Unexpected exception an illegal memory access was encountered
GPU
• DeepStream Version
6.0.1
• TensorRT Version
8
470.57.02 / 510.06
bugs
Encounter the same problem as:
When I tried to convert onnx model with ScatterND operations into tensorrt . The tensorrt will automatically convert it to a plugin.
In the inference of TensorRT, you just need to add initLibNvinferPlugins(NULL,"") at the beginning of the program, you can use it normally. However, I tried to add it into the gstinvinfer_init() in deepstream, it is still not working and I don’t know why.
The solution of
is just remove this operation from the onnx file, Not really solving this problem.
Hi @936214531 ,
Can you use “cuda-gdb” to capture the failure back trace?
