Hello All,
I have made a GPUop in Theano which calls cudnnConvolutionForward() to perform 8-bit convolution. Since, cudaNdarray only supports fp32 as of now, I have to pass float32 arguements of input and filter for convolution to the theano and typecast it to INT parameters before passing it to cudnnConvolutionForward().
I do this using a Kernels called “Float2Int” and ‘DeviceFloatCopy’ ( most probably the threads I am allocating wrong somewhere…:( )
One more kernel ‘Device2DeviceCopy’ to copy the contents of pwdesc (pointer to GPU memory pointed by filter).
Since, I am not very good in threads programming, I am sure something is messing here. :(
In file convolution8bit.cu inside function, when I set the piece of code in function
“void APPLY_SPECIFIC(doConv)”
size_t channels = 4;
int out_channels = 4;
I always get the correct output. I am giving input and filter parameters from conv.py file, computing the output of my theano GPUOP and the normal scipy.signal.convolve2d at the end. Both should give same answers.
BUT, When I change the above two lines of code as
size_t channels = 64;
int out_channels = 64;
Sometimes, the output of convolution is correct but sometimes not. I think this undeterministic behaviour is from the threads.
Since, I am not that good in threads, Can some of you review my code and please guide me forward.
I attach both of my files here :
conv.py
Convolution8bit.cu
Requirements:
- GPU with INT8 support (I am using NVIDIA 1080 TI)
- CUDNN 6.0
- CUDA 8.0
- Theano
- Keras
Steps to run:
- Copy both files from below:
- Change the convolution8Bit.cu file from
#include “/home/d1230/cudnn6.0/cuda/include/cudnn2.h”
to your path to cudnn.h(cudnn 6.0)
- Run command
python conv.py
File conv.py
import numpy as np
from scipy import signal
from theano import gof
#import theano
from theano.gof import COp, Op
import theano.tensor as T
import theano.scalar as S
from theano import function, config
import os
import theano.sandbox.cuda as cuda
from theano.sandbox.cuda.basic_ops import as_cuda_ndarray_variable, GpuOp, gpu_contiguous
from theano import Apply
from theano.sandbox.cuda.type import CudaNdarrayType
from theano import shared
from theano.gradient import grad_undefined
class convGpuOP(COp):
props = ()
def __init__(self,dtype=config.floatX):
self.func_file = "./convolution8Bit.cu"
#self.func_file = "./convolutionfp32Bit.cu"
self.func_name = "APPLY_SPECIFIC(doConvolution8Bit)"
self.dtype = dtype
super(convGpuOP, self).__init__(self.func_file,
self.func_name)
#def c_headers(self):
# return ['<cublas_v2.h>', '<stdio.h>']
return ['/home/d1230/cudnn6.0/cuda/include/cudnn2.h']
def c_header_dirs(self):
return ['/home/d1230/cudnn6.0/cuda/include']
def c_lib_dirs(self):
return ['/home/d1230/cudnn6.0/cuda/lib64']
def c_libraries(self):
return ['cudnn','cudart']
def c_compile_args(self):
return ['-DFIX', '-std=c++11']
def make_node(self, x, y):
# Validate the inputs' type
x = as_cuda_ndarray_variable(x)
assert x.dtype == "float32"
y = as_cuda_ndarray_variable(y)
assert y.dtype == "float32"
assert x.ndim == 2
assert y.ndim == 2
