Hi all,
consider this test code, which works fine:
__device__ void foo () {}
__global__ void bar() {
foo();
When moving the implementation of foo
into a different file, the compilation (using -c
) fails:
extern __device__ void foo();
foo();
The error message is ptxas fatal : Unresolved extern function '_Z3foov'
The error does not occur if I change the global
keyword to device
In an old thread, I read the suggestion that you need to use extern "C"
, but this just changes the missing symbol from _Z3foov
to foo
Do I have misunderstanding about how device
and global
functions work together, or is this a bug?
Regards,
Christian
