Here is a CUDA code from MAGMA. I want to understand the behavior of thread in two parts:
(This code is a batched version and I am considering the batchsize=1)
magma_int_t m1 = (m > MAX_NTHREADS) ? MAX_NTHREADS : m;
magma_int_t m2 = m - m1;
const magma_int_t ntcol = (m1 > 32) ? 1 : (2 * (32/m1));
magma_int_t shmem = ntcol * magma_ceilpow2(n) * sizeof(double);
magma_int_t gridx = magma_ceildiv(batchCount, ntcol);
dim3 threads(m1, ntcol, 1);
dim3 grid(gridx, 1, 1);
m1 is 90% of the time is a multiplication of 32. So if m1 is a large number then we will have just 1 thread? and if m1 is 32 we will have 2 threads. Is this correct? or is m1==8 we will have 16 threads?
The next part is:
#pragma unroll
for(int i = 0; i < N; i++){
if(tx == i){
#pragma unroll
for(int j = 0; j < N; j++)
sx[j] = rA[j];
__syncthreads();
abs = fabs(MAGMA_D_REAL( sx[i] )) + fabs(MAGMA_D_IMAG( sx[i] ));
linfo = ( abs == MAGMA_D_ZERO && linfo == 0) ? (gbstep+i+1) : linfo;
//linfo = ( abs == MAGMA_D_ZERO ) ? min(linfo,gbstep+i+1):0;
reg = (linfo == 0 ) ? MAGMA_D_DIV(MAGMA_D_ONE, sx[i] ) : MAGMA_D_ONE;
// scal and ger
if( tx > i ){
rA[i] *= reg;
#pragma unroll
for(int j = i+1; j < N; j++){
rA[j] -= rA[i] * sx[j];
If m1 > 32 and we have just 1 thread how we are doing the decomposition?
The complete code is:
-- MAGMA (version 2.6.1) --
Univ. of Tennessee, Knoxville
Univ. of California, Berkeley
Univ. of Colorado, Denver
@date July 2021
@author Azzam Haidar
@author Ahmad Abdelfattah
@generated from magmablas/zgetf2_nopiv_kernels.cu, normal z -> d, Mon Jul 12 18:37:39 2021
#include "magma_internal.h"
#include "magma_templates.h"
#include "sync.cuh"
#include "shuffle.cuh"
#include "batched_kernel_param.h"
// This kernel uses registers for matrix storage, shared mem. for communication.
// It also uses lazy swap.
//extern __shared__ double zdata[];
template<int N>
__device__ void
dgetf2_nopiv_device(int m, double* dA, int ldda, magma_int_t *info, const int tx, double* sx, int gbstep)
double rA[N] = {MAGMA_D_ZERO};
double reg = MAGMA_D_ZERO;
int linfo = 0;
double abs;
// check from previous calls if the panel factorization failed previously
// this is necessary to report the correct info value
if(gbstep > 0 && *info != 0) return;
// read
#pragma unroll
rA[i] = dA[ i * ldda + tx ];
#pragma unroll
if(tx == i){
#pragma unroll
sx[j] = rA[j];
__syncthreads();
// scal and ger
if( tx > i ){
rA[i] *= reg;
#pragma unroll
__syncthreads();
if(tx == 0){
(*info) = (magma_int_t)( linfo );
// write
#pragma unroll
dA[ i * ldda + tx ] = rA[i];
template<int N, int NPOW2>
__global__ void
dgetf2_nopiv_batched_kernel( int m, double** dA_array, int ai, int aj, int ldda,
magma_int_t* info_array, int gbstep, int batchCount)
const int tx = threadIdx.x;
const int ty = threadIdx.y;
const int batchid = blockIdx.x * blockDim.y + ty;
if(batchid >= batchCount)return;
double* dA = dA_array[batchid] + aj * ldda + ai;
magma_int_t* info = &info_array[batchid];
double* sx = (double*)zdata;
sx += ty * NPOW2;
dgetf2_nopiv_device<N>(m, dA, ldda, info, tx, sx, gbstep);
Purpose
dgetf2_nopiv computes the non-pivoting LU factorization of an M-by-N matrix A.
This routine can deal with matrices of limited widths, so it is for internal use.
The factorization has the form
A = L * U
where L is lower triangular with unit diagonal elements (lower
trapezoidal if m > n), and U is upper triangular (upper
trapezoidal if m < n).
This is a batched version that factors batchCount M-by-N matrices in parallel.
Arguments
@param[in]
m INTEGER
The number of rows the matrix A. N >= 0.
@param[in]
n INTEGER
The number of columns of the matrix A. N >= 0.
@param[in,out]
dA_array Array of pointers, dimension (batchCount).
Each is a DOUBLE PRECISION array on the GPU, dimension (LDDA,N).
On entry, each pointer is an M-by-N matrix to be factored.
On exit, the factors L and U from the factorization
A = L*U; the unit diagonal elements of L are not stored.
@param[in]
ai INTEGER
Row offset for dA_array.
@param[in]
aj INTEGER
Column offset for dA_array.
@param[in]
ldda INTEGER
The leading dimension of each array A. LDDA >= max(1,M).
@param[out]
info_array Array of INTEGERs, dimension (batchCount), for corresponding matrices.
