I’m trying to build a basic capture-display application using NvMedia framework, but I’ve encountered some problems that I couldn’t figure out. I’m using DRIVE Software 10.0 and SF3325 camera.
The goal is very simple: just to achieve something like VideoCapture and imshow() in OpenCV. The work flow is ICP->ISP->Output->NvMediaIPPComponentGetOutput()->NvMediaIDPFlip()
I used ipp_raw sample as the reference for building IPP, and img_play sample as reference for setting up IDP. Since I don’t quite understand how the “releaseList” work in IDP, my implementation is different from img_play sample, and this could be one issue.
Below is my code:
// Nvmedia camera
#include <iostream>
#include <dw/core/Context.h>
#include <dw/core/Logger.h>
#include <dw/core/VersionCurrent.h>
#include <dw/interop/streamer/ImageStreamer.h>
#include <dwvisualization/core/Renderer.h>
#include <framework/DriveWorksSample.hpp>
#include <framework/Log.hpp>
#include <framework/WindowGLFW.hpp>
#include <sys/time.h>
#include <limits.h>
#include <unistd.h>
// NvMedia
#include "nvmedia_ipp.h"
#include "nvmedia_icp.h"
#include "nvmedia_isc.h"
#include "nvmedia_idp.h"
#include "nvmedia_2d.h"
#include "img_dev.h"
#include "nvmedia_acp.h"
using namespace std;
void printOrange(const char *format,...) {
printf("\e[38;5;208m");
printf(format);
printf("\n\e[0m");
void printBlue(const char *format,...) {
printf("\e[38;5;87m");
printf(format);
printf("\n\e[0m");
class nvmIPP {
NvMediaDevice *nvmDevice = nullptr;
NvMediaIDP *idpDevice = nullptr;
NvMediaIPPManager *ippManager = nullptr;
NvMediaIPPPipeline *ipp[NVMEDIA_MAX_PIPELINES_PER_MANAGER]; // 16
NvMediaIPPComponent *ippComponents[NVMEDIA_MAX_PIPELINES_PER_MANAGER][NVMEDIA_MAX_COMPONENTS_PER_PIPELINE]; // 16 32
NvMediaIPPComponent *ippIspComponents[NVMEDIA_MAX_PIPELINES_PER_MANAGER];
NvMediaIPPComponent *ippIscComponents[NVMEDIA_MAX_PIPELINES_PER_MANAGER];
NvMediaIPPComponent *ippCAComponents[NVMEDIA_MAX_PIPELINES_PER_MANAGER];
NvMediaIPPComponent *outputComponent[NVMEDIA_MAX_PIPELINES_PER_MANAGER];
NvMediaICPSettings captureSettings = {};
ExtImgDevice *SF3325Camera = nullptr; // ISC
public:
nvmIPP () {
nvmDevice = NvMediaDeviceCreate();
if (!nvmDevice) {cerr << "NvMediaDeviceCreate failed line:" << __LINE__ << "\n"; return;}
ippInit();
ippSetCaptureSettings();
memset(ippComponents, 0, sizeof(ippComponents));
IPPCreateISC();
IPPCreateICPEX();
IPPCreateISP();
IPPCreateCA();
IPPCreateOutput();
IPPAddComponentsToPipeline();
NvMediaStatus status = NVMEDIA_STATUS_ERROR;
status = NvMediaIPPPipelineStart(ipp[0]);
if (status != NVMEDIA_STATUS_OK) {cerr << "NvMediaIPPPipelineStart failed line:" << __LINE__ << "\n"; return;}
status = ExtImgDevStart(SF3325Camera);
if (status != NVMEDIA_STATUS_OK) {cerr << "ExtImgDevStart failed line:" << __LINE__ << "\n"; return;}
IDPInit();
printBlue("nvmIPP instantialized");
~nvmIPP () {
if (idpDevice) NvMediaIDPDestroy(idpDevice);
NvMediaIPPPipelineStop(ipp[0]);
if (nvmDevice) NvMediaDeviceDestroy(nvmDevice);
if (SF3325Camera) ExtImgDevDeinit(SF3325Camera);
