Thanks for your reply, but I didn’t really get it from your answer. I would like to give you a full picture to understand my question.
I was compiling ATF(arm-trusted-firmware) and TOS(Trusted OS) from host, and compiling TAs(Trusted Applications) as well. Followings are the compiling commands.
compile.sh
export CROSS_COMPILE=/home/lgiori/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
export CROSS_COMPILE_AARCH64=/home/lgiori/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
export CROSS_COMPILE_ARM=/home/lgiori/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-
## Compile ATF and TOS
cd /trusty/atf/arm-trusted-firmware
make BUILD_BASE=./t194ref CROSS_COMPILE="${CROSS_COMPILE_AARCH64}" DEBUG=0 LOG_LEVEL=20 PLAT=tegra SPD=trusty TARGET_SOC=t194 V=0
cd /trusty/trusty/trusty
make t186 PROJECT=t186 TARGET=t186 BUILDROOT=./t194ref \ TOOLCHAIN_PREFIX="${CROSS_COMPILE_AARCH64}" \ ARCH_arm_TOOLCHAIN_PREFIX="${CROSS_COMPILE_ARM}" \ ARCH_arm64_TOOLCHAIN_PREFIX="${CROSS_COMPILE_AARCH64}" \ DEBUG=0 DEBUG_LVL=0 DEFAULT_OTE_APP_DEBUGLEVEL=1 NOECHO=@ \ TRUSTY_VARIANT=l4t-public TRUSTY_MULTI_GUEST_CONFIGURATION= \ TARGET_SOC=t194
## Copy Generate files into
cp /trusty/atf/arm-trusted-firmware/t194ref/tegra/t194/release/bl31.bin /home/lgiori/l4t-gcc/Linux_for_Tegra/nv_tegra/tos-scripts
cp /trusty/trusty/trusty/t194ref/build-t186/lk.bin /home/lgiori/l4t-gcc/Linux_for_Tegra/nv_tegra/tos-scripts
## Generate TOS image
cd /home/lgiori/l4t-gcc/Linux_for_Tegra/nv_tegra/tos-scripts
./gen_tos_part_img.py --monitor bl31.bin --os lk.bin tos_t194.img
## Replace the TOS image
cp tos_t194.img /home/lgiori/l4t-gcc/Linux_for_Tegra/bootloader/
makefile for TOS
# the above include may override LKROOT and LKINC to allow external
# directories to be included in the build
-include lk_inc.mk
LKMAKEROOT ?= .
LKROOT ?= .
LKINC ?=
BUILDROOT ?= .
DEFAULT_PROJECT ?=
TOOLCHAIN_PREFIX ?=
# check if LKROOT is already a part of LKINC list and add it only if it is not
ifneq ($(findstring $(LKROOT),$(LKINC)), $(LKROOT))
LKINC := $(LKROOT) $(LKINC)
endif
export LKMAKEROOT
export LKROOT
export LKINC
export BUILDROOT
export DEFAULT_PROJECT
export TOOLCHAIN_PREFIX
# vaneer makefile that calls into the engine with lk as the build root
# if we're the top level invocation, call ourselves with additional args
$(MAKECMDGOALS) _top:
@$(MAKE) -C $(LKMAKEROOT) -rR -f $(LKROOT)/engine.mk $(addprefix -I,$(LKINC)) $(MAKECMDGOALS)
.PHONY: _top
lk_inc.mk
LKROOT ?= lk/common
LKINC ?= lk/trusty \
lk/common \
tegra/public \
app \
external \
external/headers \
lib \
device/nvidia/t186
ifneq ($(wildcard tegra/partner),)
LKINC += tegra/partner \
device/nvidia/t210
endif
ifneq ($(wildcard tegra/private),)
LKINC += tegra/private
endif
# Build variants that use the ote-apps with an OTE-TIPC wrapper.
ifneq ($(filter embedded-v2% android% mods% sim% l4t-partner-ote, $(TRUSTY_VARIANT)),)
OTEROOT ?= $(TEGRA_TOP)/ote
LKINC += $(OTEROOT)
endif
Check the source in LKROOT = lk/common
, there is math.h
and its source code:
tianchi@securitylab:$ ls /trusty/trusty/trusty/lk/common/lib/libm/
e_acos.c e_asinf.c e_fmod.c e_powf.c e_sqrt.c k_cos.c k_sin.c k_tanf.c s_atan.c s_copysignf.c s_fabs.c s_round.c s_sin.c s_tanf.c
e_acosf.c e_atan2.c e_log.c e_rem_pio2.c e_sqrtf.c k_cosf.c k_sinf.c math_private.h s_ceil.c s_cos.c s_fabsf.c s_scalbn.c s_sinf.c s_trunc.c
e_asin.c e_exp.c e_pow.c e_rem_pio2f.c include k_rem_pio2.c k_tan.c rules.mk s_copysign.c s_cosf.c s_floor.c s_scalbnf.c s_tan.c
Here is a simplified version of rule.mk for my programs:
LOCAL_DIR := $(GET_LOCAL_DIR)
MODULE := $(LOCAL_DIR)
MODULE_INCLUDES += \
$(LOCAL_DIR)/include
MODULE_SRCS += \
$(LOCAL_DIR)/ipc.c \
#( Other source codes here) ...
$(LOCAL_DIR)/utils.c \
$(LOCAL_DIR)/main.c \
$(LOCAL_DIR)/manifest.c \
/trusty/trusty/trusty/lk/common/lib/libm/e_sqrtf.c # without this line, the included math.h would not offer a refrence to *sqrtf*.
MODULE_DEPS += \
app/trusty \
lib/libc-trusty
include make/module.mk
Without /trusty/trusty/trusty/lk/common/lib/libm/e_sqrtf.c
in MODULE_SRCS
, sqrtf
won’t be referenced correctly. Here is what I don’t understand.
Since we have linked lib/common
in makefile, why sqrtf
or sqrt
or other library functions cannot be referenced directly ? Why do we need add /trusty/trusty/trusty/lk/common/lib/libm/e_sqrtf.c
in makefile, or do I miss something about the link of math library ?
