrypt [ 294912 bytes ]
[ 354.4819 ] [................................................] 100%
[ 354.4912 ] Writing partition B_mb2 with mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt [ 440944 bytes ]
[ 358.1597 ] [................................................] 100%
[ 358.1745 ] Writing partition B_xusb-fw with xusb_t234_prod_sigheader.bin.encrypt [ 164864 bytes ]
[ 363.6638 ] [................................................] 100%
[ 363.6692 ] Writing partition B_bpmp-fw with bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt [ 1027008 bytes ]
[ 365.7219 ] [................................................] 100%
[ 365.7573 ] Writing partition B_bpmp-fw-dtb with tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt [ 204608 bytes ]
[ 378.5226 ] [................................................] 100%
[ 378.5279 ] Writing partition B_psc-fw with pscfw_t234_prod_sigheader.bin.encrypt [ 310768 bytes ]
[ 381.0794 ] [................................................] 100%
[ 381.0892 ] Writing partition B_mts-mce with mce_flash_o10_cr_prod_sigheader.bin.encrypt [ 187120 bytes ]
[ 384.9563 ] [................................................] 100%
[ 384.9625 ] Writing partition B_sc7 with sc7_t234_prod_sigheader.bin.encrypt [ 186880 bytes ]
[ 387.2942 ] [................................................] 100%
[ 387.3004 ] Writing partition B_pscrf with psc_rf_t234_prod_sigheader.bin.encrypt [ 122464 bytes ]
[ 389.6261 ] [................................................] 100%
[ 389.6295 ] Writing partition B_mb2rf with mb2rf_t234_sigheader.bin.encrypt [ 122720 bytes ]
[ 391.1623 ] [................................................] 100%
[ 391.1658 ] Writing partition B_cpu-bootloader with uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt [ 3327744 bytes ]
[ 392.6995 ] [................................................] 100%
[ 431.8884 ] Writing partition B_secure-os with tos-optee_t234_sigheader.img.encrypt [ 1887312 bytes ]
[ 434.1592 ] [................................................] 100%
[ 447.2536 ] Writing partition B_eks with eks_t234_sigheader.img.encrypt [ 9232 bytes ]
[ 457.6831 ] [................................................] 100%
[ 457.6846 ] Writing partition B_dce-fw with display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_aligned_blob_w_bin_sigheader.bin.encrypt [ 783040 bytes ]
[ 457.8133 ] [................................................] 100%
[ 457.8385 ] Writing partition B_spe-fw with spe_t234_sigheader.bin.encrypt [ 270336 bytes ]
[ 467.5759 ] [................................................] 100%
[ 467.5849 ] Writing partition B_rce-fw with camera-rtcpu-t234-rce_sigheader.img.encrypt [ 458096 bytes ]
[ 470.9483 ] [................................................] 100%
[ 470.9636 ] Writing partition B_adsp-fw with adsp-fw_sigheader.bin.encrypt [ 415232 bytes ]
[ 476.6616 ] [................................................] 100%
[ 476.6753 ] Writing partition B_pva-fw with nvpva_020_aligned_blob_w_bin_sigheader.fw.encrypt [ 67024 bytes ]
[ 481.8372 ] [................................................] 100%
[ 481.8394 ] Writing partition secondary_gpt_backup with gpt_backup_secondary_3_0.bin [ 16896 bytes ]
[ 482.6792 ] [................................................] 100%
[ 482.6810 ] Writing partition B_VER with qspi_bootblob_ver.txt [ 109 bytes ]
[ 482.8943 ] [................................................] 100%
[ 482.8961 ] Writing partition A_VER with qspi_bootblob_ver.txt [ 109 bytes ]
[ 482.9053 ] [................................................] 100%
[ 482.9160 ] tegradevflash_v2 --write BCT br_bct_BR.bct
[ 482.9171 ] Bootloader version 01.00.0000
[ 483.0282 ] Writing partition BCT with br_bct_BR.bct [ 8192 bytes ]
[ 483.0297 ] [................................................] 100%
[ 489.6796 ] tegradevflash_v2 --write BCT-boot-chain_backup bct_backup.img
[ 489.6807 ] Bootloader version 01.00.0000
[ 489.7937 ] Writing partition BCT-boot-chain_backup with bct_backup.img [ 32768 bytes ]
[ 489.7954 ] [................................................] 100%
[ 490.2098 ] tegradevflash_v2 --write A_MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 490.2104 ] Bootloader version 01.00.0000
[ 490.2125 ] Writing partition A_MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt [ 17600 bytes ]
[ 490.2135 ] [................................................] 100%
[ 490.4421 ] tegradevflash_v2 --write B_MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 490.4427 ] Bootloader version 01.00.0000
[ 490.4447 ] Writing partition B_MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt [ 17600 bytes ]
[ 490.4457 ] [................................................] 100%
[ 490.6787 ] tegradevflash_v2 --write A_MEM_BCT mem_coldboot_sigheader.bct.encrypt
[ 490.6798 ] Bootloader version 01.00.0000
[ 490.6819 ] Writing partition A_MEM_BCT with mem_coldboot_sigheader.bct.encrypt [ 243712 bytes ]
[ 490.6829 ] [................................................] 100%
[ 493.7202 ] tegradevflash_v2 --write B_MEM_BCT mem_coldboot_sigheader.bct.encrypt
[ 493.7207 ] Bootloader version 01.00.0000
[ 493.8323 ] Writing partition B_MEM_BCT with mem_coldboot_sigheader.bct.encrypt [ 243712 bytes ]
[ 493.8347 ] [................................................] 100%
[ 496.8709 ] Flashing completed
[ 496.8710 ] Coldbooting the device
[ 496.8725 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 496.8732 ] MB2 version 01.00.0000
[ 496.9836 ] Coldbooting the device
[ 496.9850 ] tegrarcm_v2 --chip 0x23 0 --reboot coldboot
[ 496.9855 ] MB2 version 01.00.0000
*** The target generic has been flashed successfully. ***
Reset the board to boot from internal eMMC.
