Unable to start VSS reasoning properly
  • Hardware Platform (GPU model and numbers) AGX-Thor
  • System Memory 64GB
  • Ubuntu Version 24.04.3 LTS
  • NVIDIA GPU Driver Version (valid for GPU only) 580.00
  • Issue Type questions
Hi, I tried to deploy VSS 3.1 on the said machine and mostly followed the steps in Prerequisites and Quickstart and I was only able to enter the VSS GUI page http://<HOST_IP>:3000/ at most and reasoning couldn’t be done successfully.
VSS UI reasoning attempt
VSS UI reasoning attempt - 2
To dict all the commands I have entered doesn’t seem to be necessary(or does it?), so I’m first to just mention the last few commands.
### Download Sample Data From NGC
mkdir sample_data
ngc registry resource download-version nvidia/vss-developer/dev-profile-sample-data:3.1.0
tar -xf dev-profile-sample-data_v3.1.0/dev-profile-sample-data.tar.gz -C ./sample_data
rm -rf dev-profile-sample-data_v3.1.0
### Download the Deployment Package
# Install Git LFS if not already installed
sudo apt install git-lfs
git lfs install
git clone GitHub - NVIDIA-AI-Blueprints/video-search-and-summarization: Blueprint for Ingesting massive volumes of live or archived videos and extract insights for summarization and interactive Q&A · GitHub
cd video-search-and-summarization
git lfs install
git lfs pull
The last command I entered was as follows. Is this the command that runs VLM locally and LLM remotely?
export NGC_CLI_API_KEY=(MY CLI API KEY)
export NVIDIA_API_KEY=(MY NIM CATALOG API KEY)
export LLM_ENDPOINT_URL=‘https://integrate.api.nvidia.com
scripts/dev-profile.sh up -p base
-H AGX-THOR
–use-remote-llm
–llm ‘nvidia/nvidia-nemotron-nano-9b-v2’
Spent roughly 30 minutes on pulling all the 12 docker images and then another 20+ minutes to create the containers because there was one container, rtvi-vlm, which wasn’t able to start succesfully and instead got skipped and docker ps showed unhealthy.
Skipped rtvi-vlm
Related containers(one unhealthy)
Also, there’re two places where users are required to enter API keys when I follow the Prerequisites and Quickstart pages. One is ngc config set, and the other one was docker login nvcr.io
The first one(NGC_CLI_API_KEY) whose Key name was set as VSS was created based on the instruction in Prerequisites page:
    1. Once logged in, click on your username in the top right corner
    2. Select Setup from the dropdown menu
    3. Navigate to API Keys under the Keys/Secrets section
    4. Click Generate API Key
    5. Click Generate Personal Key (available at top-right of the page)
    6. Provide a descriptive name for your API key (e.g., “VSS Blueprint Development”)
    7. Select NGC Catalog for Key Permissions
    8. Click Generate Personal Key
    9. Copy the generated API key immediately - you won’t be able to see it again
By the way, the button Generate Personal Key is now under the account settings section.
As for the other API key(NVIDIA_API_KEY), it was auto-generated by clicking the button the Get API Key button in step 1 under the following page.
Would like to know what I should do to fix this.
This issue seems to be caused by incompatibility between the current VLLM image and Jetpack, but I found a workaround for your reference.
  1. Deploy cosmos-reason2-8b using this method. This method is provided by Jetson AI Lab.
2.Deploying VSS using a remote VLM(You can use the local IP address)
export NGC_CLI_API_KEY="cli api key is used for download model and docker images"
export NVIDIA_API_KEY="api key is used for call llm api"
export VLM_ENDPOINT_URL='http://ip:8010'
export LLM_ENDPOINT_URL='https://integrate.api.nvidia.com'
./scripts/dev-profile.sh up -p base \
  --use-remote-llm \
  --llm "nvidia/nvidia-nemotron-nano-9b-v2" \
  --use-remote-vlm
(UPDATE)
I didn’t run the command found here first. Not sure if it has something to do with the problem I’m encountering.
I then ran the following command but still couldn’t run it successfully.
export NGC_API_KEY=$NGC_CLI_API_KEY
export LOCAL_NIM_CACHE=~/.cache/nim
mkdir -p “$LOCAL_NIM_CACHE”
chmod -R a+w “$LOCAL_NIM_CACHE”
docker run -it --rm \
--gpus all \\
--ipc host \\
--shm-size=32GB \\
-e NGC_API_KEY \\
-e NIM_MAX_MODEL_LEN=65536 \\
-v "$LOCAL_NIM_CACHE:/opt/nim/.cache" \\
-u $(id -u) \\
-p 8000:8000 \\
nvcr.io/nim/nvidia/cosmos-reason2-8b:latest
Attached is the log message I received and there’s something I noticed:
“torch.AcceleratorError: CUDA error: no kernel image is available for execution on the device”
nim_cosmos_reason2_error_log.txt (30.8 KB)
The method mentioned here is for x86 + dGPU deployments. For Thor, please refer to the solution above. I have tried it, and it works on my AGX Thor.
