We are using fiber optic cables to connect various RealSense USB cameras to our machine. We need to upgrade the camera firmware, but during actual testing, the firmware upgrade fails when using these fiber optic cables; the kernel logs show numerous “-71” errors, and the camera fails to enter RCE mode.
However, the firmware upgrade works successfully when using the same fiber optic cables on a standard Linux PC. Could there be a signal compatibility issue between the Jetson’s USB controller and the fiber optic module?
We conducted experiments on both JP5 and JP6 and tested Jetson AGX Orin units from different manufacturers; the results were the same in all cases.