printBlue("nvmIPP: byebye");
bool ippInit () {
printBlue("ippInit");
memset(ippIspComponents, 0, sizeof(ippIspComponents));
memset(ippIscComponents, 0, sizeof(ippIscComponents));
ExtImgDevParam extImgDevParam = {};
extImgDevParam.desAddr = 0x29;
extImgDevParam.brdcstSerAddr = 0x40; // Address of serializer device. 0x40 ddpx-a
extImgDevParam.brdcstSensorAddr = 0x10; // Address of sensor device. 0x10: AR0231
extImgDevParam.e2pPhysicalAddr = 0;
extImgDevParam.sensorAddr[0] = extImgDevParam.brdcstSensorAddr + 1;
extImgDevParam.sensorIdentifier[0] = (char *)("");
extImgDevParam.i2cDevice = 0; // 0: NVMEDIA_ISC_I2C_BUS_0
extImgDevParam.moduleName = (char *)("ref_max96712_96705_ar0231rccbsf3324bae");
extImgDevParam.board = (char *)("ddpx-a");
extImgDevParam.resolution = (char *)("1920x1208");
extImgDevParam.sensorsNum = 1;
extImgDevParam.inputFormat = (char *)("raw12");
extImgDevParam.interface = (char *)("csi-a");
ExtImgDevMapInfo camMap;
extImgDevParam.camMap = &camMap;
extImgDevParam.camMap->enable = CAM_ENABLE_DEFAULT;
extImgDevParam.camMap->mask = CAM_MASK_DEFAULT;
extImgDevParam.camMap->csiOut = CSI_OUT_DEFAULT;
extImgDevParam.enableEmbLines = NVMEDIA_TRUE;
extImgDevParam.initialized = NVMEDIA_FALSE;
extImgDevParam.enableSimulator = NVMEDIA_FALSE;
extImgDevParam.enableVirtualChannels = NVMEDIA_FALSE;
extImgDevParam.slave = NVMEDIA_FALSE;
SF3325Camera = ExtImgDevInit(&extImgDevParam);
if (!SF3325Camera) {cerr << "extImgDevice init failed line:" << __LINE__ << "\n"; return false;}
return true;
bool ippSetCaptureSettings() {
printBlue("ippSetCaptureSettings");
ExtImgDevProperty *sf3325property = &SF3325Camera->property;
captureSettings.interfaceType = sf3325property->interface;
captureSettings.inputFormat.inputFormatType = sf3325property->inputFormatType;
captureSettings.inputFormat.bitsPerPixel = sf3325property->bitsPerPixel;
NVM_SURF_FMT_DEFINE_ATTR(surfFormatAttrs);
NVM_SURF_FMT_SET_ATTR_RAW(surfFormatAttrs,RGGB,UINT,12,PL)
surfFormatAttrs[NVM_SURF_ATTR_COMPONENT_ORDER].value += sf3325property->pixelOrder;
captureSettings.startX = 0;
captureSettings.startY = 0;
captureSettings.surfaceType = NvMediaSurfaceFormatGetType(surfFormatAttrs, NVM_SURF_FMT_ATTR_MAX);
captureSettings.width = sf3325property->width;
captureSettings.height = sf3325property->height;
captureSettings.embeddedDataType = sf3325property->embDataType;
captureSettings.embeddedDataLines = sf3325property->embLinesTop + sf3325property->embLinesBottom;
captureSettings.interfaceLanes = 2; // CSI interface lanes 1,2,4
captureSettings.phyMode = sf3325property->phyMode;
captureSettings.tpgEnable = sf3325property->tpgEnable;
captureSettings.pixelFrequency = sf3325property->pixelFrequency;
ippManager = NvMediaIPPManagerCreate(NVMEDIA_IPP_VERSION_INFO, nvmDevice);
if (!ippManager) {cerr << "NvMediaIPPManagerCreate failed line:" << __LINE__ << "\n"; return false;}
ipp[0] = NvMediaIPPPipelineCreate(ippManager);
return true;
NvMediaStatus IPPCreateISC() {
printBlue("IPPCreateISC");
NvMediaIPPIscComponentConfig iscComponentConfig = {};
