When I attempt to print all the element values of an array in cuda-gdb
(the array length is specified as 12 during compile-time, and each element has the type uint32_t
), cuda-gdb
shows an error message: “Unknown storage specifier (read) 0x10000”.
The ‘p &array’ prompts as follows:
(@register _ZN9LargeUintIjLj12EE1EE (*)[12]) 0x7fffe7fffb58
Whether in the cuda-gdb manual or in the prompts from the ‘help’ command, I haven’t seen any option to add additional parameters for setting a storage specifier. How should I address this issue?
There is a sub-forum dedicated to cuda-gdb
and you may receive better / faster answers there.
Hi @SparkHu
Could you please share a few more details about the issue:
- Output of
nvidia-smi
command - Output of
cuda-gdb --version
command - CUDA kernel source code
@AKravets Thanks for your response.
Output of nvidia-smi:
Sun Jul 23 16:02:54 2023
| NVIDIA-SMI 530.30.02 Driver Version: 530.30.02 CUDA Version: 12.1 |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3080 On | 00000000:01:00.0 Off | N/A |
| 30% 40C P8 36W / 320W| 1MiB / 10240MiB | 0% Default |
| | | N/A |
| 1 NVIDIA GeForce RTX 3080 On | 00000000:25:00.0 Off | N/A |
| 30% 31C P8 23W / 320W| 1MiB / 10240MiB | 0% Default |
| | | N/A |
| 2 NVIDIA GeForce RTX 3080 On | 00000000:41:00.0 Off | N/A |
| 30% 30C P8 22W / 320W| 1MiB / 10240MiB | 0% Default |
| | | N/A |
| 3 NVIDIA GeForce RTX 3080 On | 00000000:61:00.0 Off | N/A |
| 30% 28C P8 26W / 320W| 1MiB / 10240MiB | 0% Default |
| | | N/A |
| 4 NVIDIA GeForce RTX 3080 On | 00000000:81:00.0 Off | N/A |
| 30% 29C P8 25W / 320W| 1MiB / 10240MiB | 0% Default |
| | | N/A |
| 5 NVIDIA GeForce RTX 3080 On | 00000000:A1:00.0 Off | N/A |
| 30% 29C P8 20W / 320W| 1MiB / 10240MiB | 0% Default |
| | | N/A |
| 6 NVIDIA GeForce RTX 3080 On | 00000000:C1:00.0 Off | N/A |
| 30% 28C P8 29W / 320W| 1MiB / 10240MiB | 0% Default |
| | | N/A |
| 7 NVIDIA GeForce RTX 3080 On | 00000000:E1:00.0 Off | N/A |
| 30% 27C P8 17W / 320W| 1MiB / 10240MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Output of cuda-gdb --version:
NVIDIA (R) CUDA Debugger
CUDA Toolkit 12.1 release
Portions Copyright (C) 2007-2023 NVIDIA Corporation
**GNU gdb (GDB) 12.1**
Copyright (C) 2022 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
As there are several source code files involved, I have packaged the source code
src.zip (4.1 KB)
and uploaded it.The source code implements the Montgomery modular reduction algorithms on a finite field. Different implementation approaches are used on the host and device sides. The entry kernel function is in the ‘kernel’ function in ‘main.cu’.
Besides not being able to view variable values in cuda-gdb, the results of the debug and release versions are also inconsistent. The release version produces correct results, but the debug version outputs incorrect results.
The command to compile the release version is:
nvcc -o test main.cu
The output of release version:
e98b9564, a92043ac, b25e5075, 70d69a83, 2f4a1a59, 1f8ade1c, 8c1d97e5, 343b588d, 108ce2db, d4df2d9b, f276f5d6, 1795837
The command to compile the debug version is:
nvcc -o test -G main.cu
The output of debug version:
54331d22, 6410f330, 9badc234, 28c1d693, 8acd7b6b, c1f71e54, c66c6c90, d3b5a2ef, e87388f6, 9854398c, 34839e1, c812a3
The two lines of numbers in the output should be exactly the same.
Could you help me take a look at these two issues? Thanks a lot.
In cuda-gdb, when I enter the function d_mont_reduce
and try to print the value of data
, an error of “Unknown storage specifier” occurred. The output is as follows:
(cuda-gdb) n
65 for (int i = 0; i < N; i += 2) {
(cuda-gdb) l
60 }
61
62 static __device__ void d_mont_reduce(LU &data, const uint32_t inv, const LU &modulo) {
63 constexpr uint32_t N = GetLargeUintParam<LU>::element_num;
64 LU odd;
66 mul_by_1(data, odd, inv, modulo, i==0);
67 mul_by_1(odd, data, inv, modulo, false);
68 }
69 asm volatile("add.cc.u32 %0, %0, %1;" : "+r"(data[0]) : "r"(odd[1]));
(cuda-gdb) p/x data
$1 = (@register LU & @register) <error reading variable: Unknown storage specifier (read) 0x10000>
(cuda-gdb) p/x data.value
Hi @SparkHu
Thank you very much for providing the details. We were able to reproduce the issue, so please expect it to be fixed in one of the upcoming CUDA releases.
I will update this topic when the CUDA version with this issue fixed is released.
Hi @AKravets
Which issue are you referring to? or both?
@SparkHu
We managed to reproduce the Unknown storage specifier
issue.
For the inconsistency between the release and debug builds of the same CUDA kernel you might get a faster reply if you ask in the sub-forum dedicated to CUDA programming: CUDA Programming and Performance - NVIDIA Developer Forums
