Hi
Is there a plan to add support for unified memory with more than 1 GPU?
Hi
Hi hhward,
CUDA Unified Memory support on more than one GPU has been available for quite some time.
See: Programming Guide :: CUDA Toolkit Documentation
-Mat
Thanks for your reply.
Is it supported with openacc too?
Yes, PGI’s implementation of OpenACC does support CUDA Unified Memory. You can enable it via the compiler flag “-ta=tesla:managed”.
For details please see: User's Guide :: PGI version 18.10 Documentation for x86 and NVIDIA Processors
Hope this helps,
Mat
Thank you for your reply.
I have tested this, but it seems that it is only using one GPU.
I have a test case where I have 17.7GB of data on a computer with four P100(16GB pr card). The memory usage(using nvidia-smi) shows that it is only using one of the cards.
pgfortran test.f90 -o xacc -mp=allcores -ta:tesla:managed
is used to compile.
It looks like all calculations are done on one card.
Do you have any idea what’s wrong?
How are you assigning the OpenMP threads to the GPU devices?
Are the OpenACC regions within the OpenMP parallel regions?
To set the device number, you’ll want something like this in early in the code:
use openmp
use openacc
devNum = acc_get_num_devices(acc_get_device_type())
!$omp parallel private(thid,dev)
thid = omp_get_thread_num()
dev = mod(thid,devNum)
call acc_set_device_num(acc_get_device_type(), dev)
call acc_init(acc_get_device_type())
!$omp end parallel
The OpenMP threads retain the same device for subsequent parallel regions.
! run parallel host threads
!$omp parallel loop
do i=1,N
! offload to the device
!$acc parallel loop
do j=1,M
Hope this helps,
Mat