iscComponentConfig.iscSensorDevice = SF3325Camera->iscSensor[0];
ippIscComponents[0] = NvMediaIPPComponentCreateNew(ipp[0], NVMEDIA_IPP_COMPONENT_ISC, nullptr, &iscComponentConfig);
if (!ippIscComponents[0]) {cerr << "NvMediaIPPComponentCreateNew() failed line:" << __LINE__ << "\n"; return NVMEDIA_STATUS_ERROR;}
return NVMEDIA_STATUS_OK;
NvMediaStatus IPPCreateICPEX() {
printBlue("IPPCreateICPEX");
NvMediaICPSettingsEx icpSettingsEx = {};
NvMediaIPPBufferPoolParamsNew *bufferPools[5], bufferPool={};
// IPPSetICPBufferPoolConfig
bufferPool.width = captureSettings.width;
bufferPool.height = captureSettings.height;
bufferPool.portType = NVMEDIA_IPP_PORT_IMAGE_1;
bufferPool.poolBuffersNum = 3;
NVM_SURF_FMT_SET_ATTR_RAW(surfFormatAttrs,RGGB,UINT,12,PL);
bufferPool.surfaceType = NvMediaSurfaceFormatGetType(surfFormatAttrs, NVM_SURF_FMT_ATTR_MAX);
bufferPool.imagesCount = 1;
bufferPool.surfAllocAttrs[0].type = NVM_SURF_ATTR_WIDTH;
bufferPool.surfAllocAttrs[0].value = bufferPool.width;
bufferPool.surfAllocAttrs[1].type = NVM_SURF_ATTR_HEIGHT;
bufferPool.surfAllocAttrs[1].value = bufferPool.height;
bufferPool.surfAllocAttrs[2].type = NVM_SURF_ATTR_EMB_LINES_TOP;
bufferPool.surfAllocAttrs[2].value = SF3325Camera->property.embLinesTop;
bufferPool.surfAllocAttrs[3].type = NVM_SURF_ATTR_EMB_LINES_BOTTOM;
bufferPool.surfAllocAttrs[3].value = SF3325Camera->property.embLinesBottom;
bufferPool.surfAllocAttrs[4].type = NVM_SURF_ATTR_CPU_ACCESS;
bufferPool.surfAllocAttrs[4].value = NVM_SURF_ATTR_CPU_ACCESS_CACHED;
bufferPool.surfAllocAttrs[5].type = NVM_SURF_ATTR_ALLOC_TYPE;
bufferPool.surfAllocAttrs[5].value = NVM_SURF_ATTR_ALLOC_ISOCHRONOUS;
bufferPool.numSurfAllocAttrs = 6;
// end IPPSetICPBufferPoolConfig
icpSettingsEx.interfaceType = captureSettings.interfaceType;
icpSettingsEx.interfaceLanes = captureSettings.interfaceLanes;
icpSettingsEx.numVirtualGroups = 1;
icpSettingsEx.phyMode = captureSettings.phyMode;
icpSettingsEx.virtualGroups[0].numVirtualChannels = 1;
icpSettingsEx.virtualGroups[0].virtualChannels[0].virtualChannelIndex = SF3325Camera->property.vcId[0];
icpSettingsEx.virtualGroups[0].virtualChannels[0].icpSettings = captureSettings;
bufferPools[0] = &bufferPool;
bufferPools[1] = NULL;
ippComponents[0][0] = NvMediaIPPComponentCreateNew(ipp[0], NVMEDIA_IPP_COMPONENT_ICP_EX, bufferPools, &icpSettingsEx);
if (!ippComponents[0][0]) {cerr << "NvMediaIPPComponentCreateNew() failed line:" << __LINE__ << "\n"; return NVMEDIA_STATUS_ERROR;}
NvMediaStatus IPPCreateISP() {
printBlue("IPPCreateISP");
NvMediaIPPIspComponentConfig ispComponentConfig = {};
NvMediaIPPBufferPoolParamsNew *bufferPools[4], bufferPool, bufferPool2;
memset(&ispComponentConfig, 0, sizeof(ispComponentConfig));
ispComponentConfig.ispSelect = NVMEDIA_ISP_SELECT_ISP_A;
bufferPools[1] = &bufferPool2; // stats pool
bufferPools[2] = NULL;
memset(&bufferPool, 0, sizeof(bufferPool));
NVM_SURF_FMT_SET_ATTR_YUV(surfFormatAttrs,YUV,420,SEMI_PLANAR,UINT,8,BL);
bufferPool.surfAllocAttrs[2].type = NVM_SURF_ATTR_CPU_ACCESS;
