Unable to stream video from CSI-1 port on Seeed ReComputer Carrier board
I am leveraging Deepstream samples to test my camera setup. I am using a Jetson Orin NX 8GB with a SeeedStudio ReComputer carrier board that has 2 CSI ports, labeled CSI0/J8 and CSI1/J12.
I have 2 cameras I am testing with. A Sony IMX219 (wide angle lens) and a Raspberry Pi Camera V2 (telephoto lens). They both work when plugged into the CSI0 port and the camera-csi-sensor-id=1 entry is set. This seems a little odd, since CSI0 is aligned with sensor_id 1. When I run the samples config for the 6 CSI feed, I get settings info for both camera for sensor_id 0 and sensor_id 1. But I get no feed from the camera plugged into the CSI1 port, which aligns with sensor_id 0.
It might be some intricacies with this particular board.
The command I am running is:
deepstream-app -c /opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/source6_csi_dec_infer_resnet_int8.txt
The feedback I get before the window appears:
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3280 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3280 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 1
Camera mode = 4
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 59.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
CONSUMER: Waiting until producer is connected…
Camera index = 0
Camera mode = 4
seconds to Run = 0
Does sensor_id=0 and sensor_id=1 work with gst-launch-1.0 nvarguscamerasrc command? Let’s be sure nvarguscamerasrc works on both CSI ports and then check the behavior in deepstream.