Atleast with this file, it seems to be going to a black screen. With the previous uefi bin files, it wouldn’t even pickup the HDMI signal after initial logo. And this is only with the uefi binaries from uefi soures, if I use the original uefi binary, it works without an error.
I guess the only step changed from previous time when I performed uefi customization (r36.3.0) is going through these steps:
It seems you can flash QSPI only successfully.
Is your issue about there’s no any display after seeing UEFI logo?
If so, please share the full serial console log for further check.
Hello Kevin,
Sorry for replying so late.
Here’s the full UART log:
11:15:42:888 -> ��
11:15:43:258 -> ����
11:15:43:282 -> ��[     0.325982] Camera-FW on t234-rce-safe started
11:15:43:285 -> TCU early console enabled.
11:15:43:301 -> ��
11:15:43:313 -> DCE Started
11:15:43:325 -> DCE_R5_Init
11:15:43:337 -> MPU enabled
11:15:43:340 -> DCE_SW_Init
11:15:43:535 -> ��[     0.578125] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.417 ms, total boot 265.631 ms)
11:15:43:574 -> ��I/TC:
11:15:43:595 -> ��Admin Task Init
11:15:43:595 -> Admin Task Init complete
11:15:43:598 -> Print Task Init
11:15:43:598 -> RM Task Init
11:15:43:601 -> SHA Task Init
11:15:43:601 -> Admin Task Started
11:15:43:604 -> DCE SC7 SHA Enabled
11:15:43:607 -> RM Task Started
11:15:43:607 -> RM Task Running
11:15:43:609 -> Print Task Started
11:15:43:609 -> Print Task Running
11:15:43:612 -> SHA Task Started
11:15:43:615 -> DCE: FW Boot Complete
11:15:43:615 -> Admin Task Running
11:15:43:618 -> SHA Task Running
11:15:43:618 -> ��I/TC: Non-secure external DT found
11:15:43:716 -> I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Fri Sep 13 04:10:17 UTC 2024 aarch64
11:15:43:745 -> I/TC: WARNING: This OP-TEE configuration might be insecure!
11:15:43:766 -> I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
11:15:43:795 -> I/TC: Primary CPU initializing
11:15:43:944 -> I/TC: Test OEM keys are being used. This is insecure for shipping products!
11:15:44:002 -> I/TC: fTPM ID is not enabled.
11:15:44:002 -> I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is not supported.
