I plug a 4k monitor then TX2 detects plugging.
After that, however, TX2 unplugs and re-plugs by itself.
It occurs on our carrier board and devkit.
It seems the self unplugging/plugging can cause the error in several cases, such as #8.
I post log in #8 case B.
On [2135.125270], I plug 4k monitor to HDMI-1 port
On [2136.979614], TX2 unplugs the monitor by itself
On [2137.083258], TX2 plugs the monitor again by itself
After [2138.303987], TX2 hit the error
[ 2135.119818] tegradc 15210000.nvdisplay: blank - powerdown
<b>[ 2135.125270] tegradc 15210000.nvdisplay: hdmi: plugged</b>
[ 2135.132453] tegradc 15200000.nvdisplay: blank - powerdown
[ 2135.199375] PD DISP1 index3 DOWN
[ 2135.199463] PD DISP0 index2 DOWN
[ 2135.212063] tegradc 15200000.nvdisplay: unblank
[ 2135.212074] PD DISP0 index2 UP
[ 2135.212986] PD DISP1 index3 UP
[ 2135.214173] Parent Clock set for DC plld3
[ 2135.215559] tegradc 15200000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 2135.272194] tegradc 15200000.nvdisplay: unblank
[ 2135.276761] tegradc 15210000.nvdisplay: blank - powerdown
[ 2135.384674] tegradc 15200000.nvdisplay: blank - powerdown
[ 2135.454616] PD DISP1 index3 DOWN
[ 2135.454699] PD DISP0 index2 DOWN
[ 2135.467224] tegradc 15200000.nvdisplay: unblank
[ 2135.467236] PD DISP0 index2 UP
[ 2135.468161] PD DISP1 index3 UP
[ 2135.469371] Parent Clock set for DC plld3
[ 2135.470737] tegradc 15200000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 2135.527397] tegradc 15200000.nvdisplay: unblank
[ 2135.531957] tegradc 15210000.nvdisplay: blank - powerdown
[ 2135.589840] tegradc 15200000.nvdisplay: blank - powerdown
[ 2135.659804] PD DISP1 index3 DOWN
[ 2135.659890] PD DISP0 index2 DOWN
[ 2135.672507] tegradc 15200000.nvdisplay: unblank
[ 2135.672519] PD DISP0 index2 UP
[ 2135.673418] PD DISP1 index3 UP
[ 2135.674601] Parent Clock set for DC plld3
[ 2135.676082] tegradc 15200000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 2135.732776] tegradc 15200000.nvdisplay: unblank
[ 2135.737339] tegradc 15210000.nvdisplay: blank - powerdown
[ 2135.742753] tegradc 15210000.nvdisplay: unblank
[ 2135.742764] PD DISP2 index4 UP
[ 2135.743242] Parent Clock set for DC plld2
[ 2135.748709] tegradc 15210000.nvdisplay: hdmi: pclk:594000K, set prod-setting:prod_c_600M
[ 2136.799724] tegradc 15210000.nvdisplay: unblank
[ 2136.970780] PD DISP2 index4 DOWN
[ 2136.974164] tegradc 15210000.nvdisplay: blank - powerdown
<b>[ 2136.979614] tegradc 15210000.nvdisplay: hdmi: unplugged</b>
[ 2136.994659] tegradc 15200000.nvdisplay: blank - powerdown
[ 2137.065116] PD DISP1 index3 DOWN
[ 2137.065202] PD DISP0 index2 DOWN
[ 2137.077805] tegradc 15210000.nvdisplay: blank - powerdown
[ 2137.083237] tegradc 15200000.nvdisplay: unblank
[ 2137.083249] PD DISP0 index2 UP
<b>[ 2137.083258] tegradc 15210000.nvdisplay: hdmi: plugged</b>
[ 2137.084152] PD DISP1 index3 UP
[ 2137.085359] Parent Clock set for DC plld3
[ 2137.086737] tegradc 15200000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 2137.148401] tegradc 15200000.nvdisplay: unblank
[ 2137.152976] tegradc 15210000.nvdisplay: blank - powerdown
[ 2137.158386] tegradc 15210000.nvdisplay: unblank
[ 2137.158397] PD DISP2 index4 UP
[ 2137.158866] Parent Clock set for DC plld2
[ 2137.164294] tegradc 15210000.nvdisplay: hdmi: pclk:594000K, set prod-setting:prod_c_600M
[ 2138.215708] tegradc 15210000.nvdisplay: unblank
[b][ 2138.303987] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 2138.310521] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop
[ 2139.367988] tegradc 15210000.nvdisplay: dc_poll_register 0x41: timeout
[ 2139.374524] tegradc 15210000.nvdisplay: dc timeout waiting for DC to stop[/b]
Could you repro this issue on devkit by using same method as #8?
I’m sorry but I don’t have DISPLAY CONNECTOR - HDMI adapter. So I can’t try #8 on devkit.
It’s difficult to monitor the gpio while running your commands via UART.
So I monitor them while running below commands instead.
sudo -s
while true; do cat /sys/kernel/debug/gpio | grep hdmi ; sleepenh 0.1 ; done;
And the log on devkit is following.