return Apply(self, [x, y], [CudaNdarrayType(broadcastable=(False,False))()])
doConv8Bit = convGpuOP()
if name == ‘main’:
a = T.matrix(dtype=‘float32’)
b = T.matrix(dtype=‘float32’)
c = doConv8Bit(a,b)
fun = function([a,b],c)
f = ((np.arange(224*224).reshape(224,224))%128).astype(‘float32’)
g = (np.ones(9).reshape(3,3)).astype(‘float32’)
#print f
#print g
#print f.shape, g.shape
print “My matrix convolution”
t = fun(f, g)
print t
print “Normal matrix convolution”
f_normal = signal.convolve2d(f, g, ‘valid’)
print np.array_equal(t, f_normal)
File convolution8Bit.cu
#section support_code
#include
#include<cublas_v2.h>
#include<math.h>
#include <cuda.h>
#include
#include
#include
#include
#include
#include
#include
//#include
#include
#include
#include
#include
#include
//#include “cuda_runtime.h”
#include “device_launch_parameters.h”
#define MAX_MSG_LEN 1000
/** Error handling from https://developer.nvidia.com/cuDNN */
#define FatalError(s)
do {
std::stringstream _where, _message;
_where << FILE << ‘:’ << LINE;
_message << std::string(s) + “\n” << FILE << ‘:’ << LINE;
std::cerr << _message.str() << “\nAborting…\n”;
cudaDeviceReset();
exit(1);
} while (0)
#define checkCUDNN(status)
do {
std::stringstream _error;
if (status != CUDNN_STATUS_SUCCESS) {
_error << "CUDNN failure: " << cudnnGetErrorString(status);
FatalError(_error.str());
} while (0)
#define checkCudaErrors(status)
do {
if (status != 0) {
_error << "Cuda failure: " << status;
} while (0)
/** Convolutional layer */
struct ConvolutionLayer {
int kernel_size;
int in_channels, in_height, in_width;
int out_channels, out_height, out_width;
std::vector pconv;
ConvolutionLayer(int in_channels_,
int out_channels_,
int kernel_size_,
int in_w_,
int in_h_)
: pconv(in_channels_ * kernel_size_ * kernel_size_ * out_channels_) {
in_channels = in_channels_;
out_channels = out_channels_;
kernel_size = kernel_size_;
in_width = in_w_;
in_height = in_h_;
out_width = in_w_ - kernel_size_ + 1;
out_height = in_h_ - kernel_size_ + 1;
/** Training context */
struct TrainingContext {
cudnnHandle_t cudnnHandle;
cudnnTensorDescriptor_t dataTensor, conv1Tensor, conv1BiasTensor;
cudnnFilterDescriptor_t conv1filterDesc;
cudnnConvolutionDescriptor_t conv1Desc;
cudnnConvolutionFwdAlgo_t conv1algo;
int m_gpuid;
int m_batchSize;
size_t m_workspaceSize;
// Disable copying
TrainingContext& operator=(const TrainingContext&) = delete;
TrainingContext(const TrainingContext&) = delete;
// Constructor
TrainingContext(int gpuid, int batch_size, ConvolutionLayer& conv1)
: m_gpuid(gpuid) {
m_batchSize = batch_size;
/** Create descriptors within the constructor.
* As instructed in the Usual manual, descriptors for
* input and output tensors, filter, and the forward
* convolution operator are created along with
* cuDNN handle.
checkCudaErrors(cudaSetDevice(gpuid));
checkCUDNN(cudnnCreate(&cudnnHandle));
checkCUDNN(cudnnCreateTensorDescriptor(&dataTensor));
checkCUDNN(cudnnCreateFilterDescriptor(&conv1filterDesc));
checkCUDNN(cudnnCreateConvolutionDescriptor(&conv1Desc));
checkCUDNN(cudnnCreateTensorDescriptor(&conv1Tensor));