11:15:44:042 -> I/TC: Primary CPU switching to normal world boot
11:15:44:068 -> ��
11:15:44:068 -> Jetson UEFI firmware (version r36.4.0-5de7ef09-dirty built on 2024-11-20T08:22:35+00:00)
11:15:44:090 ->
11:15:44:344 ->
11:15:44:375 ->
11:15:44:385 ->
11:15:44:611 ->
11:15:44:618 ->
11:15:44:627 ->
11:15:44:634 ->
11:15:44:642 ->
11:15:44:650 ->
11:15:44:658 ->
11:15:44:665 ->
11:15:44:673 ->
11:15:44:680 ->
11:15:44:688 ->
11:15:44:696 ->
11:15:44:704 ->
11:15:44:711 ->
11:15:44:719 ->
11:15:44:756 ->
11:15:44:757 ->
11:15:44:757 ->
11:15:44:757 ->
11:15:44:757 ->
11:15:44:765 ->
11:15:44:773 ->
11:15:44:781 ->
11:15:44:789 ->
11:15:44:796 ->
11:15:44:803 ->
11:15:44:812 ->
11:15:44:819 ->
11:15:44:826 ->
11:15:44:834 ->
11:15:44:841 ->
11:15:44:850 ->
11:15:44:877 ->
11:15:44:887 ->
11:15:44:898 ->
11:15:44:906 ->
11:15:44:918 ->
11:15:44:926 ->
11:15:44:936 ->
11:15:44:944 ->
11:15:44:952 ->
11:15:44:974 ->
11:15:44:983 ->
11:15:44:991 ->
11:15:44:998 ->
11:15:45:006 ->
11:15:45:013 ->
11:15:45:021 ->
11:15:45:029 ->
11:15:45:037 ->
11:15:45:050 ->
11:15:45:063 ->
11:15:45:064 ->
11:15:45:070 ->
11:15:45:094 ->
11:15:45:103 ->
11:15:45:107 ->
11:15:45:111 ->
11:15:45:119 ->
11:15:45:126 ->
11:15:45:139 -> ��I/TC: Reserved shared memory is disabled
11:15:45:149 -> I/TC: Dynamic shared memory is enabled
11:15:45:161 -> I/TC: Normal World virtualization support is disabled
11:15:45:179 -> I/TC: Asynchronous notifications are disabled
11:15:45:516 -> I/TC: WARNING: Test UEFI variable auth key is being used !
11:15:45:525 -> I/TC: WARNING: UEFI variable protection is not fully enabled !
11:15:45:678 -> ��
11:15:45:685 ->
11:15:45:693 ->
11:15:45:716 ->
11:15:45:718 ->
11:15:45:739 ->
11:15:45:747 ->
11:15:45:755 ->
11:15:45:762 ->
11:15:45:770 ->
11:15:45:778 ->
11:15:45:787 ->
11:15:45:795 ->
11:15:45:812 ->
11:15:45:813 ->
11:15:45:819 ->
11:15:45:827 ->
11:15:45:835 ->
11:15:45:845 ->
11:15:45:853 ->
11:15:45:862 ->
11:15:45:886 ->
11:15:45:897 ->
11:15:45:927 ->
11:15:45:937 ->
11:15:45:947 ->
11:15:45:958 ->
11:15:45:980 ->
11:15:45:988 ->
11:15:46:004 ->
11:15:46:013 ->
11:15:46:022 ->
11:15:46:043 ->
11:15:46:044 ->
11:15:46:050 ->
11:15:46:075 ->
11:15:46:085 ->
11:15:46:101 ->
11:15:46:138 -> ��[     3.181709] Camera-FW on t234-rce-safe started
11:15:46:141 -> TCU early console enabled.
11:15:46:144 -> ��
11:15:46:161 ->
11:15:46:170 ->
11:15:46:212 ->
11:15:46:222 ->
11:15:46:231 ->
11:15:46:231 -> ��[     3.275345] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 1.400 ms, total boot 95.142 ms)
11:15:46:240 -> ��
11:15:46:248 ->
11:15:46:256 ->
11:15:46:510 ->
11:15:46:520 ->
11:15:46:952 ->
11:15:46:961 ->
11:15:46:984 ->
11:15:46:992 ->
11:15:47:000 ->
11:15:47:009 ->
11:15:47:017 ->
11:15:47:025 ->
11:15:47:034 ->
11:15:47:044 ->
11:15:47:053 ->
11:15:47:060 ->
11:15:47:070 ->
11:15:47:078 ->
11:15:47:086 ->
11:15:47:094 ->
11:15:47:102 ->
11:15:47:111 ->
11:15:47:119 ->
11:15:47:138 ->
11:15:47:139 ->
11:15:47:145 ->
11:15:47:153 ->
11:15:47:163 ->
11:15:47:174 ->
11:15:47:182 ->
11:15:47:192 ->
11:15:47:209 ->
11:15:47:219 ->
11:15:47:234 ->
11:15:47:246 ->
11:15:47:256 ->
11:15:47:266 ->
11:15:47:274 ->
11:15:47:283 ->
11:15:47:292 ->
11:15:47:302 ->
11:15:47:315 ->
11:15:47:332 ->
11:15:47:383 ->
11:15:47:400 ->
11:15:50:008 ->
11:15:50:020 ->
11:15:50:029 ->
11:15:50:038 ->
11:15:51:877 ->
11:15:51:930 ->
11:15:51:938 ->
11:15:51:946 ->
11:15:51:955 ->
11:15:51:970 ->
11:15:53:400 -> Jetson System firmware version r36.4.0-5de7ef09-dirty date 2024-11-20T08:22:35+0
11:15:53:406 -> 0:00
11:15:53:410 -> ESC   to enter Setup.
