Hi, I am new to Isaac Sim. I wanted to understand how 3D cameras work. I am planning to use a 3D camera/ LIDAR attached to the TCP flange of a Cobot arm. I plan to use synthetic data generation to train the cobot for the routine. Is there any considerations or limitations that I should be aware of? Like any minimum distance, field of view etc which could generate any possible errors? Is there a way to take a point cloud snapshot and use that to perform the motion (the environment is narrow and availability of light might be a concern) or does Isaac sim require a constant line of sight? I am very new, so thanks in advance!
Related topics
Topic | Replies | Views | Activity | |
Simulating Structured Light Cameras | 1 | 383 | February 28, 2024 | |
Jetbot Camera sensor in simulation | 2 | 236 | May 6, 2024 | |
How to do 2.5D Maps from a camera on the robot using Isaac sim 4.5 standalone Python script | 0 | 10 | May 16, 2025 | |
3D depth camera simulation in Isaac Sim | 5 | 1800 | September 13, 2023 | |
YOLO, Openpose or custom Deep Learning Model Implementation in Omniverse Isaac Sim | 2 | 1014 | March 22, 2023 | |
Modelling depth cameras in Isaac sim | 4 | 1971 | April 5, 2024 | |
Importing .pcd file into Isaac Sim | 1 | 407 | March 25, 2024 | |
Collect data from lidar sensor while the simulation is running | 2 | 746 | April 5, 2024 | |
3D Point Clouds for simulation | 4 | 1116 | April 5, 2024 | |
How to properly handle images on OmniIsaacGymEnvs | 2 | 363 | October 31, 2023 |
