Undefined symbol when using cugraph template function
I’m trying to build an example using cugraph::sssp and though I’m linking in the right libraries, I am getting this error:
undefined reference to 'void cugraph::sssp<int, int, float, false>(raft::handle_t const&,
cugraph::graph_view_t<int, int, false, false, void> const&, cugraph::edge_property_view_t<int, float const*,
thrust::THRUST_200302_700_NS::iterator_traits<float const*>::value_type>, float*, int*, int, float, bool)'
Here’s my code:
#include <cugraph/graph.hpp>
#include <cugraph/algorithms.hpp>
#include <cugraph/graph_functions.hpp>
#include <rmm/device_uvector.hpp>
#include <rmm/device_buffer.hpp>
#include <raft/core/handle.hpp>
#include <iostream>
int main()
    // Initialize RAFT handle
    raft::handle_t handle;
    // Define the graph edges (source, destination, weight)
    std::vector<int> h_vtx = {0, 1, 2, 3, 4};
    std::vector<int> h_src = {0, 0, 1, 2, 2, 3};
    std::vector<int> h_dst = {1, 2, 3, 3, 4, 4};
    std::vector<float> h_wgt = {1.0, 2.0, 1.0, 1.0, 3.0, 1.0};
    // Number of vertices
    int num_vertices = 5;
    // Transfer data to device
    rmm::device_uvector<int> d_vtx(h_vtx.size(), handle.get_stream());
    rmm::device_uvector<int> d_src(h_src.size(), handle.get_stream());
    rmm::device_uvector<int> d_dst(h_dst.size(), handle.get_stream());
    rmm::device_uvector<float> d_wgt(h_wgt.size(), handle.get_stream());
    raft::update_device(d_wgt.data(), h_wgt.data(), h_wgt.size(), handle.get_stream());
    raft::update_device(d_src.data(), h_src.data(), h_src.size(), handle.get_stream());
    raft::update_device(d_dst.data(), h_dst.data(), h_dst.size(), handle.get_stream());
    // Create graph
    auto [graph, edge_weights, a, b, c] = cugraph::create_graph_from_edgelist<int,
        int,
        float, int,
        false, false>(
        handle,
        std::move(d_vtx),
        std::move(d_src),
        std::move(d_dst),
        std::move(d_wgt),
        std::nullopt,
        std::nullopt,
        // std::nullopt,
        cugraph::graph_properties_t{false, false},
        false, false);
    // Allocate memory for distances
    rmm::device_uvector<float> distances(num_vertices, handle.get_stream());
    rmm::device_uvector<int> d_predecessors(num_vertices, handle.get_stream());
    auto edge_weight_view = std::make_optional((*edge_weights).view());
    // Run SSSP
    int source_vertex = 0;
    cugraph::sssp(handle,
                  graph.view(),
                  *edge_weight_view,
                  distances.data(),
                  d_predecessors.data(),
                  source_vertex);
    // Transfer results back to host
    std::vector<float> h_distances(num_vertices);
    raft::update_host(h_distances.data(), distances.data(), num_vertices, handle.get_stream());
    handle.sync_stream();
    // Print distances
    std::cout << "Distances from source vertex " << source_vertex << ":\n";
    for (int i = 0; i < num_vertices; ++i)
        std::cout << "Vertex " << i << ": " << h_distances[i] << "\n";
    return 0;
And here’s my cmdline to compile it:
nvcc -arch=sm_70 -DLIBCUDACXX_ENABLE_EXPERIMENTAL_MEMORY_RESOURCE -o test ./main.cu -lcugraph -lraft
Since sssp is a template function, how could it have an undefined reference? Thanks for your help!
Hi Thayne and welcome!
Since this forum is focused on the NVHPC compilers, I don’t think we’ll be able to get you a good answer here. Unfortunately, I’m not sure where the best spot is. Let’s try moving your post over to the Accelerated Libraries Forum to see if they can help.
If you don’t get a response there and since I’m presuming you’re using RAPIDS, you might need to submit an issue report on rapids.ia.
-Mat
