jetson Orin NX platform, JetPack version is Jetson Linux 36.4 (part of JetPack 6.1), Two cameras using mipi cables directly into the jetson
The driver can be loaded and matched successfully:
pcai@pcai-desktop:~$ i2cdetect -y -r 9
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
pcai@pcai-desktop:~$ i2cdetect -y -r 10
pcai@pcai-desktop:~$ ls /dev/video*
/dev/video0 /dev/video1
root@pcai-desktop:~# v4l2-ctl --list-devices
NVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):
/dev/media0
vi-output, iimx415 10-0037 (platform:tegra-capture-vi:0):
/dev/video1
vi-output, iimx415 9-0037 (platform:tegra-capture-vi:2):
/dev/video0
However, when I enter the command for mobile phone data frames(Even when I use video1, the scenario is the same.):
v4l2-ctl -d /dev/video0 -V --set-ctrl bypass_mode=0 --stream-mmap
v4l2-ctl -d /dev/video1 -V --set-ctrl bypass_mode=0 --stream-mmap
Increasing the clock doesn’t work either; dmesg and trace remain unchanged.
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
This is my source file:
imx415-overlay.dts.txt (2.9 KB)
imx415.dtsi.txt (11.8 KB)
imx415.c.txt (16.2 KB)
