I am trying to get mask from Mask RCNN, I modified NvDsInferObjectDetectionInfo structure in the nvsdinfer.h file as the first comment. I also changed something in the nvdsinfer_custombboxparser_mrcnn_uff.cpp file. I created successfully .so file, but when I run on Deepstream, it’s fail. I think my nvdsinfer_custombboxparser_mrcnn_uff.cpp file have some problem. How can I fix that?
#include <cstring>
#include <iostream>
#include <vector>
#include <fstream>
#include "nvdsinfer_custom_impl.h"
#include <cassert>
#define MIN(a,b) ((a) < (b) ? (a) : (b))
#define MAX(a,b) ((a) > (b) ? (a) : (b))
#define CLIP(a,min,max) (MAX(MIN(a, max), min))
#define DIVIDE_AND_ROUND_UP(a, b) ((a + b - 1) / b)
using namespace std;
static const int DETECTION_MAX_INSTANCES = 100;
static const int NUM_CLASSES = 1 + 1; // COCO has 80 classes
static const int MASK_POOL_SIZE = 14;
static const nvinfer1::DimsCHW INPUT_SHAPE{3, 1024, 1024};
struct MRCNNBBox {
float x1, y1, x2, y2;
struct MRCNNMask {
float raw[MASK_POOL_SIZE * 2 * MASK_POOL_SIZE * 2];
struct MRCNNBBoxInfo {
MRCNNBBox box;
int label = -1;
float prob = 0.0f;
MRCNNMask* mask = nullptr;
struct RawDetection {
float y1, x1, y2, x2, class_id, score;
extern "C"
bool NvDsInferParseCustomMrcnnUff (
std::vector<NvDsInferLayerInfo> const &outputLayersInfo,
NvDsInferNetworkInfo const &networkInfo,
NvDsInferParseDetectionParams const &detectionParams,
std::vector<NvDsInferObjectDetectionInfo> &objectList);
std::vector<MRCNNBBoxInfo> decodeOutput(void* detectionsHost, void* masksHost) {
int input_dim_h = INPUT_SHAPE.d[1];
int input_dim_w = INPUT_SHAPE.d[2];
assert(input_dim_h == input_dim_w);
std::vector<MRCNNBBoxInfo> binfo;
RawDetection* detections = reinterpret_cast<RawDetection*>((float*) detectionsHost);
MRCNNMask* masks = reinterpret_cast<MRCNNMask*>((float*) masksHost);
for (int det_id = 0; det_id < DETECTION_MAX_INSTANCES; det_id++) {
RawDetection cur_det = detections[det_id];
MRCNNMask cur_mask = masks[det_id];
int label = (int) cur_det.class_id;
if (label <= 0)
continue;
MRCNNBBoxInfo det;
det.label = label;
det.prob = cur_det.score;
det.box.x1 = cur_det.x1 ;
det.box.y1 = cur_det.y1 ;
det.box.x2 = cur_det.x2 ;
det.box.y2 = cur_det.y2 ;
if (det.box.x2 <= det.box.x1 || det.box.y2 <= det.box.y1)
continue;
det.mask = &cur_mask;
binfo.push_back(det);
return binfo;
extern "C"
bool NvDsInferParseCustomMrcnnUff (std::vector<NvDsInferLayerInfo> const &outputLayersInfo,
std::vector<NvDsInferObjectDetectionInfo> &objectList) {
static int detIndex = -1;
static int maskIndex = -1;
if (detIndex == -1) {
for (unsigned int i = 0; i < outputLayersInfo.size(); i++) {
if (strcmp(outputLayersInfo[i].layerName, "mrcnn_detection") == 0) {
detIndex = i;
break;
std::cerr << "Could not find detection layer buffer while parsing" << std::endl;
return false;
if (maskIndex == -1) {
if (strcmp(outputLayersInfo[i].layerName, "mrcnn_mask/Sigmoid") == 0) {
maskIndex = i;
break;
std::cerr << "Could not find mask layer buffer while parsing" << std::endl;
return false;
float* out_det = (float *) outputLayersInfo[detIndex].buffer;
float* out_mask = (float *) outputLayersInfo[maskIndex].buffer;
std::vector<MRCNNBBoxInfo> binfo = decodeOutput(out_det, out_mask);
for (unsigned int roi_id = 0; roi_id < binfo.size(); roi_id++) {
NvDsInferObjectDetectionInfo object;
object.classId = binfo[roi_id].label;
object.detectionConfidence = binfo[roi_id].prob;
object.left = CLIP(binfo[roi_id].box.x1 * networkInfo.width, 0, networkInfo.width - 1);
object.top = CLIP(binfo[roi_id].box.y1 * networkInfo.height, 0, networkInfo.height - 1);
object.width = CLIP((binfo[roi_id].box.x2 - binfo[roi_id].box.x1) * networkInfo.width, 0, networkInfo.width - 1);
object.height = CLIP((binfo[roi_id].box.y2 - binfo[roi_id].box.y1) * networkInfo.height, 0, networkInfo.height - 1);
for(int raw_id=0; raw_id < MASK_POOL_SIZE * 2 * MASK_POOL_SIZE * 2; raw_id++){
object.mask_cus[raw_id] = binfo[roi_id].mask->raw[raw_id];
objectList.push_back(object);
return true;
CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE(NvDsInferParseCustomMrcnnUff);
Thanks !
