When I run the example for OmniGibson in the Anaconda prompt using the command python -m omnigibson.examples.robots.robot_control_example --quickstart
, I encounter these errors. How can I resolve them?
2024-10-21 12:17:22 [8,190ms] [Error] [carb.scripting-python.plugin] UnicodeDecodeError: ‘gbk’ codec can’t decode byte 0xa0 in position 1096: illegal multibyte sequence
At:
D:\Anaconda_envs\envs\omnigibson\lib\json_init_.py(293): load
d:/anaconda_envs/envs/omnigibson/lib/site-packages/isaacsim/exts/omni.isaac.sensor/omni/isaac/sensor/scripts/menu.py(212): init
d:/anaconda_envs/envs/omnigibson/lib/site-packages/isaacsim/exts/omni.isaac.sensor/omni/isaac/sensor/scripts/extension.py(37): on_startup
D:\Anaconda_envs\envs\omnigibson\Lib\site-packages\omni\kernel\py\omni\ext_impl_internal.py(164): _startup_ext
D:\Anaconda_envs\envs\omnigibson\Lib\site-packages\omni\kernel\py\omni\ext_impl_internal.py(224): startup
D:\Anaconda_envs\envs\omnigibson\Lib\site-packages\omni\kernel\py\omni\ext_impl_internal.py(328): startup_extension
PythonExtension.cpp::startup()(2):
D:\Anaconda_envs\envs\omnigibson\Lib\site-packages\isaacsim\exts\omni.isaac.kit\omni\isaac\kit\simulation_app.py(405): _start_app
D:\Anaconda_envs\envs\omnigibson\Lib\site-packages\isaacsim\exts\omni.isaac.kit\omni\isaac\kit\simulation_app.py(199): init
D:\Anaconda_envs\envs\omnigibson\lib\site-packages\omnigibson\simulator.py(149): _launch_app
D:\Anaconda_envs\envs\omnigibson\lib\site-packages\omnigibson\simulator.py(246): _launch_simulator
D:\Anaconda_envs\envs\omnigibson\lib\site-packages\omnigibson\envs\env_base.py(103): init
D:\Anaconda_envs\envs\omnigibson\lib\site-packages\omnigibson\utils\python_utils.py(93): wrapper
D:\Anaconda_envs\envs\omnigibson\lib\site-packages\omnigibson\examples\robots\robot_control_example.py(97): main
D:\Anaconda_envs\envs\omnigibson\lib\site-packages\omnigibson\examples\robots\robot_control_example.py(180):
D:\Anaconda_envs\envs\omnigibson\lib\runpy.py(86): _run_code
D:\Anaconda_envs\envs\omnigibson\lib\runpy.py(196): _run_module_as_main
2024-10-21 12:17:22 [8,191ms] [Error] [omni.ext.plugin] [ext: omni.isaac.sensor-12.7.1] Failed to startup python extension.