Hi, thanks for the reply. I just happened to update the situation right after your post.
Is it exactly the error message I received?
Since you’re using an x86+dGPU deployment, the errors appear to be different. You can check on Thor using docker logs rtvi-vlm. From my side, the error is as follows:
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "/opt/nvidia/rtvi/rtvi/server/rtvi_vlm_server.py", line 2366, in <module>
    server = RTVIServer(args)
  File "/opt/nvidia/rtvi/rtvi/server/rtvi_vlm_server.py", line 216, in __init__
    raise ServiceException(
common.service_exception.ServiceException: ServiceException - code: InternalServerError message: Failed to load RTVI stream handler - Failed to load VLM on GPU 0
NvRmMemInitNvmap failed: error Permission denied
NvRmMemMgrInit failed: Memory Manager Not supported, line 333
NvRmMemMgrInit failed: error type 196626
libnvrm_gpu.so: NvRmGpuLibOpen failed, error=196625
I followed the 2 steps and still encountered some problems.
Firstly, I entered the following command:
sudo docker run -it --rm --runtime=nvidia --network host \
-v $MODEL_PATH:/models/cosmos-reason2-8b:ro \
-v ${HOME}/.cache/vllm:/root/.cache/vllm \
-e MAX_JOBS=1
-e FLASHINFER_JIT_THREADS=1 \
Package vllm · GitHub \
vllm serve /models/cosmos-reason2-8b \
–served-model-name nvidia/cosmos-reason2-8b-fp8 \
–max-model-len 8192
–gpu-memory-utilization 0.5 \
–reasoning-parser qwen3 \
–media-io-kwargs ‘{“video”: {“num_frames”: -1}}’ \
–enable-prefix-caching \
–port 8010
Problem 1: OOM
workaround_1st_error_oom.txt (100.4 KB)
I added 2 more parameters to the previous command and it worked, cosuming roughly 32GB out of 59.90GB:
-e MAX_JOBS=1 \
Then I ran the dev-profile.sh command as shown below and encountered another error:
export NVIDIA_API_KEY=(MY CATALOG KEY)
export VLM_ENDPOINT_URL=‘http://0.0.0.0:8010
-H AGX-THOR \
–use-remote-llm \
–llm “nvidia/nvidia-nemotron-nano-9b-v2” \
–use-remote-vlm
Problem 2:
[ERROR] --use-remote-vlm is not accepted for base profile with hardware profile AGX-THOR
Thank you for sharing. I’m using a 128GB AGX Thor, which has more resources, so I didn’t encounter any errors.
Since remote LLM/VLM is used here, and the HW model doesn’t need to be specified。
deploying VLM already consumes almost all of the video memory. I suspect you might encounter other errors.
I set up the remote LLM in one terminal and then started another terminal to enter the commands.
If param -H isn’t given, the error message becomes this way:
Also I saw the description as follows:
--use-remote-vlm Use remote VLM; base URL taken from host env VLM_ENDPOINT_URL.
• Optional for profile=search; not accepted for profile=alerts or base on IGX-THOR or AGX-THOR
I tried replacing base with lvs but still didn’t work.
nvidia@tegra-ubuntu:~/video-search-and-summarization$ ./scripts/dev-profile.sh up -p lvs --use-remote-llm --llm “nvidia/nvidia-nemotron-nano-9b-v2” --use-remote-vlm --vlm “nvidia/nvidia/cosmos-reason2-8b-fp8” -H AGX-THOR
[ERROR] Hardware profile ‘AGX-THOR’ is only valid for profile base or alerts, not ‘lvs’
Declare the following environment variables
export SKIP_HARDWARE_CHECK=true
I checked dev-profile.sh and figured out that SKIP_HARDWARE_CHECK was mentioned.
I added SKIN_HARDWARE_CHECK=‘true’ to the environment, ran dev-profile.sh again and it worked.
export SKIP_HARDWARE_CHECK=‘true’
–use-remote-llm
–use-remote-vlm
–vlm “nvidia/cosmos-reason2-8b-fp8”
But still, there were some other issues regarding during reasoning.
After successfully running dev-profile.sh I dragged a test video clip to the VSS GUI and asked questions again, but it still ended up not responding until it reached the iteration limit. Below is the message the APIServer kept tossing out.
