As a small addendum to @bardavid52 's post from last year.
Same situation, same problem. Mobile robot and random hardlocks with any robot motion due to a really odd variant of the 5.5 x 2.5 barrel connector used on the orin agx devkit not making solid contact regardless of power budget. Issue only occurs with the barrel connector. no cold solder joints with the jack. usb-c powers just fine as expected.
Claude wants me to desolder the barrel connector and move to xt30… but before I do that I opted to mcguyver something instead.
I present to you my ghetto-fix.
- Dremel off the last 3mm or so of barrel connector
- THOROUGHLY clean all metal shavings and check for an errant short between the + and -
- Take a pair of pliers and not-so-gently squeeze the barrel jack a bit to deform both surfaces to improve contact with the jack.
- Plug in and remove a few times to confirm it has a good grip.
Does it work? Yes!
Is it slightly ingenious? Yes!
Is it slightly stupid and also dangerous? Also Yes!
Not asking for any help, just validating @bardavid52 's suspicions and offering the community another workaround.
Alan
