I’m currently trying to compile a CUDA static library with NVCC, and link it to a google test executable.
I’m using Microsoft Visual Studio.
The static CUDA library compiles with no problem, however when I try to link it to my google test application I get the following compile error:
dic_cuda.lib(dic_cuda_generated_interpolator_cuda.cu.obj) : error LNK2001: unresolved external symbol __device_builtin_variable_blockDim
I tried including “device_launch_parameters.h” on both test file and cuda file, but that’s not the problem. I tried linking cudart.lib, cuda.lib to my static library but I doesn’t help either (I think they are used by default by the nvcc compiler).
Any idea why?
Thank you
EDIT:
Instead of creating a static library, I tried to compile a DLL, the error is now when compiling/linking my library, not my googletest executable.
Here’s the build log:
2>------ Rebuild All started: Project: dic_cuda, Configuration: Debug x64 ------
2>Building Custom Rule C:/Users/mrc/source/repos/repro_core/EPIC_dic/sources/CMakeLists.txt
2>Compiling CUDA source file ..\..\..\EPIC_dic\sources\interpolator_cuda.cu...
2>
2>C:\Users\mrc\source\repos\repro_core\build\EPIC_dic\sources>"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2\bin\nvcc.exe" -gencode=arch=compute_30,code=\"sm_30,compute_30\" --use-local-env -ccbin "C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.23.28105\bin\HostX64\x64" -x cu -rdc=true -IC:\Users\mrc\source\repos\repro_core\EPIC_dic\include\dic -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2\include" --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart shared -Xcompiler="/EHsc -Zi -Ob0" -g -D_WINDOWS -D"CMAKE_INTDIR=\"Debug\"" -Ddic_cuda_EXPORTS -D"CMAKE_INTDIR=\"Debug\"" -Ddic_cuda_EXPORTS -D_WINDLL -D_MBCS -Xcompiler "/EHsc /W1 /nologo /Od /Fddic_cuda.dir\Debug\vc142.pdb /FS /Zi /RTC1 /MDd /GR" -o dic_cuda.dir\Debug\interpolator_cuda.obj "C:\Users\mrc\source\repos\repro_core\EPIC_dic\sources\interpolator_cuda.cu"
2>interpolator_cuda.cu
2>
2>C:\Users\mrc\source\repos\repro_core\build\EPIC_dic\sources>"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2\bin\nvcc.exe" -dlink -o dic_cuda.dir\Debug\dic_cuda.device-link.obj -Xcompiler "/EHsc /W1 /nologo /Od /Zi /RTC1 /MDd /GR" -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2\lib\x64" cuda.lib cudadevrt.lib cudart.lib kernel32.lib user32.lib gdi32.lib winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib advapi32.lib -Wno-deprecated-gpu-targets -gencode=arch=compute_30,code=sm_30 --machine 64 dic_cuda.dir\Debug\interpolator_cuda.obj
2>cuda.lib
2>cudadevrt.lib
2>cudart.lib
2>kernel32.lib
2>user32.lib
2>gdi32.lib
2>winspool.lib
2>shell32.lib
2>ole32.lib
2>oleaut32.lib
2>uuid.lib
2>comdlg32.lib
2>advapi32.lib
2>interpolator_cuda.obj
2> Creating library C:/Users/mrc/source/repos/repro_core/build/EPIC_dic/sources/Debug/dic_cuda.lib and object C:/Users/mrc/source/repos/repro_core/build/EPIC_dic/sources/Debug/dic_cuda.exp
2>interpolator_cuda.obj : error LNK2001: unresolved external symbol __device_builtin_variable_blockDim
2>C:\Users\mrc\source\repos\repro_core\build\EPIC_dic\sources\Debug\dic_cuda.dll : fatal error LNK1120: 1 unresolved externals
2>Done building project "dic_cuda.vcxproj" -- FAILED.
========== Rebuild All: 1 succeeded, 1 failed, 0 skipped ==========
