Unexpected compile time error using requires clauses
I’m pretty sure I’ve stumled across a bug in the concepts implementation of nvcc:
template <typename T>
struct S
    T t;
    template <typename U>
    requires (false)
    S& operator=(U&& t){
        t.a();
        return *this;
struct S2 : S<T>
    using S<T>::operator=;
int main()
    int a;
    S2<int&> s{a};
This results in the following error (Godbolt link):
<source>(15): error: template constraint not satisfied
<source>(7): note #3135-D: substitution of arguments "<S<int &>>" for requires-clause failed
<source>(7): note #3043-D: atomic constraint evaluates to false
          detected during instantiation of class "S2<T> [with T=int &]"
(23): here
1 error detected in the compilation of "<source>".
Compiler returned: 2
The same does not happen in clang or gcc, and also only happens when using reference types & the using ...::operator=; declaration - I assume this is a bug in nvcc? Any easy workarounds apart from falling back to SFINAE with std::enable_if_t?
