If you have nvidia GPU for desktop, then it would be fine, or you can lower the sources and sinks.
Hi I face the same problem and using 4.0.2 now. Does 5.0 solve this problem? Thanks!
mem leak issue fixed in 5.0, you may upgrate to new version to give a try.
Hi there,
We are using the Deepstream 5.1 and facing the same memory leak issue.
For RTSP stream memory usage is increasing rapidly and in video is little slow but in both it is continuously increasing.
We are using Jetson Nano and we are doing testing on deepstream_imagedata_multistream.py
Regards,
Naresh