bufferPool.surfAllocAttrs[2].value = NVM_SURF_ATTR_CPU_ACCESS_CACHED;
bufferPool.surfAllocAttrs[3].type = NVM_SURF_ATTR_COLOR_STD_TYPE;
bufferPool.surfAllocAttrs[3].value = NVM_SURF_ATTR_COLOR_STD_REC709_ER;
bufferPool.numSurfAllocAttrs = 4;
// stats port
memset(&bufferPool2, 0, sizeof(bufferPool2));
bufferPool2.portType = NVMEDIA_IPP_PORT_STATS_1;
bufferPool2.poolBuffersNum = 3;
ippIspComponents[0] = NvMediaIPPComponentCreateNew(ipp[0], NVMEDIA_IPP_COMPONENT_ISP, bufferPools, &ispComponentConfig);
ippComponents[0][1] = ippIspComponents[0];
if (!ippComponents[0][1]) {cerr << "NvMediaIPPComponentCreateNew() failed line:" << __LINE__ << "\n"; return NVMEDIA_STATUS_ERROR;}
NvMediaStatus IPPCreateCA() {
printBlue("IPPCreateCA");
NvMediaIPPControlAlgorithmComponentConfig caConfig = {};
memset(&caConfig, 0, sizeof(caConfig));
NvMediaIPPBufferPoolParamsNew *bufferPools[4], bufferPool;
NvMediaIPPPluginFuncs nvpluginFuncs = {
.createFunc = nullptr,
.destroyFunc = nullptr,
.processExFunc = nullptr
caConfig.width = captureSettings.width;
caConfig.height = captureSettings.height;
// FIXME: ulgy conversion from uint_32t to NvMediaRawPixelOrder
// caConfig.pixelOrder = (NvMediaRawPixelOrder)SF3325Camera->property.pixelOrder;
caConfig.pixelOrder = NVMEDIA_RAW_PIXEL_ORDER_RCCB;
caConfig.bitsPerPixel = SF3325Camera->property.bitsPerPixel;
caConfig.iscSensorDevice = SF3325Camera->iscSensor[0];
caConfig.pluginFuncs = &nvpluginFuncs;
bufferPools[1] = nullptr;
bufferPool.portType = NVMEDIA_IPP_PORT_SENSOR_CONTROL_1;
ippCAComponents[0] = NvMediaIPPComponentCreateNew(ipp[0], NVMEDIA_IPP_COMPONENT_ALG, bufferPools, &caConfig);
if (!ippCAComponents[0]) {cerr << "NvMediaIPPComponentCreateNew() failed line:" << __LINE__ << "\n"; return NVMEDIA_STATUS_ERROR;}
NvMediaStatus IPPCreateOutput() {
printBlue("IPPCreateOutput");
outputComponent[0] = NvMediaIPPComponentCreateNew(ipp[0], NVMEDIA_IPP_COMPONENT_OUTPUT, NULL, NULL);
ippComponents[0][2] = outputComponent[0];
if (!ippComponents[0][2]) {cerr << "NvMediaIPPComponentCreateNew() failed line:" << __LINE__ << "\n"; return NVMEDIA_STATUS_ERROR;}
NvMediaStatus IPPAddComponentsToPipeline() {
printBlue("IPPAddComponentsToPipeline");
status = NvMediaIPPComponentAttach(ipp[0], ippComponents[0][0], ippIspComponents[0], NVMEDIA_IPP_PORT_IMAGE_1);
status = NvMediaIPPComponentAttach(ipp[0], ippIspComponents[0], outputComponent[0], NVMEDIA_IPP_PORT_IMAGE_1);
status = NvMediaIPPComponentAttach(ipp[0], ippIspComponents[0], ippCAComponents[0], NVMEDIA_IPP_PORT_STATS_1);
status = NvMediaIPPComponentAttach(ipp[0], ippCAComponents[0], ippIscComponents[0], NVMEDIA_IPP_PORT_SENSOR_CONTROL_1);
if (status != NVMEDIA_STATUS_OK) {cerr << "NvMediaIPPComponentAttach() failed line:" << __LINE__ << "\n"; return NVMEDIA_STATUS_ERROR;}
NvMediaStatus IDPInit () {
NvMediaIDPDeviceParams queryOutputs[3];
NvMediaDispAttributes attributes = {};
int outputDeviceNum = 0;
if (NvMediaIDPQuery(&outputDeviceNum, queryOutputs) != NVMEDIA_STATUS_OK) {printOrange("NvMediaIDPQuery failed"); return NVMEDIA_STATUS_ERROR;}
