Understanding the layout of hog::classify_hists
I need to understand the layout of hog::classify_hists for my project. Layout means whether hog::classify_hists is using row major or column major order to classify the histogram. As I am just a beginner for CUDA I didn’t understand most of the code placed in opencv/modules/gpu/src/cuda/hog.cu. Here is the code.
template <int nthreads, // Number of threads per one histogram block
    int nblocks>  // Number of histogram block processed by single GPU thread block
__global__ void classify_hists_kernel_many_blocks(const int img_win_width, const int img_block_width,
        const int win_block_stride_x, const int win_block_stride_y,
        const float* block_hists, const float* coefs,
        float free_coef, float threshold, unsigned char* labels)
    const int win_x = threadIdx.z;
    if (blockIdx.x * blockDim.z + win_x >= img_win_width)
        return;
    const float* hist = block_hists + (blockIdx.y * win_block_stride_y * img_block_width +
            blockIdx.x * win_block_stride_x * blockDim.z + win_x) *
        cblock_hist_size;
    float product = 0.f;
    for (int i = threadIdx.x; i < cdescr_size; i += nthreads)
        int offset_y = i / cdescr_width;
        int offset_x = i - offset_y * cdescr_width;
        product += coefs[i] * hist[offset_y * img_block_width * cblock_hist_size + offset_x];
    __shared__ float products[nthreads * nblocks];
    const int tid = threadIdx.z * nthreads + threadIdx.x;
    reduce<nthreads>(products, product, tid, plus<float>());
    if (threadIdx.x == 0)
        labels[blockIdx.y * img_win_width + blockIdx.x * blockDim.z + win_x] = (product + free_coef >= threshold);
void classify_hists(int win_height, int win_width, int block_stride_y, int block_stride_x,
        int win_stride_y, int win_stride_x, int height, int width, float* block_hists,
        float* coefs, float free_coef, float threshold, unsigned char* labels)
    const int nthreads = 256;
    const int nblocks = 1;
    int win_block_stride_x = win_stride_x / block_stride_x;
    int win_block_stride_y = win_stride_y / block_stride_y;
    int img_win_width = (width - win_width + win_stride_x) / win_stride_x;
    int img_win_height = (height - win_height + win_stride_y) / win_stride_y;
    using std::cout;
    using std::endl;
    cout << img_win_width << endl;
    dim3 threads(nthreads, 1, nblocks);
    dim3 grid(divUp(img_win_width, nblocks), img_win_height);
    cudaSafeCall(cudaFuncSetCacheConfig(classify_hists_kernel_many_blocks<nthreads, nblocks>, cudaFuncCachePreferL1));
    int img_block_width = (width - CELLS_PER_BLOCK_X * CELL_WIDTH + block_stride_x) / block_stride_x;
    classify_hists_kernel_many_blocks<nthreads, nblocks><<<grid, threads>>>(
            img_win_width, img_block_width, win_block_stride_x, win_block_stride_y,
            block_hists, coefs, free_coef, threshold, labels);
    cudaSafeCall( cudaGetLastError() );
    cudaSafeCall( cudaDeviceSynchronize() );
“I didn’t understand most of the code”
any line in particular?