- = 0: successful exit
- < 0: if INFO = -i, the i-th argument had an illegal value
or another error occured, such as memory allocation failed.
- > 0: if INFO = i, U(i,i) is exactly zero. The factorization
has been completed, but the factor U is exactly
singular, and division by zero will occur if it is used
to solve a system of equations.
@param[in]
gbstep INTEGER
Internal use.
@param[in]
batchCount INTEGER
The number of matrices to operate on.
@param[in]
queue magma_queue_t
Queue to execute in.
@ingroup magma_getrf_batched
extern "C" magma_int_t
magma_dgetf2_nopiv_internal_batched(
magma_int_t m, magma_int_t n,
double** dA_array, magma_int_t ai, magma_int_t aj, magma_int_t ldda,
magma_int_t* info_array, magma_int_t gbstep,
magma_int_t batchCount, magma_queue_t queue )
#define dAarray(i,j) dA_array, i, j
magma_int_t arginfo = 0;
if (m < 0) {
arginfo = -1;
} else if (n < 0 || n > 32 || (m > 512 && n > 16) ) {
arginfo = -2;
} else if (ai < 0) {
arginfo = -4;
} else if (aj < 0) {
arginfo = -5;
} else if (ldda < max(1,m)) {
arginfo = -6;
if (arginfo != 0) {
magma_xerbla( __func__, -(arginfo) );
return arginfo;
// Quick return if possible
if (m == 0 || n == 0) {
return arginfo;
switch(n){
case 1: dgetf2_nopiv_batched_kernel< 1, magma_ceilpow2( 1)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 2: dgetf2_nopiv_batched_kernel< 2, magma_ceilpow2( 2)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 3: dgetf2_nopiv_batched_kernel< 3, magma_ceilpow2( 3)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 4: dgetf2_nopiv_batched_kernel< 4, magma_ceilpow2( 4)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 5: dgetf2_nopiv_batched_kernel< 5, magma_ceilpow2( 5)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 6: dgetf2_nopiv_batched_kernel< 6, magma_ceilpow2( 6)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 7: dgetf2_nopiv_batched_kernel< 7, magma_ceilpow2( 7)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 8: dgetf2_nopiv_batched_kernel< 8, magma_ceilpow2( 8)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 9: dgetf2_nopiv_batched_kernel< 9, magma_ceilpow2( 9)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 10: dgetf2_nopiv_batched_kernel<10, magma_ceilpow2(10)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 11: dgetf2_nopiv_batched_kernel<11, magma_ceilpow2(11)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 12: dgetf2_nopiv_batched_kernel<12, magma_ceilpow2(12)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 13: dgetf2_nopiv_batched_kernel<13, magma_ceilpow2(13)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 14: dgetf2_nopiv_batched_kernel<14, magma_ceilpow2(14)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 15: dgetf2_nopiv_batched_kernel<15, magma_ceilpow2(15)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 16: dgetf2_nopiv_batched_kernel<16, magma_ceilpow2(16)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 17: dgetf2_nopiv_batched_kernel<17, magma_ceilpow2(17)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 18: dgetf2_nopiv_batched_kernel<18, magma_ceilpow2(18)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 19: dgetf2_nopiv_batched_kernel<19, magma_ceilpow2(19)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 20: dgetf2_nopiv_batched_kernel<20, magma_ceilpow2(20)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 21: dgetf2_nopiv_batched_kernel<21, magma_ceilpow2(21)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 22: dgetf2_nopiv_batched_kernel<22, magma_ceilpow2(22)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 23: dgetf2_nopiv_batched_kernel<23, magma_ceilpow2(23)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 24: dgetf2_nopiv_batched_kernel<24, magma_ceilpow2(24)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 25: dgetf2_nopiv_batched_kernel<25, magma_ceilpow2(25)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 26: dgetf2_nopiv_batched_kernel<26, magma_ceilpow2(26)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 27: dgetf2_nopiv_batched_kernel<27, magma_ceilpow2(27)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 28: dgetf2_nopiv_batched_kernel<28, magma_ceilpow2(28)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 29: dgetf2_nopiv_batched_kernel<29, magma_ceilpow2(29)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 30: dgetf2_nopiv_batched_kernel<30, magma_ceilpow2(30)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 31: dgetf2_nopiv_batched_kernel<31, magma_ceilpow2(31)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
case 32: dgetf2_nopiv_batched_kernel<32, magma_ceilpow2(32)><<<grid, threads, shmem, queue->cuda_stream()>>>(m1, dA_array, ai, aj, ldda, info_array, gbstep, batchCount); break;
default: printf("error: panel width %lld is not supported\n", (long long) n);
if(m2 > 0){
magmablas_dtrsm_recursive_batched(
MagmaRight, MagmaUpper, MagmaNoTrans, MagmaNonUnit,
m2, n, MAGMA_D_ONE,
dAarray(ai ,aj), ldda,
dAarray(ai+m1,aj), ldda, batchCount, queue );
#undef dAarray
return arginfo;
Can I increase the number of threads (<1024)to do the computation faster? I think I have free threads.
Like:
const magma_int_t ntcol = (m1 > 32) ? 4 : (8 * (32/m1));