11:15:53:410 -> F11   to enter Boot Manager Menu.
11:15:53:413 -> Enter to continue boot.
11:15:58:841 ->
11:15:58:843 -> L4TLauncher: Attempting Direct Boot
11:16:02:100 -> ��I/TC: Reserved shared memory is disabled
11:16:02:111 -> I/TC: Dynamic shared memory is enabled
11:16:02:120 -> I/TC: Normal World virtualization support is disabled
11:16:02:140 -> I/TC: Asynchronous notifications are disabled
11:16:07:530 -> ��TCU debug prints will be routed to traces.
11:16:08:173 -> ��Starting RmBootstrap
11:16:08:173 -> Registered event_type:[0] for dce_core_ipc_type:[1]
11:16:08:178 -> Registered event_type:[1] for dce_core_ipc_type:[3]
11:16:08:184 -> dce_ipc State Initialized
11:16:08:184 -> RmBootstrap completed successfully
Do you mean that there’s no issue when you use original UEFI binary?
Is the console still alive at this moment?
It seems your board does not hang.
Please also share /var/log/xorg.0.log for further check.
Are you using /dev/ttyTCU0 to output log?
Please refer to Jetson Nano & NX Style - Serial Debug Console - JetsonHacks to capture log on the devkit.
Yes
Here’s my log using minicom, I think it’s the same, previously I took the log on windows system.
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyUSB0, 11:10:23
Press CTRL-A Z for help on special keys
    ��[     0.323051] Camera-FW on t234-rce-safe started
  DCE Started
DCE_R5_Init
MPU enabled
DCE_SW_Init
��[     0.575216] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.413 ms, total boot 265.650)
��I/TC:
��Admin Task Init
Print Task Init
RM Task Init
SHA Task Init
Admin Task Started
DCE SC7 SHA Enabled
RM Task Started
RM Task Running
Print Task Started
Print Task Running
SHA Task Started
Admin Task Running
SHA Task Running
I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Fri Sep 13 04:10:17 UTC 2024 4
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.l
[2024-12-02 11:12:17] ��
[2024-12-02 11:12:17] ����
                          [2024-12-02 11:12:18] ��[     0.324067] Camera-FW on t234-rce-safe started
[2024-12-02 11:12:18] TCU early console enabled.
                        [2024-12-02 11:12:18] DCE Started
[2024-12-02 11:12:18] DCE_R5_Init
[2024-12-02 11:12:18] MPU enabled
[2024-12-02 11:12:18] DCE_SW_Init
[2024-12-02 11:12:18] ��[     0.576162] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.412 )
[2024-12-02 11:12:18] ��I/TC:
[2024-12-02 11:12:18] ��Admin Task Init
[2024-12-02 11:12:18] Admin Task Init complete
[2024-12-02 11:12:18] Print Task Init
[2024-12-02 11:12:18] RM Task Init
[2024-12-02 11:12:18] SHA Task Init
[2024-12-02 11:12:18] Admin Task Started
[2024-12-02 11:12:18] DCE SC7 SHA Enabled
[2024-12-02 11:12:18] RM Task Started
[2024-12-02 11:12:18] RM Task Running
[2024-12-02 11:12:18] Print Task Started
[2024-12-02 11:12:18] Print Task Running
[2024-12-02 11:12:18] SHA Task Started
[2024-12-02 11:12:18] DCE: FW Boot Complete
[2024-12-02 11:12:18] Admin Task Running
[2024-12-02 11:12:18] SHA Task Running
[2024-12-02 11:12:18] ��I/TC: Non-secure external DT found
[2024-12-02 11:12:18] I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Fri Sep4
[2024-12-02 11:12:18] I/TC: WARNING: This OP-TEE configuration might be insecure!
[2024-12-02 11:12:18] I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architectul
[2024-12-02 11:12:18] I/TC: Primary CPU initializing
[2024-12-02 11:12:18] I/TC: Test OEM keys are being used. This is insecure for shipping products!
[2024-12-02 11:12:18] I/TC: fTPM ID is not enabled.
[2024-12-02 11:12:18] I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is .
[2024-12-02 11:12:18] I/TC: Primary CPU switching to normal world boot
                        [2024-12-02 11:12:18] Jetson UEFI firmware (version r36.4.0-5de7ef09-dirty )
                      [2024-12-02 11:12:19]
        [2024-12-02
        d
[2024-12-02 11:12:19] I/TC: Dynamic shared memory is enabled
[2024-12-02 11:12:19] I/TC: Normal World virtualization support is disabled
[2024-12-02 11:12:19] I/TC: Asynchronous notifications are disabled
[2024-12-02 11:12:20] I/TC: WARNING: Test UEFI variable auth key is being used !
