I’m working on ZFS (RWTH Aachen University).
I want to offload a function with OpenACC to the GPU, but the compilation fails with
Unexpected branch type
In the function is a switch-case with 6 cases, if I throw away one case and just use 5 cases, the compilation works. Is there a problem with switch-case and OpenACC? I have got a switch-case with 2 cases in another gpu function and this works well.
I was able find an old RFE from 2012 (TPR#18800) requesting we support larger switch statements. Unfortunately it was deemed a low priority item so has not been addressed. I’ll ask that revisit the issue and see if we can increase the priority.
Hi Mat,
thank you for your help.
Did I understand right, that PGI is not able to work with larger switch-case statements on GPUs?
For now, I try to work around with if-statements.
