unknown numeric_limits<double>::lowest() in PGI 16.7
trying to compile
const double low = std::numeric_limits<double>::lowest();
with PGI 16.7 gives the following error message:
error: class "std::numeric_limits<double>" has
          no member "lowest"
The other member functions such as max(), min() etc. seem to compile just fine.
Thanks,
LS
Probably another issue with C++11. Get the right g++ environment, install
everything again, and you should be okay.
dave
OK, got it. I need to put my desired GCC version in the PATH and then reinstall PGI. Do you know whether version 5.2 is OK even though I think officially you only support up to 5.1?
Thanks,
LS
5.2 will not be supported until 16.10.
dave