[2024-12-02 11:12:20] I/TC: WARNING: UEFI variable protection is not fully enabled !
[2024-12-02 11:12:20] ��
        [2024-12-
[2024-12-02 11:12:21]
        [2024-12-02
[2024-12-02 11:12:57] ��
[2024-12-02 11:12:57] ����
                          [2024-12-02 11:12:57] ��[     0.325431] Camera-FW on t234-rce-safe started
[2024-12-02 11:12:57] TCU early console enabled.
[2024-12-02 11:12:58] ��
                        [2024-12-02 11:12:58] DCE Started
[2024-12-02 11:12:58] DCE_R5_Init
[2024-12-02 11:12:58] MPU enabled
[2024-12-02 11:12:58] DCE_SW_Init
[2024-12-02 11:12:58] ��[     0.577630] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.415 m
s, total boot 265.686 ms)
[2024-12-02 11:12:58] ��I/TC:
[2024-12-02 11:12:58] ��Admin Task Init
[2024-12-02 11:12:58] Admin Task Init complete
[2024-12-02 11:12:58] Print Task Init
[2024-12-02 11:12:58] RM Task Init
[2024-12-02 11:12:58] SHA Task Init
[2024-12-02 11:12:58] Admin Task Started
[2024-12-02 11:12:58] DCE SC7 SHA Enabled
[2024-12-02 11:12:58] RM Task Started
[2024-12-02 11:12:58] RM Task Running
[2024-12-02 11:12:58] Print Task Started
[2024-12-02 11:12:58] Print Task Running
[2024-12-02 11:12:58] SHA Task Started
[2024-12-02 11:12:58] DCE: FW Boot Complete
[2024-12-02 11:12:58] Admin Task Running
[2024-12-02 11:12:58] SHA Task Running
[2024-12-02 11:12:58] ��I/TC: Non-secure external DT found
[2024-12-02 11:12:58] I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Fri Sep
[2024-12-02 11:12:58] I/TC: WARNING: This OP-TEE configuration might be insecure!
[2024-12-02 11:12:58] I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architectur
[2024-12-02 11:12:58] I/TC: Primary CPU initializing
[2024-12-02 11:12:58] I/TC: Test OEM keys are being used. This is insecure for shipping products!
[2024-12-02 11:12:58] I/TC: fTPM ID is not enabled.
[2024-12-02 11:12:58] I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is n
ot supported.
[2024-12-02 11:12:58] I/TC: Primary CPU switching to normal world boot
                        [2024-12-02 11:12:58] Jetson UEFI firmware (version r36.4.0-5de7ef09-dirty b
                      [2024-12-02 11:12:59]
        [2024-12-02
11:12:59]
        [2
024-12-02 11:12:59]
        [2024-12-02 11
:12:59]
        [202
4-12-02 11:12:59]
        [2024-12-02 11:1
2:59]
        [2024-
12-02 11:12:59]
        [2024-12-02 11:12:
59]
        [2024-12
-02 11:12:59]
        [2024-12-0
2 11:12:59]
        [2024-12-02
11:12:59]
        [2
024-12-02 11:12:59]
        [2024-12-02 11
:12:59]
        [2024-12-02 11:12:59] ��I/TC: Reserved shared memory is disabled
[2024-12-02 11:12:59] I/TC: Dynamic shared memory is enabled
[2024-12-02 11:12:59] I/TC: Normal World virtualization support is disabled
[2024-12-02 11:12:59] I/TC: Asynchronous notifications are disabled
[2024-12-02 11:13:00] I/TC: WARNING: Test UEFI variable auth key is being used !
[2024-12-02 11:13:00] I/TC: WARNING: UEFI variable protection is not fully enabled !
[2024-12-02 11:13:00] ��
        [2024-12-0
2 11:13:00]
        [2024-12-02
11:13:00]
        [2
024-12-02 11:13:00]
        [2024-12-02 11
:13:00]
        [202
4-12-02 11:13:00]
        [2024-12-02 11:1
3:00]
[2024-12-02 11:13:01]
        [2024-12-02
11:13:01]
        [2
024-12-02 11:13:01]
        [2024-12-02 11
:13:01]
        [202
4-12-02 11:13:01]
        [2024-12-02 11:1
3:01]
        [2024-
12-02 11:13:01]
        [2024-12-02 11:13:
01]
        [2024-12
[2024-12-02 11:13:55] ��
[2024-12-02 11:13:55] ����
                          [2024-12-02 11:13:55] ��[     0.323630] Camera-FW on t234-rce-safe started
[2024-12-02 11:13:55] TCU early console enabled.
