Understanding TensorRT compilation process
This is a general question and will not require any hardware/environment specifications.
The process used by me to run a sample TensorRT application (e.g. sample FasterRCNN) is as follows:
  • Install TensorRT from ( .deb ) and dependencies like CUDA/cuDNN
  • Clone TensorRT repo
  • Download and untar the TensorRT binaries from the same site that provides .deb .
  • Compile these binaries (out of the .tar file) using instructions provided in the github repo.
I don’t understand the role of resources used in first 3 steps, i.e., the deb package, the repo and the tar file. Why are all of them required ?
Please note that if you are using a Jetson device.
The TensorRT package is installed as one of the SDK components.
You don’t need to install it manually.
I am asking in reference to the host devices.
Usually, you can install TensorRT on the host with a Debian package directly.
Please check the detailed instructions in our document:
If you have further questions about host TensorRT, please file a new topic to below-board for better help:
Thanks for the response but that’s not my query, let me emphasise on it :
I hope I am being clear here.
If you install it through .deb, only step.1 is required.
The github README asks cloning the repo as well, for the the sample applications .
The OSS GitHub contains up-to-date plugin support.
If a sample requires the latest plugin implementation, you will need to update the library manually.
However, FasterRCNN is added for a while.
The required plugin implementation should be available in the default TensorRT package already.
So, I can compile and run the samples just by downloading the TensorRT .deb package and installing it ? No need for the GitHub repo or the .tar file ?
For Jetson, the package is included in JetPack.
Usually, you can find it when setup Xavier with SDK manager.
Or just run the following command:
$ sudo apt update
$ sudo apt install nvidia-tensorrt
After the installation, you can find the example in the blew folder:
/usr/src/tensorrt/samples/sampleUffFasterRCNN/
I have version 6 or 5 of TensorRT due to my old JetPack version. It is missing this sample. Can I update TensorRT without having to reflash Jetson again ?
nvidia-tensorrt is not found.
Instead I tried tensorrt
$ sudo apt-get install tensorrt
Reading package lists... Done
Building dependency tree
Reading state information... Done
tensorrt is already the newest version (6.0.1.10-1+cuda10.0).
The following packages were automatically installed and are no longer required:
  libcharls1 libgdcm2.8 libgl2ps1.4 libhdf5-openmpi-100 liblept5 libllvm9
  libnetcdf-c++4 libsocket++1 libtesseract4 libvtk6.3
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 337 not upgraded.
On checking apt-cache policy,
$ apt-cache policy tensorrt
tensorrt:
  Installed: 6.0.1.10-1+cuda10.0
  Candidate: 6.0.1.10-1+cuda10.0
  Version table:
 *** 6.0.1.10-1+cuda10.0 500
        500 https://repo.download.nvidia.com/jetson/t194 r32/main arm64 Packages
        100 /var/lib/dpkg/status
I am still unable to update tensorrt as a debian package
Would you mind upgrading your device to r32.6 first?
You can find our OTA feature and detailed command below:
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/updating_jetson_and_host.html#
To update to a new point release
