I have been playing around with the sample app of Motion Estimation Mode Only in Video Codec SDK. I have been able to unpack H264 MV structure but not HEVC. I am wondering if you have a documentation or utility to unpack the MV from zigzag structure to raster scan.
typedef struct _NV_ENC_HEVC_MV_DATA
NV_ENC_MVECTOR mv[4]; /**< up to 4 vectors within a CU */
uint8_t cuType; /**< 0 (I), 1(P) */
uint8_t cuSize; /**< 0: 8x8, 1: 16x16, 2: 32x32, 3: 64x64 */
uint8_t partitionMode; /**< The CU partition mode
0 (2Nx2N), 1 (2NxN), 2(Nx2N), 3 (NxN),
4 (2NxnU), 5 (2NxnD), 6(nLx2N), 7 (nRx2N) */
uint8_t lastCUInCTB; /**< Marker to separate CUs in the current CTB from CUs in the next CTB */
} NV_ENC_HEVC_MV_DATA;
The sample output header for HEVC is as follows
ctb, cuType, cuSize, partitionMode, MV[0].x, MV[0].y, MV[1].x, MV[1].y, MV[2].x, MV[2].y, MV[3].x, MV[3].y, lastCUInCTB
I am confused with the first column, it is an ascending list of indices that seem to be cu index but not CTB?
How do we know the CTB size? Does the sdk support all 64×64, 32×32, or 16×16 CTB size?
Thanks for your time!