                        [2024-12-02 11:13:55] DCE Started
[2024-12-02 11:13:55] DCE_R5_Init
[2024-12-02 11:13:55] MPU enabled
[2024-12-02 11:13:55] DCE_SW_Init
[2024-12-02 11:13:55] ��[     0.575785] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.415 m
s, total boot 265.643 ms)
[2024-12-02 11:13:55] ��I/TC:
[2024-12-02 11:13:55] ��Admin Task Init
[2024-12-02 11:13:55] Admin Task Init complete
[2024-12-02 11:13:55] Print Task Init
[2024-12-02 11:13:55] RM Task Init
[2024-12-02 11:13:55] SHA Task Init
[2024-12-02 11:13:55] Admin Task Started
[2024-12-02 11:13:55] DCE SC7 SHA Enabled
[2024-12-02 11:13:55] RM Task Started
[2024-12-02 11:13:55] RM Task Running
[2024-12-02 11:13:56] Print Task Started
[2024-12-02 11:13:56] Print Task Running
[2024-12-02 11:13:56] SHA Task Started
[2024-12-02 11:13:56] DCE: FW Boot Complete
[2024-12-02 11:13:56] Admin Task Running
[2024-12-02 11:13:56] SHA Task Running
[2024-12-02 11:13:56] ��I/TC: Non-secure external DT found
[2024-12-02 11:13:56] I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Fri Sep
[2024-12-02 11:13:56] I/TC: WARNING: This OP-TEE configuration might be insecure!
[2024-12-02 11:13:56] I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architectur
[2024-12-02 11:13:56] I/TC: Primary CPU initializing
[2024-12-02 11:13:56] I/TC: Test OEM keys are being used. This is insecure for shipping products!
[2024-12-02 11:13:56] I/TC: fTPM ID is not enabled.
[2024-12-02 11:13:56] I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is n
ot supported.
[2024-12-02 11:13:56] I/TC: Primary CPU switching to normal world boot
                        [2024-12-02 11:13:56] Jetson UEFI firmware (version r36.4.0-5de7ef09-dirty b
        [2024-12-02
11:13:57]
          [2024-12-02 11:13:57]
        [2
024-12-02 11:13:57]
        [2024-12-02 11
:13:57]
        [202
4-12-02 11:13:57]
        [2024-12-02 11:1
3:57]
        [2024-
12-02 11:13:57]
        [2024-12-02 11:13:
57]
        [2024-12
-02 11:13:57]
        [2024-12-0
2 11:13:57]
        [2024-12-02
11:13:57]
        [2
024-12-02 11:13:57]
        [2024-12-02 11
:13:57]
        [2024-12-02 11:13:57] ��I/TC: Reserved shared memory is disabled
[2024-12-02 11:13:57] I/TC: Dynamic shared memory is enabled
[2024-12-02 11:13:57] I/TC: Normal World virtualization support is disabled
[2024-12-02 11:13:57] I/TC: Asynchronous notifications are disabled
[2024-12-02 11:13:57] I/TC: WARNING: Test UEFI variable auth key is being used !
[2024-12-02 11:13:57] I/TC: WARNING: UEFI variable protection is not fully enabled !
[2024-12-02 11:13:58] ��
        [2024-12-0
2 11:13:58]
        [2024-12-02
11:13:58]
        [2
024-12-02 11:13:58]
        [2024-12-02 11
:13:58]
        [202
4-12-02 11:13:58]
        [2024-12-02 11:1
3:58]
                                            [2024-12-02 11:13:59]
        [2024-12-02
11:13:59]
        [2
024-12-02 11:13:59]
        [2024-12-02 11
:13:59]
        [202
4-12-02 11:13:59]
        [2024-12-02 11:1
3:59]
[2024-12-02 11:14:19] ��
[2024-12-02 11:14:19] ����
                          [2024-12-02 11:14:19] ��[     0.324344] Camera-FW on t234-rce-safe started
[2024-12-02 11:14:19] TCU early console enabled.
                        [2024-12-02 11:14:19] DCE Started
[2024-12-02 11:14:20] DCE_R5_Init
[2024-12-02 11:14:20] MPU enabled
[2024-12-02 11:14:20] DCE_SW_Init
[2024-12-02 11:14:20] ��[     0.576272] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.417 )
[2024-12-02 11:14:20] ��I/TC:
[2024-12-02 11:14:20] ��Admin Task Init
[2024-12-02 11:14:20] Admin Task Init complete
[2024-12-02 11:14:20] Print Task Init
[2024-12-02 11:14:20] RM Task Init
[2024-12-02 11:14:20] SHA Task Init
[2024-12-02 11:14:20] Admin Task Started
[2024-12-02 11:14:20] DCE SC7 SHA Enabled
[2024-12-02 11:14:20] RM Task Started
[2024-12-02 11:14:20] RM Task Running
[2024-12-02 11:14:20] Print Task Started
[2024-12-02 11:14:20] Print Task Running
[2024-12-02 11:14:20] SHA Task Started
[2024-12-02 11:14:20] DCE: FW Boot Complete
[2024-12-02 11:14:20] Admin Task Running
[2024-12-02 11:14:20] SHA Task Running
[2024-12-02 11:14:20] ��I/TC: Non-secure external DT found
[2024-12-02 11:14:20] I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Fri Sep4
[2024-12-02 11:14:20] I/TC: WARNING: This OP-TEE configuration might be insecure!