1462513590.257121
gpio-252 ( |vdd-hdmi ) out hi
gpio-441 ( |hdmi2.0_hpd ) in hi
1462513590.391012
gpio-441 ( |hdmi2.0_hpd ) in lo
[ 386.156480] tegradc 15210000.nvdisplay: blank - powerdown
<b>[ 386.163340] tegradc 15210000.nvdisplay: hdmi: plugged</b>
1462513590.524716
[ 386.213167] tegradc 15210000.nvdisplay: blank - powerdown
1462513590.634958
1462513590.745336
1462513590.858871
1462513590.972479
1462513591.084530
1462513591.201320
1462513591.316551
1462513591.427704
1462513591.540888
[ 386.220894] tegradc 15210000.nvdisplay: unblank
[ 386.220908] PD DISP0 index2 UP
[ 386.221933] PD DISP1 index3 UP
[ 386.222024] PD DISP2 index4 UP
[ 386.223609] Parent Clock set for DC plld2
[ 386.231116] tegradc 15210000.nvdisplay: hdmi: pclk:594000K, set prod-setting:prod_c_600M
[ 387.289053] tegradc 15210000.nvdisplay: unblank
1462513591.651215
[ 387.360878] tegradc 15210000.nvdisplay: blank - powerdown
[ 387.420254] PD DISP2 index4 DOWN
1462513591.761335
[ 387.422335] PD DISP1 index3 DOWN
[ 387.422484] PD DISP0 index2 DOWN
[ 387.440889] tegradc 15210000.nvdisplay: blank - powerdown
gpio-252 ( |vdd-h[ 387.447752] tegradc 15210000.nvdisplay: unblank
dmi ) out hi <b>[ 387.447792] tegradc 15210000.nvdisplay: hdmi: unplugged</b>
gpio-441 ( [ 387.463129] tegradc 15210000.nvdisplay: unblank
|hdmi2.0_hpd ) in lo
[ 387.515734] tegradc 15210000.nvdisplay: blank - powerdown
[ 387.521234] tegradc 15210000.nvdisplay: unblank
[ 387.525813] tegradc 15210000.nvdisplay: unblank
1462513591.883524
[ 387.563279] tegradc 15210000.nvdisplay: blank - powerdown
<b>[ 387.570279] tegradc 15210000.nvdisplay: hdmi: plugged</b>
gpio-441 ( [ 387.583456] tegradc 15210000.nvdisplay: blank - powerdown
|hdmi2.0_hpd ) in lo
1462513592.011876
1462513592.121530
1462513592.232539
1462513592.347385
1462513592.458798
1462513592.569486
1462513592.678921
1462513592.789524
1462513592.902145
[ 387.591658] tegradc 15210000.nvdisplay: unblank
[ 387.591670] PD DISP0 index2 UP
[ 387.592638] PD DISP1 index3 UP
[ 387.592731] PD DISP2 index4 UP
[ 387.594277] Parent Clock set for DC plld2
[ 387.599878] tegradc 15210000.nvdisplay: hdmi: pclk:594000K, set prod-setting:prod_c_600M
[ 388.672832] tegradc 15210000.nvdisplay: unblank
1462513593.015642
1462513593.131017
[ 388.779274] tegradc 15210000.nvdisplay: blank - powerdown
[ 388.838319] PD DISP2 index4 DOWN
[ 388.838417] PD DISP1 index3 DOWN
[ 388.838502] PD DISP0 index2 DOWN
1462513593.237509
gpio-252 ( |vdd-hdmi ) o[ 388.854750] tegradc 15210000.nvdisplay: unblank
ut hi
gpio-441 ( [ 388.854762] PD DISP0 index2 UP
|hdmi[ 388.855696] PD DISP1 index3 UP
2.0_hpd ) in lo
[ 388.855776] PD DISP2 index4 UP
[ 388.857234] Parent Clock set for DC plld2
[ 388.862497] tegradc 15210000.nvdisplay: hdmi: pclk:594000K, set prod-setting:prod_c_600M
[ 388.950198] tegradc 15210000.nvdisplay: unblank
1462513593.344129
1462513593.457612
1462513593.578300
There were once some users whose HDMI monitor always sets wrong hotplug signal and cause plugged/unplugged keeps showing.
Could you prevent using that monitor for any test at this moment? We are using 3~4 kind of 4k monitors on devkit almost everyday but does not see such behavior.
The messages don’t “keep” showing.
I plug hdmi and TX2 makes "plugged" message
TX2 makes "unplugged" message while the HDMI is connected
TX2 keeps outputting HDMI signal without unplugged/plugged messages
Did you use this monitor in previous test?
Yes, I used the monitor in previous test.
Additionally, other two 4k monitors and one FHD monitor I used in previous tests make TX2 outputting such messages.
The messages are shown in these case.
[Case A]
unplug hdmi
wait until the monitor moves into power saving mode
plug hdmi then the messages are shown
[Case B]
plug hdmi
turn off the monitor by power button
turn on the monitor by power button then the messages are shown
[Case C]
plug hdmi
unplug monitor's AC plug
plug it again then the messages are shown
On the other hand, the messages aren’t shown in following case.
[Case D]
unplug hdmi
plug hdmi while the monitor shows a message such as "No Signal"
Another FHD monitor I used in previous tests makes TX2 showing “No EDID change after HPD bounce, taking no action” message in Case A, B, C and sometimes D instead of “unplugged/plugged” messages.
OK. I prepared some monitors which doesn’t make TX2 showing “unplugged/plugged” messages.
I’m testing again now with them but I already got the error in some conditions on our carrier board while the test is ongoing.
I’m also letting you know that we can’t ban our users from using monitors which makes TX2 showing “unplugged/plugged” messages.
