ever since I included the atomicadd function in my GPU code I’ve not been able to compile the code to use emulation mode.
I get the following error:
Undefined reference to `atomicaddd’
I’m using the function to accumulate double precision values in to a double precision array. It works perfectly on the GPU but I need to use the emulation mode to debug another part of the code.
Looks like our compiler team missed adding this one to the emulation library. We’ll get it into 13.0. In the meantime we can send you an object file you can link with. Let me know if you want to wait or if you want me to send you the file.
Actually, it looks like we did get this into 12.10. Are you able to update your compiler version? If not, I can send you the object (I can get your email address).
I managed to get the 12.10 update and have installed it. I’m not longer getting the
undefined reference to > atomicadd
error when I compile but the error most certainly hasn’t been fixed. When I try to run my code in emulation mode the result I get is zero. So I presume that although the compiler is recognizing the function it still doesn’t know what to do with it when in emulation mode and so nothing gets added in to my array.
You’ll have to show me how you use it. It works for me:
brentl@woodchuck:~/simple/cuda/qa> pgf90 -V12.10 -Mcuda=emu atomd2.cuf
brentl@woodchuck:~/simple/cuda/qa> ./a.out
32896.00000000000 32896.00000000000
TEST PASSED
brentl@woodchuck:~/simple/cuda/qa> cat atomd2.cuf
module atomictests
contains
attributes(global) subroutine testatomicdadd( a )
real8, device :: a
real8 r
r = dble((blockIdx%x-1) * blockDim%x + threadIdx%x)
istat = atomicadd(a, r)
return
end subroutine testatomicdadd
end module atomictests
program t
use cudafor
use atomictests
real8, device :: r
real8 x
n = 256
r = 0
call testatomicdadd<<<4,n/4>>> ®
x = r
print ,x,dble(n(n+1)/2)
if (x .eq. dble(n*(n+1)/2)) then
print *,“TEST PASSED”
else
print *,“TEST FAILED”
endif
end