idpDevice = NvMediaIDPCreate(queryOutputs[0].displayId, 1, nullptr, queryOutputs[0].enabled);
if (!idpDevice) {printOrange("NvMediaIDPCreate failed"); return NVMEDIA_STATUS_ERROR;}
attributes.depth = 1;
NvMediaIDPSetAttributes(idpDevice, NVMEDIA_DISP_ATTR_SET_DEPTH, &attributes);
NvMediaStatus IDPDisplayImage (NvMediaImage *imgToDisplay) {
NvMediaImage *releaseFrames[9] = {0};
NvMediaImage **releaseList = &releaseFrames[0];
NvMediaStatus status = NvMediaIDPFlip(idpDevice, imgToDisplay, NULL, NULL, releaseList, NULL);
if (status != NVMEDIA_STATUS_OK) {printOrange("NvMediaIDPFlip failed");}
bool onProcess () {
NvMediaIPPComponentOutput ippOutput = {};
NvMediaStatus status = NvMediaIPPComponentGetOutput(outputComponent[0], 100, &ippOutput); // blocking func
cout << "ippOutput.image " << ippOutput.image << " type " << ippOutput.image->type << " width " << ippOutput.image->width << " height " << ippOutput.image->height << " imageCount " << ippOutput.image->imageCount << " captureTimeStamp.sec " << ippOutput.image->captureTimeStamp.tv_sec << " colorStd " << ippOutput.image->colorStd << endl;
if (status != NVMEDIA_STATUS_OK) {printOrange("NvMediaIPPComponentGetOutput failed");}
IDPDisplayImage(ippOutput.image);
status = NvMediaIPPComponentReturnOutput(outputComponent[0], &ippOutput);
return true;
int main(int argc, const char *argv[]) {
argc = argc;
argv = argv;
nvmIPP app = nvmIPP();
for (size_t i=0; i<30; i++) {
app.onProcess();
return 0;
And here’s the output:
ippInit
nvmedia isc: GetCameraPowerControlLevel: 936: Camera power control library: NVCCP
Max96712 Rev 2 detected!
MAX96712: Enable periodic AEQ on Link 0
MAX96705: Pre-emphasis set to 0xaa
Sensor AR0231 RCCB Rev7 detected!
IPPCreateISC
IPPCreateICPEX
IPPCreateISP
IPPCreateCA
No autocontrol plugin, default settings will be used
IPPCreateOutput
ippOutput.image 0xe53060 type 35 width 1920 height 1208 imageCount 1 captureTimeStamp.sec 1583197290 colorStd 5
nvmDisplayFlipQueueDisplayYUV: Flip failed
ippOutput.image 0xe53850 type 35 width 1920 height 1208 imageCount 1 captureTimeStamp.sec 1583197290 colorStd 5
ippOutput.image 0xe54040 type 35 width 1920 height 1208 imageCount 1 captureTimeStamp.sec 1583197290 colorStd 5
ippOutput.image 0xe53060 type 35 width 1920 height 1208 imageCount 1 captureTimeStamp.sec 1583197291 colorStd 5
ippOutput.image 0xe53850 type 35 width 1920 height 1208 imageCount 1 captureTimeStamp.sec 1583197291 colorStd 5
ippOutput.image 0xe54040 type 35 width 1920 height 1208 imageCount 1 captureTimeStamp.sec 1583197291 colorStd 5
nvmIPP: byebye
It seems the capturing part is working because NvMediaIPPComponentGetOutput() did not raise any error, and ippOutput.image(NvMediaImage) contains reasonable values. However, I’m not 100% sure the issue is with IDP. I tried to feed the output image into NvMedia IEP to encode it, but got segmentation fault. I also tried to replace the display part of ipp_raw sample (which use egl stream to display) with IDP, and got similar error.
Could you provide any suggestion on how to debug this?
Thank you!
