I have Nvidia 1660ti and amd ryzen 7 3750h in my laptop, I am using Ubuntu 20.04 but somehow I am not able to use the Nvidia Card.
- when i do a
sudo lshw -c video
i get this*-display UNCLAIMED description: VGA compatible controller product: TU116M [GeForce GTX 1660 Ti Mobile] vendor: NVIDIA Corporation physical id: 0 bus info: pci@0000:01:00.0 version: a1 width: 64 bits clock: 33MHz capabilities: pm msi pciexpress vga_controller cap_list configuration: latency=0 resources: memory:f6000000-f6ffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:f000(size=128) memory:f7000000-f707ffff *-display description: VGA compatible controller product: Picasso vendor: Advanced Micro Devices, Inc. [AMD/ATI] physical id: 0 bus info: pci@0000:05:00.0 version: c1 width: 64 bits clock: 33MHz capabilities: pm pciexpress msi msix vga_controller bus_master cap_list configuration: driver=amdgpu latency=0 resources: irq:24 memory:e0000000-efffffff memory:f0000000-f01fffff ioport:c000(size=256) memory:f7500000-f757ffff
- I have installed
nvidia-drives-460
from ubuntu software and it shows that 1 proprietary driver is in use. but lshw shows no driver :( -
nvidia-smi
shows this:NVIDIA-SMI has failed because it couldnt communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
prime-select query
printsnvidia
- attached a bug report for your reference
nvidia-bug-report.log (143.5 KB)
I am also not able to use my secondary monitor because of this I feel.
please help.
