I’m working with gstreamer 1.18 (built with gst-build). I’m trying to use the lossless preset of the nvh265enc plugin. With the following pipeline, I can successfully use all presets except the lossless ones (lossless (6) and lossless-hp (7)):
gst-launch-1.0 videotestsrc ! nvh265enc preset=6 ! h265parse ! nvh265dec ! glimagesink
Whenever I set preset
to 6 or 7, I get the following error.
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Got context from element 'sink': gst.gl.GLDisplay=context, gst.gl.GLDisplay=(GstGLDisplay)"\(GstGLDisplayX11\)\ gldisplayx11-0";
Got context from element 'nvh265dec0': gst.cuda.context=context, gst.cuda.context=(GstCudaContext)"\(GstCudaContext\)\ cudacontext0", cuda-device-id=(int)0;
ERROR: from element /GstPipeline:pipeline0/GstNvH265Enc:nvh265enc0: Could not configure supporting library.
Additional debug info:
../subprojects/gst-plugins-bad/sys/nvcodec/gstnvbaseenc.c(1712): gst_nv_base_enc_set_format (): /GstPipeline:pipeline0/GstNvH265Enc:nvh265enc0:
Failed to init encoder: 8
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
Freeing pipeline ...
What’s more puzzling is that the lossless preset works with the samples from the Nvidia Video Codec SDK 9.
Did I miss any additional configuration?
(also asked here nvidia - Unable to use the lossless preset of the nvh265enc gstreamer plugin - Stack Overflow just in case)