// Initialize convolution forward pass
size_t workspaceSizeFromConv = SetFwdConvolutionTensors(
conv1, dataTensor, conv1Tensor, conv1filterDesc, conv1Desc, conv1algo);
m_workspaceSize = std::max((int)workspaceSizeFromConv, 0);
~TrainingContext() {
checkCudaErrors(cudaSetDevice(m_gpuid));
checkCUDNN(cudnnDestroy(cudnnHandle));
checkCUDNN(cudnnDestroyTensorDescriptor(dataTensor));
checkCUDNN(cudnnDestroyTensorDescriptor(conv1Tensor));
checkCUDNN(cudnnDestroyFilterDescriptor(conv1filterDesc));
checkCUDNN(cudnnDestroyConvolutionDescriptor(conv1Desc));
/** Set tensors and ops for forward pass */
size_t SetFwdConvolutionTensors(ConvolutionLayer& conv,
cudnnTensorDescriptor_t& srcTensorDesc,
cudnnTensorDescriptor_t& dstTensorDesc,
cudnnFilterDescriptor_t& filterDesc,
cudnnConvolutionDescriptor_t& convDesc,
cudnnConvolutionFwdAlgo_t& algo) {
int n = m_batchSize;
int c = conv.in_channels;
int h = conv.in_height;
int w = conv.in_width;
// Set input tensor. Folowing the manual, chagnged
// * CUDNN_DATA_FLOAT -> CUDNN_DATA_INT8x4x4, and
// * CUDNN_TENSOR_NCHW_VECT_C -> CUDNN_TENSOR_NCHW_VECT_C
// checkCUDNN(cudnnSetTensor4dDescriptor(
// srcTensorDesc, CUDNN_TENSOR_NCHW_VECT_C, CUDNN_DATA_INT8x4x4, n, c, h, w));
srcTensorDesc, CUDNN_TENSOR_NCHW_VECT_C, CUDNN_DATA_INT8x4, n, c, h, w));
// Set convolution filter. Folowing the manual, chagnged
checkCUDNN(cudnnSetFilter4dDescriptor(filterDesc,
CUDNN_DATA_INT8x4,
conv.out_channels,
conv.in_channels,
conv.kernel_size,
conv.kernel_size));
// checkCUDNN(cudnnSetFilter4dDescriptor(filterDesc,
// CUDNN_DATA_INT8x4x4,
// CUDNN_TENSOR_NCHW_VECT_C,
// conv.out_channels,
// conv.in_channels,
// conv.kernel_size,
// conv.kernel_size));
// Set convolution operator. Folowing the manual, chagnged
// * CUDNN_DATA_FLOAT -> CUDNN_DATA_INT32
int pad_height = 0;
int pad_width = 0;
int stride_h = 1;
int stride_v = 1;
int dilation_h = 1;
int dilation_w = 1;
checkCUDNN(cudnnSetConvolution2dDescriptor(convDesc,
pad_height,
pad_width,
stride_h,
stride_v,
dilation_h,
dilation_w,
CUDNN_CONVOLUTION,
CUDNN_DATA_INT32));
// Compute output dimension. Folowing the manual, chagnged
checkCUDNN(cudnnGetConvolution2dForwardOutputDim(
convDesc, srcTensorDesc, filterDesc, &n, &c, &h, &w));
// Set output tensor (Changed CUDNN_DATA_FLOAT to CUDNN_DATA_INT8x4x4, following the manual)
dstTensorDesc, CUDNN_TENSOR_NCHW, CUDNN_DATA_FLOAT, n, c, h, w));
// dstTensorDesc, CUDNN_TENSOR_NCHW_VECT_C, CUDNN_DATA_INT8x4x4, n, c, h, w));
// Retrieve orward pass algorithm. We can either hardcode it to a specific
// algorithm or use cudnnGetConvolutionForwardAlgorithm. For the purpose
// of this test, either way works.
algo = CUDNN_CONVOLUTION_FWD_ALGO_IMPLICIT_PRECOMP_GEMM;
// Following also works
// checkCUDNN(cudnnGetConvolutionForwardAlgorithm(
// cudnnHandle,
// srcTensorDesc,
// filterDesc,
// convDesc,
// dstTensorDesc,
// CUDNN_CONVOLUTION_FWD_PREFER_FASTEST,
// 0,
// &algo));
// Compute workspace size. We can either hardcode it to a specific number,
// or use cudnnGetConvolutionForwardWorkspaceSize. For the purpose of this
// test, either way works.
