Details of Setup
- Hardware Platform (Jetson / GPU): GPU
- DeepStream Version: 7.1.0
- TensorRT Version: 10.7.0.23-1+cuda12.6 amd64
- NVIDIA GPU Driver Version (valid for GPU only): 560.35.03 (CUDA Version: 12.6)
Issue Type: Bug
Description of Issue:
I encounter a symbol lookup error
when running a custom-built DeepStream YOLO plugin. The error log is as follows:
deepstream-app: symbol lookup error: /home/ds_tracker/workspace/DeepStream-Yolo/build/libnvdsinfer_custom_impl_Yolo.so: undefined symbol: _ZNSt12experimental10filesystem2v17__cxx114path14_M_split_cmptsEv
The issue arises during the engine creation phase:
NvDsInferContext[UID 1]: Trying to create engine from model files
Configuration Details:
The relevant configuration files are:
deepstream_app_config.txt
:config-file
points toconfig_infer_primary_yoloV11.txt
.- Full configuration:
[application] enable-perf-measurement=1 perf-measurement-interval-sec=5 ...
Full file attached for reference.
:- ONNX file:
yolo11m_yolo11.onnx
- Custom library path:
- Custom functions:
parse-bbox-func-name
: NvDsInferParseYoloengine-create-func-name
: NvDsInferYoloCudaEngineGet
- ONNX file:
Reproduction Steps:
- Build the custom library
using the provided source code. - Configure the application using the attached files.
- Run
deepstream-app -c deepstream_app_config.txt
Additional Notes:
- The application halts at the engine-building stage.
- I suspect the issue might be linked to C++ standard library compatibility, as the undefined symbol references experimental filesystem.
Request:
Could you provide guidance on resolving the undefined symbol
issue? Specifically:
- Are there specific build flags or dependencies required for
? - Does DeepStream 7.1 have compatibility constraints with certain GCC versions or C++ filesystem implementations?
[application]
[tiled-display]
enable=0
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=3
uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4
num-sources=1
gpu-id=0
cudadec-memtype=0
drop-frame-interval=0 # Add this
eos-timeout=5000000 # Add this (5 seconds timeout)
[sink0]
enable=1
type=3
sync=1
gpu-id=0
nvbuf-memory-type=0
output-file=output.mp4
[osd]
enable=0
gpu-id=0
border-width=5
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
batch-size=1
batched-push-timeout=40000
[primary-gie]
enable=1
gpu-id=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV11.txt
[property]
gpu-id=0
net-scale-factor=1
model-color-format=1
onnx-file=yolo11m_yolo11.onnx
#model-engine-file=model_b1_gpu0_fp32.engine
#int8-calib-file=calib.table
labelfile-path=labels.txt
batch-size=1
network-mode=0
num-detected-classes=80
interval=0
gie-unique-id=1
process-mode=1
network-type=0
cluster-mode=2
maintain-aspect-ratio=1
symmetric-padding=0
#workspace-size=2000
parse-bbox-func-name=NvDsInferParseYolo
#parse-bbox-func-name=NvDsInferParseYoloCuda
custom-lib-path=/home/ds_tracker/workspace/DeepStream-Yolo/build/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
[class-attrs-all]
nms-iou-threshold=0.45
pre-cluster-threshold=0.25
topk=300
