Unitree G1 IDM for DreamZero
I am currently using the NVIDIA stack to train a generalist humanoid pick and place policy with unitree’s G1 and I have run into some roadblocks regarding IDM availability. Alot of the tools I want to experiment with (specifically DreamZero and Groot Dreams) require an IDM of the specific robot to generate usable actions.
Without the IDM I am able to generate synthetic data but it isnt usable as it cannot be mapped to joints. Is there a publicaly available IDM for the G1 or are these models going to include these capabilites in the near future?
Thanks for the help.
There is no publicly released IDM specifically for the Unitree G1 that you can drop into DreamZero or GR00T‑Dreams today, and the currently announced DreamZero / GR00T‑Dreams stacks do not yet expose a generic “bring your own robot, no IDM required” workflow for G1‑class humanoids.
Below I’ll break down what is known, why you’re blocked, and what practical paths forward look like.
1. Current status of G1 + IDM
  • DreamZero and GR00T‑Dreams treat the IDM as a learned mapping from visual transitions to robot‑specific joint‑space trajectories, so they must be trained or adapted per robot (YAM, GR1, etc.) rather than being universally interchangeable. dreamzero0.github
  • NVIDIA’s GR00T‑Dreams blog describes IDM conceptually—taking “before/after” frames and labeling them with a sequence of 3D actions—but does not publish IDMs for arbitrary third‑party robots.
  • Unitree has open‑sourced datasets and retargeted motion collections for G1 (e.g., on GitHub/Hugging Face), but these are kinematic/trajectory datasets, not packaged inverse‑dynamics models compatible with the Isaac GR00T blueprints. roboticgizmos
So right now, what you’re seeing (synthetic video/action proposals that you cannot map to G1 joints) is expected: without a G1‑calibrated IDM or a consistent joint‑space retargeting layer, the world‑model outputs stay “non‑actuable” for that robot.
2. Public G1 data vs. an IDM
There are building blocks around G1, just not a ready‑made IDM:
  • Unitree‑related open‑source resources
    • Unitree and others have released G1 datasets for manipulation and locomotion tasks—object placement, pouring, dual‑arm manipulation, etc.—available on GitHub/Hugging Face. roboticgizmos
    • There is also a “G1 retargeted motions” dataset with 174 motion sequences retargeted from human mocap to the G1’s 23‑DOF kinematic structure. huggingface
  • G1 SDK and kinematics
    • The G1 SDK / developer docs provide joint configurations and degrees of freedom for the various G1/G1‑EDU variants. support.unitree
These are exactly the ingredients you would need to train or fine‑tune an IDM yourself (or in collaboration with NVIDIA/Unitree), but nobody has wrapped them as a turnkey “G1‑IDM for DreamZero” artifact yet in public.
3. Likely direction of NVIDIA’s tools
From NVIDIA’s world‑model and GR00T communication so far:
  • GR00T‑Dreams and related blogs emphasize world models + IDM + robot adapter as the core recipe, and they explicitly mention adapting DreamZero‑style models to new robots given modest amounts of robot‑specific data. dreamzero0.github
  • However, the public blueprints today focus on NVIDIA’s reference platforms (e.g., YAM, GR1, GR00T N1.5) and do not yet list Unitree G1 as a supported out‑of‑the‑box target with packaged IDMs. developer.nvidia
Putting this together, it is reasonable to expect that:
  • Future GR00T‑style releases will broaden hardware coverage and may include more “robot adapters” for popular humanoids, but
  • Until NVIDIA or Unitree explicitly announces G1 support, you have to assume G1 IDM is not going to appear as a plug‑and‑play artifact in the immediate term.
So for planning purposes: treat a G1 IDM as something you would either need to (a) train/fit yourself, or (b) obtain under NDA/support from NVIDIA/Unitree rather than from a public download link.
4. Practical options for your project
Given your current situation—training a generalist humanoid pick‑and‑place policy on G1 with NVIDIA’s stack—here are concrete paths you can pursue:
4.1. Use retargeted motion as a bridge
  • Start from the open “G1 retargeted motions” dataset and similar G1 operation datasets. huggingface
  • Instead of trying to directly use DreamZero’s raw action proposals, add a retargeting layer that maps world‑model trajectories (expressed in some canonical or human‑centric space) to G1 joint space using the same kinematic assumptions as those datasets.
  • This does not give you a full learned IDM, but it can make synthetic trajectories at least kinematically consistent with G1 and usable for supervised policy training.
4.2. Train a lightweight G1 IDM
If you have:
  • A few hours of G1 teleop or scripted demonstration data with synchronized RGB (or RGB‑D) and joint trajectories, and
  • Access to the NVIDIA world‑model infrastructure,
then you can:
  • Treat the existing DreamZero/GR00T IDM design as a template and train a robot‑specific head that maps latent motion embeddings (or before/after image features) to G1 actions. developer.nvidia
  • This can often be done with relatively modest data volume, because the heavy lifting (visual understanding, general action priors) is in the shared world model; the IDM mainly learns robot‑specific kinematics and actuation constraints. dreamzero0.github
This is more engineering work, but it aligns with how NVIDIA envisions porting DreamZero‑style policies to new robots.
4.3. Coordinate with Unitree / integrators
  • Unitree is actively building an ecosystem around G1—datasets, app store, dev tools, and third‑party integrators. linkedin
  • Some of those partners (e.g., commercial integrators building embodied AI assistants on G1) are already running custom models that map perception to joint‑space actions locally. robostore
  • It is plausible that Unitree or partners have internal IDMs or action‑prediction modules that could serve as a starting point, even if they’re not labeled as “GR00T IDM” yet.
Practically: it’s worth opening channels with Unitree dev support and NVIDIA’s robotics/GR00T team (through forums and, ideally, your enterprise contacts) to ask about joint efforts or early‑access adapters for G1.
4.4. Keep world‑model training robot‑agnostic
While you wait for a better G1 IDM story:
  • Continue using DreamZero/GR00T‑style world modeling to generate rich latent trajectory representations and visual semantics, even if you can’t directly execute the actions on G1 yet. dreamzero0.github
  • You can train a “downstream” policy that takes these world‑model features plus G1 state and learns a mapping to actions using your own supervised data; the world model still buys you better generalization and sample efficiency.
5. Direct answers to your questions
Is there a publicly available IDM for the G1?
Based on current public information, no public IDM specifically for the Unitree G1 has been released that you can plug directly into DreamZero or GR00T‑Dreams. forums.developer.nvidia
Are these models going to include these capabilities in the near future?
  • NVIDIA’s public materials clearly intend for DreamZero/GR00T‑Dreams to support adaptation to new robots via robot‑specific IDMs or adapters, and they highlight that only modest robot‑specific data is needed. developer.nvidia
  • However, there has been no explicit public commitment or timeline for a ready‑made G1 IDM, so you should assume you’ll either need to build/adapt one yourself or work with NVIDIA/Unitree under a collaboration or support agreement.
If you can share what data you currently have from your G1 (demo logs, mocap‑retargeted trajectories, sim vs real), I can sketch a concrete training pipeline for a minimal G1 IDM that would let you start exploiting DreamZero/GR00T‑Dreams outputs in joint space.
Hi Richard,
Thanks for the help. Just expanding on point 4, I am not sure I completely understand how training relative positions would help create an IDM for dreamzero or groot dreams or how to even go about making that retargeting layer. Does this require running multiple policies at once? What are we even passing in or getting out? How do I train a model to generate tragectories and is there any examples of how to do this (even for other robots)?
Thanks alot
