Understanding the Role of Virtual GPU Software and Licensing
Hi everyone,
I’m in the process of setting up a server with a GPU for use in virtualized environments, specifically for running 3D modeling software. My setup involves partitioning the GPU into four separate instances and assigning each one to a different VM. These VMs will be running 3D modeling software that requires GPU acceleration.
I’ve already installed the necessary drivers, partitioned the GPU into four virtual instances, and confirmed that each VM is able to access its allocated portion of the GPU without any issues. Essentially, each of the four VMs can use its respective GPU partition for the software, and the setup seems to be working perfectly so far.
With this configuration, I’m wondering about the role of Virtual GPU (vGPU) software and licensing. Since I have successfully partitioned and assigned the GPU to my VMs, do I still need to purchase or install additional software or licenses? If so, what specific vGPU licensing model would apply to my scenario? I’m assuming the software is necessary for managing these GPU partitions, but I would appreciate more clarity on how it fits into the overall setup.
Any insights or advice would be greatly appreciated!
Hello @work.rana9, welcome to the NVIDIA developer forums.
You probably know the product pages for vGPU already I guess?
You should check out the free trial and see, if the offered solutions give you any added benefits.
For more questions I suggest you check our dedicated vGPU forum category here on this server: Virtual GPU Forums - NVIDIA Developer Forums
I hope that helps.
