Try to deploy Clara SDK v 0.5.0-9881 with this documentation
https://docs.nvidia.com/clara/deploy/ClaraInstallation.html
Arch :
- Linux Ubuntu 18.04
- 2 GPU Tesla V100 PCI 32GB
I have installed the prerequisite
- minikube version: v1.9.2
- kubectl :
Client Version: version.Info{Major:"1", Minor:"18", GitVersion:"v1.18.2", GitCommit:"52c56ce7a8272c798dbc29846288d7cd9fbae032", GitTreeState:"clean", BuildDate:"2020-04-16T11:56:40Z", GoVersion:"go1.13.9", Compiler:"gc", Platform:"linux/amd64"}
Server Version: version.Info{Major:"1", Minor:"18", GitVersion:"v1.18.0", GitCommit:"9e991415386e4cf155a24b1da15becaa390438d8", GitTreeState:"clean", BuildDate:"2020-03-25T14:50:46Z", GoVersion:"go1.13.8", Compiler:"gc", Platform:"linux/amd64"}
- helm (it does not work with v3)
Client: &version.Version{SemVer:"v2.16.4", GitCommit:"5e135cc465d4231d9bfe2c5a43fd2978ef527e83", GitTreeState:"clean"}
Server: &version.Version{SemVer:"v2.16.4", GitCommit:"5e135cc465d4231d9bfe2c5a43fd2978ef527e83", GitTreeState:"clean"}
- Docker
Client: Docker Engine - Community
Version: 19.03.8
API version: 1.40
Go version: go1.12.17
Git commit: afacb8b7f0
Built: Wed Mar 11 01:25:46 2020
OS/Arch: linux/amd64
Experimental: false
Server: Docker Engine - Community
Engine:
Version: 19.03.8
API version: 1.40 (minimum version 1.12)
Built: Wed Mar 11 01:24:19 2020
Experimental: false
containerd:
Version: 1.2.13
GitCommit: 7ad184331fa3e55e52b890ea95e65ba581ae3429
nvidia:
Version: 1.0.0-rc10
GitCommit: dc9208a3303feef5b3839f4323d9beb36df0a9dd
docker-init:
Version: 0.18.0
GitCommit: fec3683
I have installed Clara CLI
- clara version 0.5.0-9881
then the configuration :
clara config --key NGC_API_KEY --orgteam nvidia/Clara
with my API KEY. I have used nvidia/Clara as org and team because I can’t see any information about organization and team in my NGC account.
clara pull platform ==> OK
clara platform start
-==> ERROR
rpc error: code = Unknown desc = validation failed: [configmaps "clara-workflow-controller-configmap" not found, configmaps "clara-resultsservice-configmap" not found, persistentvolumes "clara-platformapiserver-common-volume" not found, persistentvolumes "clara-platformapiserver-model-volume" not found, persistentvolumes "clara-platformapiserver-payload-volume" not found, persistentvolumes "clara-platformapiserver-service-volume" not found, persistentvolumes "pv-results-service-volume" not found, persistentvolumeclaims "clara-platformapiserver-common-volume-claim" not found, persistentvolumeclaims "clara-platformapiserver-model-volume-claim" not found, persistentvolumeclaims "clara-platformapiserver-payload-volume-claim" not found, persistentvolumeclaims "clara-platformapiserver-service-volume-claim" not found, persistentvolumeclaims "pv-results-service-volume-claim" not found, serviceaccounts "argo-ui" not found, serviceaccounts "argo" not found, serviceaccounts "platformapiserver-service-account" not found, clusterroles.rbac.authorization.k8s.io "clara-ui-cluster-role" not found, clusterroles.rbac.authorization.k8s.io "clara-workflow-controller-cluster-role" not found, clusterroles.rbac.authorization.k8s.io "clara-platformapiserver-cluster-role" not found, clusterrolebindings.rbac.authorization.k8s.io "clara-ui-crb" not found, clusterrolebindings.rbac.authorization.k8s.io "clara-workflow-controller-binding" not found, clusterrolebindings.rbac.authorization.k8s.io "clara-platformapiserver-binding" not found, services "clara-ui" not found, services "clara" not found, services "clara-resultsservice" not found, unable to recognize "": no matches for kind "Deployment" in version "extensions/v1beta1", deployments.apps "clara-resultsservice" not found]
