Does the display port need a linux driver to support it? If there is a linux driver, where to locate it? thanks
Every device on jetson requires a linux kernel driver to run.
Not quite sure what you want to ask here. The driver code could be downloaded in each l4t archive page.
Is the display port controller in the SOC? Could you tell me where the linux driver code is in the source package for the display controller? THX
Yes, the dp port controller is inside the soc. Driver code path is: kernel/nvidia/drivers/video/tegra/dc/dp.c.
The download path is as what I said in previous link.
Thanks a lot for the kindly support. It really helps a lot.
