Unexpected result and Bus error with PGI-18.10 fortran
Dear Sir,
The following code gives an unexpected result and a bus error with PGI 18.10 Fortran (Community edition).
module conf_m
    implicit none
    integer, parameter :: dp = kind(0.0d0)
    type conf_t
        real(dp), allocatable :: x(:), v(:)
    contains
        procedure :: set
        procedure :: show
    endtype
contains
subroutine set( self, x, v )
    class(conf_t) :: self
    real(dp), intent(in), optional :: x(:), v(:)
    if (present( x )) self% x(:) = x(:)
    if (present( v )) self% v(:) = v(:)
end
subroutine show( self, msg )
    character(*), intent(in), optional :: msg
    if (present( msg )) print *, msg
    print *, "x = ", self% x
    print *, "v = ", self% v
end
end module
program main
    use conf_m
    implicit none
    type(conf_t) :: conf
    real(dp) :: x( 2 ), v( 2 )
    allocate( conf% x( 2 ), conf% v( 2 ) )
    call conf% set( x = [1.0d0, 2.0d0], v = [3.0d0, 4.0d0] )
    call conf% show()                    ! NG (incorrect result for x)
    call conf% show( msg = "test" )  ! NG (bus error)
end
pgfortran gives this output (which is incorrect
for x)
x = 0.000000000000000 0.000000000000000
v = 3.000000000000000 4.000000000000000
Bus error: 10
while gfortran-8.2 gives this output (which is what I
expect):
x = 1.0000000000000000 2.0000000000000000
v = 3.0000000000000000 4.0000000000000000
test
Though I am not 100% sure whether the above code
is standard-conforming, I am afraid it may be a compiler
issue of PGI-18.4.
Thanks for the report tbzy.
I’ve added problem report (TPR #27051) and have sent it to our compiler engineers to investigate.
Best Regards,
Mat
We’ve fixed this with 19.7, should be included in that version and above.
