I’m getting strange linking errors with the following code:
#include "gstnvdsmeta.h"
auto type = nvds_meta_api_get_type();
[build] ../AdInter/libgstadinter.so: undefined reference to `nvds_meta_api_get_type'
[build] collect2: error: ld returned 1 exit status
My library is yet linked to both libnvds_meta.so
and libnvdsgst_meta.so
Oddly, in the same file, nvds_meta_get_info
and gst_buffer_get_nvds_meta
also don’t work, but gst_buffer_get_nvds_batch_meta
works !
Any idea why this error occurs ?
• Hardware Platform : Jetson
• DeepStream Version : 5 (it was also the case on DS.4)
• JetPack Version 4.4 DP
• TensorRT Version 7.1
Amycao
May 29, 2020, 2:23pm
#3
Hi
You need to link metada library to your code.
Thanks for your response, but you might want to read over my question.
As I said, my code is already linked to the metadata library.
The gst_buffer_get_nvds_batch_meta
function even works !
But not nvds_meta_get_info
or gst_buffer_get_nvds_meta
, which are also declared in gstnvdsmeta.h
Bump.
Can you please try to reproduce the behavior ? I’m pretty sure this is a bug.
Amycao
June 8, 2020, 8:22am
#6
Hi
Could you specify how could I repro your issue? Is that possible to share one workable test code to repro?
Of course:
Here’s main.cpp
#include <gst/gst.h>
int
main (int argc, char *argv[])
// does compile
GstBuffer* buf = gst_buffer_new();
gst_buffer_get_nvds_batch_meta(buf);
// does not compile (linking issue)
nvds_meta_get_info();
return 0;
And the corresponding Makefile
(adapted from deepstream-user-metadata-test
APP:= nvds-meta-test
TARGET_DEVICE = $(shell gcc -dumpmachine | cut -f1 -d -)
NVDS_VERSION:=5.0
INCLUDES_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/sources/includes
LIB_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/lib/
ifeq ($(TARGET_DEVICE),aarch64)
CFLAGS:= -DPLATFORM_TEGRA
endif
SRCS:= $(wildcard *.c)
INCS:= $(wildcard *.h)
PKGS:= gstreamer-1.0
OBJS:= $(SRCS:.c=.o)
CFLAGS+= -I$(INCLUDES_INSTALL_DIR)
CFLAGS+= `pkg-config --cflags $(PKGS)`
LIBS:= `pkg-config --libs $(PKGS)`
LIBS+= -L$(LIB_INSTALL_DIR) -lnvdsgst_meta -lnvds_meta \
-Wl,-rpath,$(LIB_INSTALL_DIR)
all: $(APP)
%.o: %.c $(INCS) Makefile
$(CC) -c -o $@ $(CFLAGS) $<
$(APP): $(OBJS) Makefile
$(CC) -o $(APP) $(OBJS) $(LIBS)
clean:
rm -rf $(OBJS) $(APP)
Amycao
June 9, 2020, 4:07am
#8
Hi
I have reproed your issue, will file one bug, thanks for your patience.
Thanks !
Don’t forget that it’s not only nvds_meta_get_info
, but also gst_buffer_get_nvds_meta
, and maybe other functions I didn’t try.