//size_t sizeInBytes = 1073741824;
size_t sizeInBytes = 0;
checkCUDNN(cudnnGetConvolutionForwardWorkspaceSize(cudnnHandle,
srcTensorDesc,
filterDesc,
convDesc,
dstTensorDesc,
algo,
&sizeInBytes));
return sizeInBytes;
/** Execute forward pass /
void ForwardPropagation(int data,
float* conv1,
int* pconv1,
void* workspace) {
float alpha = 1.0f;
float beta = 0.0f;
#if 0
printf("cudnnHandle %d\n", cudnnHandle );
printf("dataTensor %d\n", dataTensor );
printf("data %d\n", data );
printf("conv1filterDesc %d\n", conv1filterDesc );
printf("pconv1 %d\n", pconv1 );
printf("conv1Desc %d\n", conv1Desc );
printf("conv1algo %d\n", conv1algo );
printf("workspace %d\n", workspace );
printf("m_workspaceSize %d\n", m_workspaceSize );
printf("conv1Tensor %d\n", conv1Tensor );
printf("conv1 %d\n", conv1 );
printf("++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++**\n" );
checkCUDNN(cudnnConvolutionForward(cudnnHandle,
&alpha,
dataTensor,
data,
conv1filterDesc,
pconv1,
conv1Desc,
conv1algo,
workspace,
m_workspaceSize,
&beta,
conv1Tensor,
conv1));
//Function declaration
global void Float2Int(float * in,int * out, int n);
global void Device2DeviceCopy(int * in,int * out, int n);
global void DeviceFloatCopy(float * in,float * out, int n);
global void printVal(int* val, int elem);
global void printArr(float * in, int elem);
// Support code function
bool matrix_same_dim(PyArrayObject* arr1, PyArrayObject* arr2)
if ((PyArray_NDIM(arr1) == 2) && (PyArray_NDIM(arr2) == 2))
return 1;
else
return 0;
#section support_code_apply
// Apply-specific support function
void APPLY_SPECIFIC(doConv)(
DTYPE_INPUT_0* x_ptr,
DTYPE_INPUT_1* y_ptr,
DTYPE_OUTPUT_0* z_ptr,
int m, int n, int p, int q, int out_row, int out_col)
float gpu_elapsed_time_ms=0;
int iterations = 1;
int gpu = 3; //For now
// input dimensions
size_t width = m;
size_t height = n;
size_t channels =64;
int batch_size = 1;
// Create layer architecture
int out_channels =64;
int kernel_size = p;
int * in1;
int * in2 ;
float *out;
ConvolutionLayer conv1(
(int)channels, out_channels, kernel_size, (int)width, (int)height);
TrainingContext context(gpu, batch_size, conv1);
//Allocate memory on device
(cudaMalloc((void **)&in1, (context.m_batchSize*channels*m*n)*sizeof(int)));
(cudaMalloc((void **)&in2, (channels*kernel_size*kernel_size)*sizeof(int)));
(cudaMalloc((void **)&out, ( sizeof(float) * context.m_batchSize * conv1.out_channels * conv1.out_height * conv1.out_width)));
//Create CUDA stream
cudaStream_t stream;
cudaStreamCreate( &stream);
//CUDA events
cudaEvent_t start1, stop1;
cudaEventCreate(&start1);
cudaEventCreate(&stop1);
cudaEventRecord(start1, 0);
Float2Int<<<((m*n*channels)/1024)+1,1024>>>(x_ptr,in1,sizeof(int) * m*n*context.m_batchSize*channels); //Equivalent ttchSizeo _a
Float2Int<<<((p*q*channels)/1024)+1,1024>>>(y_ptr,in2,sizeof(int) * kernel_size*kernel_size*channels ); //Equivalent to h_b
//printVal<<<1,1>>>(in1, 10);
// start to count execution time of typecasting
cudaEventRecord(stop1, 0);
cudaEventSynchronize(stop1);
// compute time elapse of typecassting
cudaEventElapsedTime(&gpu_elapsed_time_ms, start1, stop1);
printf("Time elapsed for typecasting in Convolution kernels for Input %dx%d, Kernel size %dx%d on GPU is : %f ms.\n\n", m, n, p, q, gpu_elapsed_time_ms);
int* d_pconv1;
checkCudaErrors(cudaMalloc(&d_pconv1, sizeof(int)*conv1.pconv.size()));
//Fill d_pconv1
Device2DeviceCopy<<<((p*q*channels)/1024)+1,1024>>>(in2, d_pconv1,sizeof(int)*conv1.pconv.size());
checkCudaErrors(cudaMemcpyAsync(d_pconv1,
in2,
sizeof(int)*conv1.pconv.size(),
cudaMemcpyDeviceToDevice));