Step - 19 - Thought
Updated Plan: 1. [x] Call
Copy code
vst_video_clip
— adjusted sensor_id to ‘sample-sim-traffic’ (valid stream found). 2. [ ] Call
Copy code
video_understanding
— adjust timestamps to match video length (19) and retry (e.g., start=0, end=19). — ### Latest Tool Results
Copy code
video_understanding
result: Tool call failed: [###] {‘message’: ‘The timestamps length(15) should be equal video length (19).’, ‘type’: ‘Internal Server Error’, ‘param’: None, ‘code’: 500} {‘error’: {‘message’: ‘The timestamps length(15) should be equal video length (19).’, ‘type’: ‘Internal Server Error’, ‘param’: None, ‘code’: 500}}
Step - 20 - Error
Error: Recursion limit of 50 reached without hitting a stop condition. You can increase the limit by setting the
Copy code
recursion_limit
config key. For troubleshooting, visit: https://docs.langchain.com/oss/python/langgraph/errors/GRAPH_RECURSION_LIMIT
After having tried to do local VLM with remote LLM a few times but ended up getting only failure, I tried using both remote VLM and LLM at the same time.
Command:
export VLM_ENDPOINT_URL=‘https://integrate.api.nvidia.com
--use-remote-llm \
--llm “nvidia/nvidia-nemotron-nano-9b-v2” \
--use-remote-vlm \
--vlm “nvidia/nvidia-cosmos-reason2-8b”
Making sure that no unhealthy containers were seen
Still not able to work properly. (502 bad gateway)
It should be nvidia/cosmos-reason2-8b.
But nim currently does not provide API services for cosmos-reason2-8b. You can use the following command line to check. If you write the model as nvidia/nvidia-cosmos-reason2-8b, you will get another error.
MODEL="nvidia/cosmos-reason2-8b"
curl -sS -w "\nHTTP %{http_code}\n" https://integrate.api.nvidia.com/v1/chat/completions   -H "Authorization: Bearer $NVIDIA_API_KEY"   -H "Content-Type: application/json"   -d "{\"model\":\"$MODEL\",\"messages\":[{\"role\":\"user\",\"content\":\"hi\"}]}"
Try the command line below. The command line you provided doesn’t match the parameters such asmodel name and max-model-len, causing inference failure. I successfully inferred on my 128G AGX-thor.
ngc registry model download-version "nim/nvidia/cosmos-reason2-8b:1208-fp8-static-kv8" \
  --dest ~/.cache/huggingface/hub
export MODEL_PATH="${HOME}/.cache/huggingface/hub/cosmos-reason2-8b_v1208-fp8-static-kv8"
sudo sysctl -w vm.drop_caches=3
  -e MAX_JOBS=1 \
  -e VLLM_USE_V1=1 \
  -v "$MODEL_PATH":/models/cosmos-reason2-8b:ro \
  -v "${HOME}/.cache/vllm":/root/.cache/vllm \
  ghcr.io/nvidia-ai-iot/vllm:0.14.0-r38.3-arm64-sbsa-cu130-24.04 \
    --served-model-name nvidia/cosmos-reason2-8b \
    --max-model-len 16384 \
    --gpu-memory-utilization 0.5 \
    --reasoning-parser qwen3 \
    --enable-prefix-caching \
    --limit-mm-per-prompt '{"video": 1, "image": 0}' \
    --media-io-kwargs '{"video": {"num_frames": 32}}' \
    --port 8010
export NGC_CLI_API_KEY=xxxx
export NVIDIA_API_KEY=xxxx
  --use-remote-llm \
  --use-remote-vlm \
  --vlm "nvidia/cosmos-reason2-8b"
Thanks, it finally worked for the first time.
Memory consumption is roughly 36 GB out of 60 GB.
However, I’d like to know if it’s possible to do remote LLM on some other devices as for now, The LLM_ENDPOINT_URL is https://integrate.api.nvidia.com. What I have in mind is to modify it like what we have done to the VLM in this workaround.
Commands entered in 2 different terminals:
mkdir -p ~/.cache/vllm
-e MAX_JOBS=1 \
-e VLLM_USE_V1=1 \
-v “$MODEL_PATH”:/models/cosmos-reason2-8b:ro \
-v “${HOME}/.cache/vllm”:/root/.cache/vllm \
--served-model-name nvidia/cosmos-reason2-8b \\
--max-model-len 16384 \\
--gpu-memory-utilization 0.5 \\
--reasoning-parser qwen3 \\
--enable-prefix-caching \\
--limit-mm-per-prompt '{"video": 1, "image": 0}' \\
--media-io-kwargs '{"video": {"num_frames": 32}}' \\
--port 8010
export NVIDIA_API_KEY=(MY NIM API KEY)
export VLM_ENDPOINT_URL=‘http://10.1.9.24:8010
--use-remote-llm \
--use-remote-vlm \
--vlm “nvidia/cosmos-reason2-8b”
As a developer, as long as your API key hasn’t expired, the LLM endpoint can continue to be used, although the speed might be slower.
This is guaranteed by NIM, VSS just a user of NIM.
