mpirun_util.o(.text+0x36): In function vedit_str': : undefined reference to va_copy’
mpirun_util.o(.text+0xcc): In function vedit_str': : undefined reference to va_copy’
va_copy - should be macro in stdarg.h file. PGI compiler use own stdarg.h file and it doesn’t have the macro definition.
So I guess it is some compiler issue ?
Could it be a configuration issue? Make sure you remove previous configuration and then reconfigure with pgcc/pgf77/pgf90/pgcpp. I would use the latest MVAPICH and also latest PGI compilers if possible.
I installed it as part of OFED and also I installed it manually with my own scripts (I’m mvapich maintainer in OFED distribution) . All the installation process done on clean code base.
More info:
With the same Redhat AS 4 UP6 and the same pgi version 7.0.7 BUT on
x86_64 platform the same code compiles without any problem and on i686 it fails (other machine with the same install)
In $PGI/linux86_64//include/stdarg.h we have va_copy macro defined.
And in $PGI/linux86//include/stdarg.h the macro is missed ! So I guess it is root cause of the failure, is not it ?