cudaEvent_t start, stop;
cudaEventCreate(&start);
cudaEventCreate(&stop);
// start to count execution time of GPU version
cudaEventRecord(start, 0);
void* d_cudnn_workspace = nullptr;
if (context.m_workspaceSize > 0) {
(cudaMalloc(&d_cudnn_workspace, context.m_workspaceSize));
// Start forward pass
//printf("Begin forwrad pass %d \n" , conv1.pconv.size());
checkCudaErrors(cudaDeviceSynchronize());
//auto t1 = std::chrono::high_resolution_clock::now();
// Temporary buffers and workspaces
printf("Begin %d\n", conv1.pconv.size());
for (int iter = 0; iter < iterations; ++iter) {
context.ForwardPropagation(in1, out, d_pconv1, d_cudnn_workspace);
//printf("Done forwrad pass\n");
//auto t2 = std::chrono::high_resolution_clock::now();
printf(
“Iteration time: %f ms\n”,
std::chrono::duration_caststd::chrono::microseconds(t2 - t1).count() /
1000.0f / iterations);
// Free data structures
//printf("%f %f\n", out[0],out[1]);
//printArr<<<1,1>>>(out, 20);
if (d_cudnn_workspace != nullptr)
(cudaFree(d_cudnn_workspace));
//TO-DO Call dp4a convolution
cudaEventRecord(stop, 0);
cudaEventSynchronize(stop);
// compute time elapse on GPU computing
cudaEventElapsedTime(&gpu_elapsed_time_ms, start, stop);
//printf("Time elapsed on matrix convolutions for Input %dx%d, Kernel size %dx%d on GPU is : %f ms. device float copy is channels %d height %d width %d \n\n", m, n, p, q, gpu_elapsed_time_ms , conv1.out_channels, conv1.out_height, conv1.out_width);
DeviceFloatCopy<<<((conv1.out_channels * conv1.out_height * conv1.out_width)/1024)+1,1024>>>(out,z_ptr,sizeof(float) * context.m_batchSize * conv1.out_channels * conv1.out_height * conv1.out_width);
cudaStreamSynchronize (stream);
cudaStreamDestroy(stream);
cudaFree(in1);
cudaFree(in2);
cudaFree(out);
//checkCudaErrors(cudaFree(d_data));
checkCudaErrors(cudaFree(d_pconv1));
void check_real_matrix(const char* name, CudaNdarray* m)
char msg[MAX_MSG_LEN];
// check whether it’s a matrix (2d CudaNdarray)
if (CudaNdarray_NDIM(m) != 2)
snprintf(msg, MAX_MSG_LEN, “%s must be two-dimensional”, name);
throw std::runtime_error( msg);
// check if unstrided in second dim
if (CudaNdarray_HOST_STRIDES(m)[1] != 1 )
snprintf(msg, MAX_MSG_LEN, “%s must be unstrided (i.e. have contiguous elements) in its second (i.e. last) dimension”, name);
// all checks correct
// Apply-specific main function
int APPLY_SPECIFIC(doConvolution8Bit)(CudaNdarray* input0,
CudaNdarray* input1,
CudaNdarray** output0)
int m,n,p,q;
// Validate that the inputs have the same shape
//printf("Enter main......");
check_real_matrix("input0", input0);
check_real_matrix("input1", input1);
//Input dimensions M*N
m = CudaNdarray_HOST_DIMS(input0)[0];
n= CudaNdarray_HOST_DIMS(input0)[1];
//Filter (kernel) dimensions size P*Q
p = CudaNdarray_HOST_DIMS(input1)[0];
q = CudaNdarray_HOST_DIMS(input1)[1];
printf("M:%d\n", m);
printf("n:%d\n", n);
printf("P:%d\n", p);
printf("Q:%d\n", q);
int out_dim[2] = {m-2,n-2}; //first try with -2
int g = CudaNdarray_prep_output(output0,2,out_dim, 0);
/*printf("%d",CudaNdarray_HOST_DIMS(input0));*/
(DTYPE_INPUT_0*)CudaNdarray_DEV_DATA(input0),
(DTYPE_INPUT_1*)CudaNdarray_DEV_DATA(input1),
(DTYPE_OUTPUT_0*)CudaNdarray_DEV_DATA(*output0),
m,n,p,q,m-2,n-2
return 0;
int i = blockIdx.x * blockDim.x + threadIdx.x;
//float upper_temp = *upper;
if(i < n)
//Actual typecasting
out[i] = (int) in[i];
//printf(“Float to Int %d\n”,out[i]);
if(i < n)
out[i] = in[i];
//printf("Float to Int %d\n",out[i]);
if(i < n)
out[i] = in[i];
int i = 0;
for( i = 0; i< elem; i++ ){
printf(“in1 %f \n”, in[i]);
int i = 0;
printf(“Array elements are %d \n”, val[i]);