[2024-12-02 11:14:20] I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architectul
[2024-12-02 11:14:20] I/TC: Primary CPU initializing
[2024-12-02 11:14:20] I/TC: Test OEM keys are being used. This is insecure for shipping products!
[2024-12-02 11:14:20] I/TC: fTPM ID is not enabled.
[2024-12-02 11:14:20] I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is .
[2024-12-02 11:14:20] I/TC: Primary CPU switching to normal world boot
                        [2024-12-02 11:14:20] Jetson UEFI firmware (version r36.4.0-5de7ef09-dirty )
                      [2024-12-02 11:14:21]
        [2024-12-02
        d
[2024-12-02 11:14:21] I/TC: Dynamic shared memory is enabled
[2024-12-02 11:14:21] I/TC: Normal World virtualization support is disabled
[2024-12-02 11:14:21] I/TC: Asynchronous notifications are disabled
[2024-12-02 11:14:22] I/TC: WARNING: Test UEFI variable auth key is being used !
[2024-12-02 11:14:22] I/TC: WARNING: UEFI variable protection is not fully enabled !
[2024-12-02 11:14:22] ��
        [2024-12-
[2024-12-02 11:14:23]
        [2024-12-02
        0
[2024-12-02 11:14:30] 0:00
[2024-12-02 11:14:30] ESC   to enter Setup.
[2024-12-02 11:14:30] F11   to enter Boot Manager Menu.
[2024-12-02 11:14:30] Enter to continue boot.
[2024-12-02 11:14:35]
                      [2024-12-02 11:14:35] L4TLauncher: Attempting Direct Boot
[2024-12-02 11:14:40] ��I/TC: Reserved shared memory is disabled
[2024-12-02 11:14:40] I/TC: Dynamic shared memory is enabled
[2024-12-02 11:14:40] I/TC: Normal World virtualization support is disabled
[2024-12-02 11:14:40] I/TC: Asynchronous notifications are disabled
[2024-12-02 11:14:45] ��TCU debug prints will be routed to traces.
[2024-12-02 11:14:46] ��Starting RmBootstrap
[2024-12-02 11:14:46] Registered event_type:[0] for dce_core_ipc_type:[1]
[2024-12-02 11:14:46] Registered event_type:[1] for dce_core_ipc_type:[3]
[2024-12-02 11:14:46] dce_ipc State Initialized
[2024-12-02 11:14:46] RmBootstrap completed successfully
Cursor is blinking but the log does not move forward. Also the screen attached to jetson remains black.
How to access this?
Do you mean that it hangs and you can not enter anything in the console at this moment?
If you can access the board, please help to capture this log on your board.
Can your board boot before you update custom UEFI binary?
yes, I cannot type anything, however the console doesn’t hang as the cursor remains blinking. Whichever key I press, a newline is created.
I cannot access the board as it doesn’t boot completely.
Yes.
Please revert back to original UEFI binary.
And share the detailed steps how did you build custom UEFI binary and apply the change.
As I’ve said previously, I changed not a single letter in the uefi source, just compiled what was cloned. Compilation was successful so I replaced the uefi_jetson.bin file, as I’ve been doing with r36.3 previously. We’e also tried with the binary file you provided, and it didn’t work as well.
Here is the var/log/xorg.o.log file I obtained with the original UEFI binary.
Xorg.0.log (19.8 KB)
The following is the console log also with the original UEFI binary.
    ��[     0.325172] Camera-FW on t234-rce-safe started
  DCE Started
DCE_R5_Init
MPU enabled
DCE_SW_Init
��[     0.577240] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.413 ms, total boot 265.553)
��I/TC:
��Admin Task Init
Print Task Init
RM Task Init
SHA Task Init
Admin Task Started
DCE SC7 SHA Enabled
RM Task Started
RM Task Running
Print Task Started
Print Task Running
SHA Task Started
Admin Task Running
SHA Task Running
  Jetson UEFI firmware (version 36.4.0-gcid-37537400 built on 2024-09-13T04:02:39+00:00)
[2024-12-05 09:48:07] ����
                          [2024-12-05 09:48:07] ��[     0.329083] Camera-FW on t234-rce-safe started
[2024-12-05 09:48:07] TCU early console enabled.
