Hi all,
See the following Fortran code accelerated with OpenACC, which is manipulating a 3D allocatable array which is a field of a derived type:
cat test.f90
program test
implicit none
type t
real, allocatable, dimension(:,:,:) :: x
end type
type(t) :: a
allocate(a%x(1,1,1))
a%x(:,:,:) = 1.
!$acc enter data copyin(a,a%x)
!$acc kernels default(present)
a%x(:,:,:) = a%x(:,:,:) + 1.
!$acc end kernels
!$acc update self(a%x)
print*,a%x(:,:,:)
end
The code crashes on my (Pascal) card:
nvfortran -acc -Minfo=accel -g -traceback test.f90 && ./a.out
test:
9, Generating enter data copyin(a%x(:,:,:),a)
10, Generating default present(a,a%x(:,:,:))
11, Loop is parallelizable
Generating NVIDIA GPU code
11, ! blockidx%x threadidx%x auto-collapsed
!$acc loop gang, vector(128) collapse(3) ! blockidx%x threadidx%x
13, Generating update self(a%x(:,:,:))
Present table dump for device[1]: NVIDIA Tesla GPU 0, compute capability 6.1, threadid=1
host:0x4102e0 device:0x7ff623efa000 size:240 presentcount:1+1 line:9 name:a
host:0xc0d2c0 device:0x7ff623efa200 size:4 presentcount:0+1 line:9 name:(null)
allocated block device:0x7ff623efa000 size:512 thread:1
allocated block device:0x7ff623efa200 size:512 thread:1
FATAL ERROR: variable in data clause is partially present on the device: name=(unknown)
But doesn’t crash if the array is 2D or 1D. Is there anything incorrect about my implementation?
Thank you in advance!
Pedro
