Unbale to view the video feed?
• Hardware Platform (/ GPU) 3070rtx
• DeepStream Version 6.2
• TensorRT Version - 8.5
• NVIDIA GPU Driver Version (valid for GPU only) 525
Hi
This is my pipeline
gst-launch-1.0 uridecodebin uri=rtsp://admin:pot123@10.90.65.182/stream0 ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvvideoconvert ! nvmultistreamtiler rows=1 columns=1 width=720 height=576 ! nvdsosd ! nvvideoconvert ! capsfilter caps=“video/x-raw(memory:NVMM),format=I420” ! nvv4l2h264enc ! h264parse ! rtph264pay ! udpsink host=0.0.0.0 port=5000
i am not able to see the feed so can you help me to fix the error
error
Setting pipeline to PAUSED …
0:00:00.059224321 5369 0x556f88632720 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2h264enc0:sink Unable to try format: Unknown error -1
0:00:00.059235700 5369 0x556f88632720 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2h264enc0:sink Could not probe minimum capture size for pixelformat YM12
0:00:00.059238640 5369 0x556f88632720 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2h264enc0:sink Unable to try format: Unknown error -1
Can you try NV12 format ?
error
0:00:00.044399856 13816 0x55670ef8def0 ERROR GST_PIPELINE grammar.y:738:gst_parse_perform_link: could not link nvvideoconvert1 to capsfilter0
0:00:00.044439870 13816 0x55670ef8def0 ERROR GST_PIPELINE grammar.y:738:gst_parse_perform_link: could not link capsfilter0 to nvv4l2h264enc0
If you just run the following command line, Can save file normally ?
gst-launch-1.0 uridecodebin uri="your rtsp uri" ! "video/x-raw(memory:NVMM),format=NV12" ! nvv4l2h264enc ! h264parse ! filesink location=1.h264