                        [2024-12-05 09:48:07] DCE Started
[2024-12-05 09:48:07] DCE_R5_Init
[2024-12-05 09:48:07] MPU enabled
[2024-12-05 09:48:07] DCE_SW_Init
[2024-12-05 09:48:07] ��[     0.579250] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.417 )
[2024-12-05 09:48:07] ��I/TC:
[2024-12-05 09:48:07] ��Admin Task Init
[2024-12-05 09:48:07] Admin Task Init complete
[2024-12-05 09:48:07] Print Task Init
[2024-12-05 09:48:07] RM Task Init
[2024-12-05 09:48:07] SHA Task Init
[2024-12-05 09:48:07] Admin Task Started
[2024-12-05 09:48:07] DCE SC7 SHA Enabled
[2024-12-05 09:48:07] RM Task Started
[2024-12-05 09:48:07] RM Task Running
[2024-12-05 09:48:07] Print Task Started
[2024-12-05 09:48:07] Print Task Running
[2024-12-05 09:48:07] SHA Task Started
[2024-12-05 09:48:07] DCE: FW Boot Complete
[2024-12-05 09:48:07] Admin Task Running
[2024-12-05 09:48:07] SHA Task Running
[2024-12-05 09:48:07] ��I/TC: Non-secure external DT found
[2024-12-05 09:48:07] I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Fri Sep4
[2024-12-05 09:48:07] I/TC: WARNING: This OP-TEE configuration might be insecure!
[2024-12-05 09:48:07] I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architectul
[2024-12-05 09:48:07] I/TC: Primary CPU initializing
[2024-12-05 09:48:07] I/TC: Test OEM keys are being used. This is insecure for shipping products!
[2024-12-05 09:48:07] I/TC: fTPM ID is not enabled.
[2024-12-05 09:48:07] I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is .
[2024-12-05 09:48:07] I/TC: Primary CPU switching to normal world boot
                        [2024-12-05 09:48:07] Jetson UEFI firmware (version 36.4.0-gcid-37537400 bu)
                      [2024-12-05 09:48:08]
        [2024-12-05
        d
[2024-12-05 09:48:08] I/TC: Dynamic shared memory is enabled
[2024-12-05 09:48:08] I/TC: Normal World virtualization support is disabled
[2024-12-05 09:48:09] I/TC: Asynchronous notifications are disabled
[2024-12-05 09:48:09] I/TC: WARNING: Test UEFI variable auth key is being used !
[2024-12-05 09:48:09] I/TC: WARNING: UEFI variable protection is not fully enabled !
[2024-12-05 09:48:09] ��
        [2024-12-
[2024-12-05 09:48:10]
        [2024-12-05
[2024-12-05 09:48:13]
        [2024-12-05 09:48:15]
        [2024-12-05 09:48:15]        20
[2024-12-05 09:48:17] 00
[2024-12-05 09:48:17] ESC   to enter Setup.
[2024-12-05 09:48:17] F11   to enter Boot Manager Menu.
[2024-12-05 09:48:17] Enter to continue boot.
[2024-12-05 09:48:22]
                      [2024-12-05 09:48:22] L4TLauncher: Attempting Direct Boot
[2024-12-05 09:48:26] ��I/TC: Reserved shared memory is disabled
[2024-12-05 09:48:26] I/TC: Dynamic shared memory is enabled
[2024-12-05 09:48:26] I/TC: Normal World virtualization support is disabled
[2024-12-05 09:48:26] I/TC: Asynchronous notifications are disabled
[2024-12-05 09:48:31] ��TCU debug prints will be routed to traces.
[2024-12-05 09:48:32] ��Starting RmBootstrap
[2024-12-05 09:48:32] Registered event_type:[0] for dce_core_ipc_type:[1]
[2024-12-05 09:48:32] Registered event_type:[1] for dce_core_ipc_type:[3]
[2024-12-05 09:48:32] dce_ipc State Initialized
[2024-12-05 09:48:32] RmBootstrap completed successfully
It is not the expected result to me since I’ve also verified it on the Orin Nano devkit.
Custom build UEFI binary should work when there’s no any modification.
Could you also share the result of $ cat /etc/nv_boot_control.conf from your board for further check?
It is the normal log to me w/o any errors.
Here it is,
TNSPEC 3767-300-0005-K.2-1-1-jetson-orin-nano-devkit-
COMPATIBLE_SPEC 3767--0005--1--jetson-orin-nano-devkit-
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Did you clone the sources using this method? If not, can you try this as given in the build-without-docker guide? Because the only thing seems different from the previous is the link for subhook submodule.
Is there a way to download the uefi sources manually instead of cloning them using edkrepo clone nvidia-uefi NVIDIA-Platforms r36.4.0 command?
Kindly give me an update.
